Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Listen to table item changes
Listen to table item changes [message #507447] Wed, 13 January 2010 09:30 Go to next message
Is there a way to listen to visible table items of an SWT Table?
So that when the number of items changes a listener is informed.
(A solution with JFace table viewer would also help.)
Kai
Re: Listen to table item changes [message #507461 is a reply to message #507447] Wed, 13 January 2010 05:02 Go to previous messageGo to next message
http://tomsondev.bestsolution.at/2007/01/05/what-items-are-v isible-in-tabletree/
Am 13.01.10 15:30, schrieb Kai Schlamp:
> Regards,
> Kai
Re: Listen to table item changes [message #507472 is a reply to message #507461] Wed, 13 January 2010 10:40 Go to previous messageGo to next message
Thanks, Tom. But I guess I was a bit imprecise with my question, my fault.
I am looking for a way to listen what items are at all inside the table. So when items are added or removed a listener is informed.
Kai
Tom Schindl wrote on Wed, 13 January 2010 05:02
> Regards,
> Kai
Re: Listen to table item changes [message #507487 is a reply to message #507472] Wed, 13 January 2010 11:23 Go to previous message
There's none but might I suggest to use an IObservableList
(WritableList) as your viewer input, a ObservableListContentProvider
add/remove your domain objects there on the WritableList (instead of
calling the viewer pendents) => You can then register a listener on the
WritableList and get informed.
Tom
Am 13.01.10 16:40, schrieb Kai Schlamp:
> Regards,
> Kai
>> > > Regards,
>> > Kai
Previous Topic:Tip for Correct implementation to anchor a widget in the parent composite rectangle.
Next Topic:SWT Browser Control loosing focus on Enter key press
Current Time: Wed Jul 02 10:34:38 EDT 2025
Powered by FUDForum. Page generated in 0.03754 seconds
