java.lang.OutOfMemoryError on Eclipse [message #507088] |
Mon, 11 January 2010 22:19  |
Dear All,
I am compiling a J2EE+Flex application on eclipse ganymede Version: 3.4.1 with the following eclipse.ini settings. (I am working on windows7 machine with 2GB Ram)
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
512M
-framework
plugins\org.eclipse.osgi_3.4.2.R34x_v20080826-1230.jar
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms1024m
-Xmx1024m
-XX:PermSize=512m
-XX:MaxPermSize=512m
-XX:+HeapDumpOnOutOfMemoryError
-Djava.net.preferIPv4Stack=true
But I have continuously happened to face for the following Memory out of bounce exception during compiling the application.
An internal error occurred during: "Building Workspace". java.lang.OutOfMemoryError
Following is the exception trace at <workspace>/.metadeta/.log file.
eclipse.buildId=M20080911-1700
java.version=1.6.0_11
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.jobs 4 2 2010-01-12 08:14:47.007
!MESSAGE An internal error occurred during: "Building Workspace".
!STACK 0
at java.io.RandomAccessFile.writeBytes(Native Method)
at java.io.RandomAccessFile.write(Unknown Source)
at flex2.compiler.PersistenceStore.write(PersistenceStore.java: 154)
at flex2.compiler.API.persistCompilationUnits(API.java:4154)
at flex2.compiler.API.persistCompilationUnits(API.java:4133)
at flex2.tools.oem.internal.OEMUtil.save(OEMUtil.java:163)
at flex2.tools.oem.Application.save(Application.java:506)
at com.adobe.flexbuilder.multisdk.compiler.internal.ASBuilder.s aveState(ASBuilder.java:522)
at com.adobe.flexbuilder.multisdk.compiler.internal.ASItemBuild er.saveState(ASItemBuilder.java:94)
at com.adobe.flexbuilder.project.compiler.BuilderManager.maybeR emoveOldestBuilder(Unknown Source)
at com.adobe.flexbuilder.project.compiler.BuilderManager.getBui lder(Unknown Source)
at com.adobe.flexbuilder.project.compiler.internal.FlexIncremen talBuilder.preBuild(Unknown Source)
at com.adobe.flexbuilder.project.compiler.internal.FlexProjectB uilder.buildItem(Unknown Source)
at com.adobe.flexbuilder.project.compiler.internal.FlexProjectB uilder.build(Unknown Source)
at com.adobe.flexbuilder.project.compiler.internal.FlexIncremen talBuilder.build(Unknown Source)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:633)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:309)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:341)
at org.eclipse.core.internal.resources.Workspace.build(Workspac e.java:330)
at org.eclipse.ui.actions.GlobalBuildAction$1.run(GlobalBuildAc tion.java:182)
Someone who please be kind enough to help me out to get rid of this exception, I have been working on days in finding a solution for this. What I found in every place was asking to increase the memory for JVM, as you can see I have already done it at the eclipse.ini file, but the error popping up continuously.
Thanks a lot in advance
Dha
Re: java.lang.OutOfMemoryError on Eclipse [message #512445 is a reply to message #511818] |
Fri, 05 February 2010 02:59  |
some Java VMs cannot handle more then a total of 2 GB of RAM.
Please note that a MaxPermSize of more then 256 is usually not
necessary. It will only hold references the class objects and string
literals which should not exceed the 256MB limit. If you reduce your
MaxPermSize, you will be able to increase the heap size XMX.
Hope that helps,
Sebastian
Am 03.02.10 05:26, schrieb dhammikas:
> Thnks for the comment. Yes of course, i am contacting flex guys on the
> previous exceptions came through flex builder.. But as i have mentioned
> latter, now i am having matters with increasing the java heap size on
> eclipse. Though i have upgraded the RAM form 2 to 3GB still eclipse
> behaves with the configurations used with 2G RAM, ie
> 1024M
> -vmargs
> -Xms512m
> - -XX:PermSize=512m
> -XX:MaxPermSize=1024m
> What i am worrying about is that, why cant i increase -Xmx and
> XX:MaxPermSize some more, 1G of my RAM is still available, how can i
> config JVM on eclipse to increase these parameters?
> Thnaks a lot for concerning and please share any thoughts. best..
FUDForum. Page generated in 0.04169 seconds
