Home » Modeling » M2T (model-to-text transformation) » [Xpand] LET statement
[Xpand] LET statement [message #506220] Wed, 06 January 2010 09:52 Go to next message
I have a 'component' metamodel. In this metamodel a component have
ports, and each port is typed by a interface.
From a corresponding model I want to generate all referenced interfaces
by component's ports.
I want also to use PROTECT BLOCK feature with the ID generation, but I
must not generate several times the same PROTECT BLOCK.
Then I must know I a current interface in my template generation has
been already generated. To do that I think about a global variable which
keep all generated interface like this :
«LET Set[String] AS generatedInterfaces»
«ENDLET»
and add generated interface in a EXPAND/FILE statement like this :
«generatedInterfaces.put(interface)»
Unfortunaly this doesn't works.
Xpand documentation only describe LET statement with the String
primitive type.
Any help would be welcome.
For more details see
http://gforge.inria.fr/plugins/scmsvn/viewcvs.php/trunk/v1/p lugins/fr.inria.adam.calico.models.generation.xpand.fractalT emplate/models/?root=calico
Launcher.java permits to launch the xpand template without MWE.
Best Regards.
Re: [Xpand] LET statement [message #506348 is a reply to message #506220] Thu, 07 January 2010 03:53 Go to previous messageGo to next message
Hello Esteban,
you can use
«LET {} AS generatedInterfaces»
«ENDLET»
that creates an empty list (no set, so you have to check with generatedInterfaces.contains(...) whether the element is already contained when filling the list.
Another option is to use the globalvar extension:
First you have to add org.eclipse.xtend.util.stdlib to your plugin dependencies.
Then you write an extension (existence_tester.ext):
import <your meta model>;
extension org::eclipse::xtend::util::stdlib::globalvar;
boolean hasNotBeenUsedYet(String att) :
	let atts = (List[String]) getGlobalVar("atts") :
		if(atts == null) then (
			storeGlobalVar("atts", { att }) ->
			true
		else (
			if(atts.contains(att)) then false
			else (
				atts.add(att) ->
				storeGlobalVar("atts", atts) ->
				true
In your Xpand you can use it like that:
«EXTENSION existence_tester»
   «IF hasNotBeenUsedYet("a")»test a«ENDIF»
   «IF hasNotBeenUsedYet("b")»test b«ENDIF»
   «IF hasNotBeenUsedYet("a")»test c«ENDIF»
   «IF hasNotBeenUsedYet("b")»test d«ENDIF»
which should result in an output
a
b
Maybe the second solution is too complicated for your needs but it would free you from filling the generated interfaces set in the same place as checking its content.
Joerg
Re: [Xpand] LET statement [message #506359 is a reply to message #506348] Thu, 07 January 2010 04:30 Go to previous messageGo to next message
Joerg Reichert schrieb:
> Hello Esteban,
> you can use
> «ENDLET»
{}.toSet() would make it a set.
Sven
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] LET statement [message #506366 is a reply to message #506359] Thu, 07 January 2010 05:14 Go to previous messageGo to next message
Hi Joerg & Sven,
I have tried the two solutions without success, I have always these
followings warnings :
0 [main] INFO and2.pr.ProtectedRegionResolverImpl - Source scan
started ...
6 [main] INFO and2.pr.ProtectedRegionResolverImpl - Source scan
finished in 0.004s
6 [main] INFO and2.pr.ProtectedRegionResolverImpl - Files scanned: 17
6 [main] INFO and2.pr.ProtectedRegionResolverImpl - Regions found: 10
11 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'IHM.run' referenced more than once
103 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
104 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'PDA.run' referenced more than once
106 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
116 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'PC.run' referenced more than once
118 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'Authentification.auth' referenced more than once
119 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'GlobalSearch.getData' referenced more than once
121 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'RevocationList.check' referenced more than once
123 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'SessionServer.newTicket' referenced more than once
region with ID 'SessionServer.checkTicket' referenced more than once
125 [main] WARN and2.pr.ProtectedRegionResolverImpl - Protected
region with ID 'MedicalServer.getPicture' referenced more than once
127 [main] INFO org.eclipse.xpand2.Generator - Written 25
files to outlet
[default](/home/esteban/CALICO/trunk/v1/plugins/fr.inria.ada m.calico.models.generation.xpand.fractalTemplate/src-gen)
My attempts are commited :
I must notice that I execute my Xpand template from Java.
Best Regards.
>> Hello Esteban,
>> you can use
>> «ENDLET»
> Cheers,
> Sven
Re: [Xpand] LET statement [message #506440 is a reply to message #506366] Thu, 07 January 2010 09:36 Go to previous message
Hello Esteban,
you iterate too often over the subcomponents:
in main you call
«EXPAND componentImplementation FOREACH this.subComponents»
«EXPAND componentImplementation FOR this»
and in componentImplementation you also call
So you override already generated files and the protected region id collector emits these warn statements as it is served with already collected ids.
Joerg
Re: [Xpand] LET statement [message #506472 is a reply to message #506440] Thu, 07 January 2010 06:18 Go to previous message
Yes you are right,
a stupid mistake on my part.
Thanks Joerg.
Joerg Reichert wrote:
> Hello Esteban,
> in main you call
> collected ids.
> Cheers,
> Joerg
Previous Topic:[Acceleo] Naming conflicts in modules
Next Topic:[Acceleo] Get information about Metamodel in a model
Current Time: Sun Nov 09 03:34:41 EST 2025
Powered by FUDForum. Page generated in 0.04345 seconds
