Home » Modeling » TMF (Xtext) » 404 on the ANTLR connector?
404 on the ANTLR connector? [message #50544] Thu, 11 June 2009 16:57 Go to next message
http://wiki.eclipse.org/Xtext/Workspace_Setup says to use
http://xtext.itemis.com/updates/milestones/site.xml as the update site
for the ANTLR connector. It used to work, but now I get a 404. Did it move?
Shane
Re: 404 on the ANTLR connector? [message #50602 is a reply to message #50544] Fri, 12 June 2009 02:45 Go to previous messageGo to next message
Yes it has moved to
http://download.itemis.com/updates/milestones/site.xml
I've updated the mentioned link in the wiki.
Sven
> Shane
Re: 404 on the ANTLR connector? [message #50711 is a reply to message #50602] Fri, 12 June 2009 12:56 Go to previous messageGo to next message
Sven Efftinge wrote:
> Yes it has moved to
Oh, the old one is also listed here:
http://www.eclipse.org/modeling/tmf/downloads/
Shane
Re: 404 on the ANTLR connector? [message #50888 is a reply to message #50711] Sat, 13 June 2009 11:01 Go to previous messageGo to next message
Thanks, I've updated that as well.
Sven
>> Yes it has moved to
> Shane
Re: 404 on the ANTLR connector? [message #52409 is a reply to message #50888] Fri, 19 June 2009 16:38 Go to previous messageGo to next message
Sven,
Will this be available or replaced for XText, and if so idea on
timeline? Assume some sort of licensing issue is involved. :)
Miles
> Sven
>>> Yes it has moved to
>> Shane
Re: 404 on the ANTLR connector? [message #52440 is a reply to message #52409] Sat, 20 June 2009 09:01 Go to previous messageGo to next message
Hi Miles,
what exactly are you asking for?
Whether the antlr generator will be included in Xtext at some point?
Sven
Miles Parker schrieb:
> Sven,
> Miles
>> Sven
>>>> Yes it has moved to
>>> Shane
Re: 404 on the ANTLR connector? [message #479383 is a reply to message #50602] Mon, 10 August 2009 15:55 Go to previous message
> [Shane] http://wiki.eclipse.org/Xtext/Workspace_Setup says to use
> site for the ANTLR connector. It used to work, but now I get a 404.
> Did it move?
> [Sven] Yes it has moved to
Now I'm getting a 404 there... Looks like it moved here:
http://download.itemis.com/updates/milestones/site/site.xml
If that's intentional, you might want to update the wiki (again). :)
Shane
Previous Topic:[XText] implementing cross references
Next Topic:[Announce] TMF XTEXT 0.7.2RC1 is available
Current Time: Mon Apr 28 05:13:51 EDT 2025
Powered by FUDForum. Page generated in 0.03724 seconds
