Home » Archived » BIRT » Report Parameters
Report Parameters [message #49804] Wed, 22 June 2005 19:27 Go to next message
Rick Spickelmier is currently offline Rick SpickelmierFriend
In version 1.0, when ever I try to bind report parameters to parameters in a
data set, I get the following error (when I try to preview the results):
Invalid Javascreipt expression: Source: ParamBinding(Currency), line: 0,
Expression: params["Currency"]
Script engine error: ReferenceError: "params" is not defined.
Reason:
A Birt exception occurred.
Note that params["Currency"] is what the 'Expression builder' puts in when I
select the Currency report parameter.
Any ideas?
Thanks!
Rick
Re: Report Parameters [message #50502 is a reply to message #49804] Thu, 23 June 2005 16:01 Go to previous messageGo to next message
Originally posted by: dsdas.yahoo.com
I have the same problem?
Can somebody help??
"Rick Spickelmier" <ricks@spickelmier.com> escreveu na mensagem
news:d9ce3r$6nr$1@news.eclipse.org...
> a data set, I get the following error (when I try to preview the results):
> Reason:
> I select the Currency report parameter.
> Any ideas?
> Thanks!
> Rick
Re: Report Parameters [message #50883 is a reply to message #49804] Thu, 23 June 2005 20:10 Go to previous message
Gary Xue is currently offline Gary XueFriend
Please file a bugzilla report so a BIRT engineer can take a look. Make sure
that the report design file that's giving your the problem is attached to
the report.
thanks,
Gary Xue
"Rick Spickelmier" <ricks@spickelmier.com> wrote in message
a
> Reason:
I
> Any ideas?
> Thanks!
> Rick
Previous Topic:Procedures
Next Topic:metadata.ExtensionException --> The design file XXXX has error and can not be run problem
Current Time: Wed Oct 16 10:45:08 GMT 2024
Powered by FUDForum. Page generated in 0.03472 seconds
