Re: Software Updates in eclipse 3.4 [message #333948 is a reply to message #333925] |
Wed, 14 January 2009 16:05 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: eclipse-news.rizzoweb.com
On 1/14/2009 4:35 AM, Sheela wrote:
> We have a feature based product on eclipse 3.4. Can someone tell me how
> to configure it so as to provide software updates.
> I have the update plugin and site.xml, and these worked fine on eclipse
> 3.3.2. But now when i try the software updates link in Help i get the
> message "Cannot launch the Update UI. This installation has not been
> configured properly for software updates." How do i configure my product
> for software updates?
> I'm also getting the message "!ENTRY org.eclipse.equinox.p2.ui.sdk 2 0
> 2009-01-14 14:57:46.318
> !MESSAGE Could not locate the running profile instance" in the error log
> view of the product. I think it is related to the same problem.
If you Google for some of that text, you'll find lots of relevant
information. For example, "This installation has not been configured
properly for software updates" (with the quotes) leads to several blogs
and discussions.
Eric
Re: Software Updates in eclipse 3.4 [message #504293 is a reply to message #334033] |
Fri, 18 December 2009 01:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Li Junhong![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=peonest%40gmail.com) Messages: 1012 Registered: July 2009 |
Hi Sheela,
Have you solved this problem of how to make update function available in exported RCP product based on eclipse 3.4?
Autually, it works really well based eclipse 3.3, just like the situation you met, but cannot work based on 3.4. I'm just a bit confused. Could you do me a favor to share your experience about this? Thanks so much!
Calvin.
[Updated on: Fri, 18 December 2009 01:03] Report message to a moderator
FUDForum. Page generated in 0.02835 seconds
