Extending the tptp UI [message #50379] |
Fri, 13 January 2006 16:22 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: respond_to_newsgroup.nowhere.com
I've read in various places that the tptp UI can be extended, but I can't
find any documentation describing the available extension points. Can
someone point me to the documentation?
Thanks.
Re: Extending the tptp UI [message #50492 is a reply to message #50408] |
Fri, 13 January 2006 20:58 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
"Ali Mehregani" <amehrega@ca.ibm.com> wrote in message
news:dq8p3j$tor$1@utils.eclipse.org...
> See the examples under File > New > Example > UI. Once you create a
> specific example, the help content window will point you to the correct
> help
> page. You can also try reading the documentation under the schema of the
> extension points that you're interested in.
Thanks. That'll definitely get me started.
FUDForum. Page generated in 0.02956 seconds
