Home » Archived » Buckminster » [headless junit] cannot find xml test results file
[headless junit] cannot find xml test results file [message #499563] Mon, 23 November 2009 11:24 Go to next message
Joerg Buchberger is currently offline Joerg BuchbergerFriend
Member
Hi all.
Is there an option for the junit command, that allows me to specify, if, how and where to save the test results?
Or do I have to put a configuration somewhere?
Joerg
icon14.gif  Re: [headless junit] cannot find xml test results file [SOLVED] [message #499587 is a reply to message #499563] Mon, 23 November 2009 12:34 Go to previous message
Member
Joerg Buchberger wrote on Mon, 23 November 2009 06:24
Hi all.
Joerg
Each of the following gives us the available command line options for buckminsters junit command:
buckminster junit -?
buckminster junit --help
buckminster junit
And this is the description/option I was looking for:
-o
--output
  The (file) path where JUnit XML test output will be written to.
Yep. Tested.
Works like a charm.
Cheers.
Joerg
[Updated on: Mon, 23 November 2009 12:35]
Report message to a moderator
Previous Topic:Setup / tear down for JUnit plugin tests
Next Topic:[hudson plugin] fails when performing #create.product
Current Time: Wed Feb 05 06:06:48 GMT 2025
Powered by FUDForum. Page generated in 0.03330 seconds
