Home » Archived » XML Schema Definition (XSD) » XML generation from XSD puts "token" in attributes
icon5.gif  XML generation from XSD puts "token" in attributes [message #498855] Wed, 18 November 2009 19:42 Go to next message
Nick Radov is currently offline Nick RadovFriend
I would like to generate some sample XML files for testing based on an XSD. So I used the "Generate, XML File..." command and it did create a file. Unfortunately, many of the attributes in the generated file are set to "token" which doesn't pass schema validation. The XSD defines a limited set of allowable values for those attributes.
Is there any way to make it generate correct attribute values?
Unfortunately I can't post the XSD files here to reproduce the problem because they are copyright by HL7. If anyone happens to be an HL7 member you can download the CDA.xsd file from the Clinical Document Architecture page in the "CDA Release 2" package.
Re: XML generation from XSD puts "token" in attributes [message #498859 is a reply to message #498855] Wed, 18 November 2009 19:53 Go to previous messageGo to next message
Nick,
The XSD project doesn't provide that action. Maybe the web tools
project does. I've added it to the "to" list of the reply.
> http://www.hl7.org/implement/standards/cda.cfm page in the "CDA
> Release 2" package.
Ed Merks
Re: XML generation from XSD puts "token" in attributes [message #503260 is a reply to message #498859] Fri, 11 December 2009 16:03 Go to previous message
Valentin is currently offline ValentinFriend
Member
Nick, yes there are some limitations in the WTP XSD to XML instance
generator.
I have opened this bugzilla
https://bugs.eclipse.org/bugs/show_bug.cgi?id=297594 to track the problem.
Valentin
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:he1jc9$1k3$1@build.eclipse.org...
> Nick,
> The XSD project doesn't provide that action. Maybe the web tools project
>> http://www.hl7.org/implement/standards/cda.cfm page in the "CDA Release
>> 2" package.
Re: XML generation from XSD puts "token" in attributes [message #604439 is a reply to message #498859] Fri, 11 December 2009 16:03 Go to previous message
Member
generator.
Valentin
> Nick,
>> 2" package.
Previous Topic:Does XML Schema editor work with CCRC?
Next Topic:Create XSD programmatically
Current Time: Wed Feb 05 15:50:13 GMT 2025
Powered by FUDForum. Page generated in 0.03582 seconds
