Home » Modeling » M2T (model-to-text transformation) » XSD adapter and imports(The OawXSDEcoreBuilder has to be called for every EPackage explicitly.)
Re: XSD adapter and imports [message #498032 is a reply to message #497971] |
Fri, 13 November 2009 18:03 |
Moritz Eysholdt Messages: 161 Registered: July 2009 Location: Kiel, Germany |
Hi Marco,
could you please create a bug-report at https://bugs.eclipse.org/bugs/
and attach the XSDs and the workflow I need to reproduce the problem?
cheers,
Moritz
> Sorry for pushing this. But I do not find a solution myself.
> Is there really no answer to this 1/2 year old issue.
> I tried a lot. With having now the schema split in 2 XSD, both reference
> in schemaFile of the workflow, I still get the same:
> WARNING: XSDSchema 'file:/.../foo/root.xml.xsd' has no namespace.
> Setting it to null
> Nov 13, 2009 2:41:27 PM
> org.eclipse.xtend.typesystem.xsd.builder.OawXSDResource
> collectImportedSchemas
> WARNING: Include /root.xml.xsd/XSDImport 'ns1.xsd' has not been
> resolved. XSDSchema 'file:/.../foo/root.xml.xsd' (null)
> org.eclipse.xtend.typesystem.xsd.builder.XSDResolver locateSchema
> INFO: Importing 'ns1.xsd' (http://www.example.org/test) from XSDSchema
> org.eclipse.emf.mwe.internal.core.ast.util.VisitorCreator createBean
> SEVERE: java.lang.RuntimeException: The OawXSDEcoreBuilder has to be
> called for every EPackage explicitly. Schema:XSDSchema
> 'file:/.../foo/ns1.xsd' (http://www.example.org/test) Root:XSDSchema
> 'file:/.../foo/root.xml.xsd' (null) XSDSchemas:
> 'file:/.../foo/root.xml.xsd' (null), 'file:/.../foo/ns1.xsd'
> br
> m
Current Time: Wed Jan 08 19:37:14 GMT 2025
Powered by FUDForum. Page generated in 0.04081 seconds
