jdk 1.5, and early release stuff [message #49222] |
Wed, 04 June 2003 22:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: tgm1024SiteNameMispelled.hotmale.com
If I were to install the sun early adopter stuff for experimenting with
generics and other things, will eclipse work ok with it even though the
eclipse syntax engine itself will not like things like
List<String> list = new ArrayList<String>();
Thanks.
Re: jdk 1.5, and early release stuff [message #49417 is a reply to message #49222] |
Wed, 04 June 2003 23:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: faust.acm.org
This won't work until the Eclipse compiler supports it (on the 3.0 plan).You
can turn off all compilation and use ANT to build. And you can associate
..java files with the default text editor instead of the Java editor if
that's giving you grief. So I suppose if you hack around, you can get this
to "work."
Randy
"Muad'Dib" <tgm1024SiteNameMispelled@hotmale.com> wrote in message
news:bblqvd$ps4$1@rogue.oti.com...
> Thanks.
Re: jdk 1.5, and early release stuff [message #49476 is a reply to message #49417] |
Wed, 04 June 2003 23:25 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Sounds like time for vi or emacs as my IDE for experimenting with the early
adoption releases. Thanks for yor reply!
In news:bblu2n$rjv$1@rogue.oti.com,
Randy Faust <faust@acm.org> spoke unto us:
> plan).You can turn off all compilation and use ANT to build. And you
> can associate .java files with the default text editor instead of the
> Java editor if that's giving you grief. So I suppose if you hack
> around, you can get this to "work."
> Randy
>> with generics and other things, will eclipse work ok with it even
>> though the eclipse syntax engine itself will not like things like
>> Thanks.
Re: jdk 1.5, and early release stuff [message #50528 is a reply to message #49922] |
Thu, 05 June 2003 15:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Why doesn't eclipse have a simple option:
O turn off jdk specifics
or
O Allow experimental jdk's such as early adoptions
To turn off specific syntax highlighting and the like?
In news:bbn3vq$k49$1@rogue.oti.com,
Johan Compagner <jcompagner@j-com.nl> spoke unto us:
> i think "wait for one of the last milestone builds to include these
> features"
> is more what we can expect.
> johan
> "Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in
> message news:bbn0g7$h3l$1@rogue.oti.com...
>> plan).You
>>> Java editor if
>>> get this
>>> to "work."
>> Maybe you just wait for the first milestone builds. Maybe
>> some of the requested features are implemented then
>> (including generics).
>> Martin (Kersten)
Re: jdk 1.5, and early release stuff [message #52565 is a reply to message #52263] |
Sat, 07 June 2003 19:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In news:bbsg4u$hp2$1@rogue.oti.com,
Tim Tyler <tim@tt1.org> spoke unto us:
> news:bbnp7h$8u3$1@rogue.oti.com...
> What would that do?
Turn off anything within eclipse that was specific to a particular jdk
release.
>> or
> ...and what would that do? You can use "experimental JDKs"
> fine as it is.
You seem to be at odds with everyone else's post in this thread.
Re: jdk 1.5, and early release stuff [message #52649 is a reply to message #52622] |
Sat, 07 June 2003 22:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In news:bbtko3$2f2$1@rogue.oti.com,
>>> What would that do?
>> jdk release.
> Such as?
> What is specific to a particular JDK?
Numerous language changes in 1.5. Generics, for loop iterator enhancement,
Boxing/unboxing of primitives, yadda. These require a different javac.exe
and eclipse is bound to it's internal compiler's revs.
There should be a way to turn off the jdk revision specific stuff, hence
turn off its reliance upon the internal compiler, to just allow external
compilation. Visual Cafe for Java used to do just that, back when it was
alive before borland bought 'em. You had a crap load of fields to fill out,
but you could set it up to use any jdk release when they ended up obsoleting
the one built into the ide.
But you answer yourself in the following paragraphs.
>>>> or
>>> fine as it is.
> using a JDK (the jre of the jdk) can be used perfectly fine
> (If you had the JDK1.5 beta now you could use it for running and
> debugging)
Sure, if that's all you want it for. I tend to use an IDE for /compiling/
too.
> The problem with JDK1.5 that javac is changed pretty much and the
> internal compiler of eclipse has to catchup.
> johan
RIGHT. Which according to folks here, means that I cannot develop using
1.5-isms with eclipse as it stands before rev 3.0.
Re: jdk 1.5, and early release stuff [message #53196 is a reply to message #52649] |
Mon, 09 June 2003 13:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Johan Compagner![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=jcompagner%40j-com.nl) Messages: 148 Registered: July 2009 |
Just turn off auto build and make a ANT builder that uses the javac command.
Of course the Java Editor will still not understand generics code
and i think there will be other problems that could also arise for
example with code completion..
> too.
with an ant builder this should be possible,
> > johan
1.5 isn't even out yet (and i mean out as the first beta)
of course you could use the early adaptor generices lib for looking at it.
But i wouldn't build any code with it as long as the first beta's or RC are
appearing. Because it is still a running target. That's why i believe
eclipse won't support it in the first Milestones of the 3.0 release.
Because then they are constantly playing catchup. Hopefully the generices
spec will stablelize as soon as possible.
But even if an ide had just a javac call. Then i still believe that the IDE
has to be alterd to support all the new syntax (think about the editor)
I also don't know exactly which roadmaps ends first the one of eclispe 3.0
or the one of 1.5? If i have to guess then i think we have Eclipse 3.0 final
long before a 1.5 final so if eclise supports it then it is fine by me.
johan
Re: jdk 1.5, and early release stuff [message #53274 is a reply to message #52649] |
Mon, 09 June 2003 15:21 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Tim Tyler![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=tim%40tt1.org) Messages: 52 Registered: July 2009 |
Member |
news:bbtnuc$3l1$1@rogue.oti.com...
> >>> What would that do?
> >> jdk release.
> > Such as?
enhancement,
A "turn off jdk specifics" option would help with this not in the slightest.
> compilation.
There already is - use javac, jikes - or whatever - as an external tool.
See the "Run > External tools" menu.
> to fill out, but you could set it up to use any jdk release when
> they ended up obsoleting the one built into the ide.
So - do that with Eclipse - if you really want.
It can call command-line utilities like the best of them.
__________
|im |yler http://timtyler.org/ tim@tt1.org
Re: jdk 1.5, and early release stuff [message #53412 is a reply to message #53196] |
Mon, 09 June 2003 18:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
In news:bc2481$b63$1@rogue.oti.com,
....[snipity doo dah]...
> the IDE has to be alterd to support all the new syntax (think about
> the editor)
Not really---there could be an option like I suggested to turn off anything
in the editor (and anything else in the ide) that is language specific.
Ok, thanks for your suggestions though. I'll give them a whack.
FUDForum. Page generated in 0.05117 seconds
