Home » Archived » Buckminster » Aggregator fetching from unc path does not work(Buckminster Aggregator)
Aggregator fetching from unc path does not work [message #493642] Tue, 27 October 2009 12:56 Go to next message
David  is currently offline David Friend
Member
Testing the aggregator to build our internal updatesite.
We have internal plugins that are just hosted on shares with P2 metadata enabled.
I am not able to use unc paths as a location to a mapped repository. I tried file:// and \\ and //../ etc none work, in the end i had to move the files to an webserver and go towards that url, then it worked of course.
any chance unc path lookups will work in the future?
Re: Aggregator fetching from unc path does not work [message #493714 is a reply to message #493642] Tue, 27 October 2009 16:16 Go to previous messageGo to next message
Filip Hrbek is currently offline Filip HrbekFriend
I've tried it with my latest version of aggregator and it works fine.
Both //server/sharedname/repofolder and \\server\sharedname\repofolder work fine (they are automatically translated to file://server/sharedname/repofolder).
Is there any message in the error log?
Best regards
Filip
> enabled.
> course.
Re: Aggregator fetching from unc path does not work [message #493822 is a reply to message #493642] Wed, 28 October 2009 08:08 Go to previous messageGo to next message
Member
what version are you using?
i seem to be using:
buckminister aggregator editor 1.0.0.r10553
which is the latest on:
http://download.eclipse.org/tools/buckminster/tools
but using Eclipse 3.5.0 though not latest.
when i try i get ( i just edited the internal url, its a valid url internally):
eclipse.buildId=I20090611-1540
java.version=1.5.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sv_SE
Framework arguments: -pluginCustomization configuration\plugin_customization.ini
Command-line arguments: -os win32 -ws win32 -arch x86 -pluginCustomization configuration\plugin_customization.ini
Warning
Wed Oct 28 09:04:25 CET 2009
An exception was ignored during command execution
java.net.URISyntaxException: Illegal character in path at index 0: \\server.company.se\GRPskv\folder\Vershant\Eclipse\VE_Update _Site_libraries\lib\Galileo_Final_20090707
at java.net.URI$Parser.fail(URI.java:2816)
at java.net.URI$Parser.checkChars(URI.java:2989)
at java.net.URI$Parser.parseHierarchical(URI.java:3073)
at java.net.URI$Parser.parse(URI.java:3031)
at java.net.URI.<init>(URI.java:578)
at org.eclipse.buckminster.aggregator.p2.util.MetadataRepositor yResourceImpl.load(MetadataRepositoryResourceImpl.java:175)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.buckminster.aggregator.p2.util.MetadataRepositor yResourceImpl.loadRepository(MetadataRepositoryResourceImpl. java:141)
at org.eclipse.buckminster.aggregator.p2.util.MetadataRepositor yResourceImpl.loadRepository(MetadataRepositoryResourceImpl. java:135)
at org.eclipse.buckminster.aggregator.provider.MappedRepository ItemProvider.onLocationChange(MappedRepositoryItemProvider.j ava:487)
at org.eclipse.buckminster.aggregator.provider.MappedRepository ItemProvider.notifyChanged(MappedRepositoryItemProvider.java :213)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:280)
at org.eclipse.buckminster.aggregator.impl.MappedRepositoryImpl .setLocation(MappedRepositoryImpl.java:708)
at org.eclipse.buckminster.aggregator.impl.MappedRepositoryImpl .eSet(MappedRepositoryImpl.java:354)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjec tImpl.java:1073)
at org.eclipse.emf.edit.command.SetCommand.doExecute(SetCommand .java:721)
at org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:131)
at org.eclipse.emf.common.command.BasicCommandStack.execute(Bas icCommandStack.java:84)
at org.eclipse.emf.edit.provider.ItemPropertyDescriptor.setProp ertyValue(ItemPropertyDescriptor.java:1441)
at org.eclipse.emf.edit.ui.provider.PropertySource.setPropertyV alue(PropertySource.java:116)
at org.eclipse.ui.views.properties.PropertySheetEntry.valueChan ged(PropertySheetEntry.java:782)
at org.eclipse.ui.views.properties.PropertySheetEntry.setValue( PropertySheetEntry.java:723)
at org.eclipse.ui.views.properties.PropertySheetEntry.applyEdit orValue(PropertySheetEntry.java:146)
at org.eclipse.ui.views.properties.PropertySheetEntry$1.applyEd itorValue(PropertySheetEntry.java:103)
at org.eclipse.jface.viewers.CellEditor$1.run(CellEditor.java:3 33)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.CellEditor.fireApplyEditorValue(Ce llEditor.java:331)
at org.eclipse.jface.viewers.CellEditor.focusLost(CellEditor.ja va:716)
at org.eclipse.jface.viewers.TextCellEditor$5.focusLost(TextCel lEditor.java:186)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2583)
at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1781)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:42 89)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3979 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2170)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4602 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:231 2)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1530)
at org.eclipse.swt.widgets.Tree.WM_LBUTTONDOWN(Tree.java:6280)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3981 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:5821)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:24 09)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3471)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
Re: Aggregator fetching from unc path does not work [message #493848 is a reply to message #493822] Wed, 28 October 2009 09:41 Go to previous message
Please update from http://download.eclipse.org/tools/buckminster/tools-3.5 (current version is 1.0.0.r10827).
It should fix your problem. However, there is some more work to do (as the URI format is normalized, a messed up repository view may remain among the repository resources, which in the end should not have any influence on the aggregator functionality though).
Filip
David napsal(a):
> i seem to be using:
> internally):
> Warning
> tImpl.java:1073)
> .java:721)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> llEditor.java:331)
> va:716)
> lEditor.java:186)
> ner.java:137)
> a:2405)
> (Realm.java:332)
> bench.java:493)
> ava:149)
> tarter.java:368)
> tarter.java:179)
> ssorImpl.java:39)
Previous Topic:New Buckminster Build - when?
Next Topic:Aggregator chooses lowest version if selected by category
Current Time: Wed Feb 05 18:00:17 GMT 2025
Powered by FUDForum. Page generated in 0.03463 seconds
