IPageLayout.ID_RES_NAV in 3.5 [message #493039] |
Thu, 22 October 2009 19:56 |
Originally posted by: runzhou.li.gmail.com
I've noticed that IPageLayout.ID_RES_NAV is deprecated in 3.5, noted to use
Common Navigator Framework.
What should I do to migrate?
Thank you.
Re: IPageLayout.ID_RES_NAV in 3.5 [message #493553 is a reply to message #493067] |
Mon, 26 October 2009 19:35 |
So is there a given standard resource navigator to replace this old one now?
I just want to add it into the perspective and go.
If it's for sure cannot be done without using an extension point, then it's
all fine.
"Francis Upton" <francisu@ieee.org> 写入消息
news:hbqpsq$ojl$1@build.eclipse.org...
> Look in the Common Navigator section in the Platform Plugin Guide in the
> help, there is a section in there that talks about the migration issues.
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494257 is a reply to message #493592] |
Thu, 29 October 2009 19:32 |
In fact, Resource Navigator and Project Explorer have differences, and these
differences are the reasons why I want to user resource navigator.
"Prakash G.R." <grprakash@gmail.com> 写入消息
news:hc61n4$8pu$1@build.eclipse.org...
> Francis,
> Would it be better if we update the JavaDoc of the IPageLayout.ID_RES_NAV
> to use IPageLayout.ID_PROJECT_EXPLORER instead of that?
> - Prakash
> Platform UI Team, IBM
> http://blog.eclipse-tips.com
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494277 is a reply to message #494272] |
Thu, 29 October 2009 22:00 |
So it's not as "deprecated" as it sounds? ;)
"Remy Suen" <remysuen@ca.ibm.com> 写入消息
news:hcd08r$79q$1@build.eclipse.org...
>> these differences are the reasons why I want to user resource navigator.
> Well, you're more than welcome to continue to use the RN if it satisfies
> your use cases. :)
> Regards,
> Remy
Re: IPageLayout.ID_RES_NAV in 3.5 [message #494423 is a reply to message #494278] |
Fri, 30 October 2009 14:46 |
I see.
Thank you so much :)
news:hcd3h8$79q$3@build.eclipse.org...
> Depends how you interpret the term "deprecated". If it works for you keep
> using it. Just don't expect new enhancements or speedy fixes for bugs
> that are reported.
> I use a few outdated/unmaintained programs even though there are other
> programs that do the same thing and are maintained. The ones I use now do
> what I need it to do so I just keep using it.
> Regards,
> Remy
FUDForum. Page generated in 0.04127 seconds
