Re: Problem on eclipse startup:org.eclipse.swt.SWTError: Cannot initialize Drop [message #491245 is a reply to message #490811] |
Tue, 13 October 2009 18:41 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Grant Gayed![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=Grant_Gayed%40ca.ibm.com) Messages: 2150 Registered: July 2009 |
Hi David,
There's an existing report for this, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=110166 . If you are able to
reproduce this problem reliably then your comments could be quite helpful
there. You say that the failure began happening a few days ago, and prior
to this it worked fine (?). Did you do anything (eg.- installing the J2EE
tools) that coincided with the failures starting to happen? Does plain
eclipse (no J2EE tools) work fine on this machine? Perhaps it's
locale-related? Are you running any other apps, including apps shown in the
system tray, when these failures occur?
Grant
"David" <dlaurent@freenet.de> wrote in message
news:has7ls$7k0$1@build.eclipse.org...
> Since some days I have trouble when starting eclipse. The startup is
discontinued and the log shows following entry:
> !SESSION 2009-10-09
19:29:52.741 -----------------------------------------------
> eclipse.buildId=I20090611-1540
> java.version=1.6.0_16
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
> Framework arguments: -product org.eclipse.epp.package.jee.product
> Command-line arguments: -os win32 -ws win32 -arch x86 -product
> !ENTRY org.eclipse.osgi 4 0 2009-10-09 19:30:14.594
> !MESSAGE Application error
> !STACK 1
> at org.eclipse.swt.dnd.DND.error(DND.java:267)
> at org.eclipse.swt.dnd.DND.error(DND.java:228)
> at org.eclipse.swt.dnd.DropTarget.<init>(DropTarget.java:144)
> at org.eclipse.ui.internal.EditorSashContainer.addDropSupport(E
ditorSashContainer.java:542)
> at org.eclipse.ui.internal.EditorSashContainer.createControl(Ed
itorSashContainer.java:534)
> at
org.eclipse.ui.internal.EditorAreaHelper.<init>(EditorAreaHelper.java:41)
> at org.eclipse.ui.internal.WorkbenchPage.init(WorkbenchPage.jav a:2419)
> at org.eclipse.ui.internal.WorkbenchPage.<init>(WorkbenchPage.java:564)
> at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.
createWorkbenchPage(Workbench3xImplementation.java:39)
> at org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben
chWindow.java:757)
> at org.eclipse.ui.internal.Workbench$21.runWithException(Workbe
nch.java:1045)
> at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run
(StartupThreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr
onizer.java:134)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3855)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
> at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work
benchAdvisor.java:803)
> at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe
nch.java:1384)
onizer.java:134)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
(Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work
bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start
(IDEApplication.java:113)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
eAppHandle.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
..runApplication(EclipseAppLauncher.java:110)
..start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
tarter.java:368)
tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> I have already read alot of forum messages about
> but the solutions are some years old (2005 and 2007) and I don't know if
they are applicable.
> Any idea, what the error is about? Thanks a lot!
> David
Re: Problem on eclipse startup:org.eclipse.swt.SWTError: Cannot initialize Drop [message #496041 is a reply to message #491245] |
Sat, 07 November 2009 13:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andreas Reis![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=andreas.reis%40gmail.com) Messages: 3 Registered: November 2009 |
My Windows copy of Eclipse also refuses to start since about a week due to the same error. As I wrote in Bugzilla's Bug 110166 (my error logs can be found there):
"I am having this problem since a couple of days. Running W7x64 RTM, Eclipse 3.5 SR1 (the "for Java EE Developers" package) and Java 6 Update 17 (16 previously).
I had not changed my Eclipse, which ran fine, and Java configuration when the problem started occurring. Running a fresh copy of Eclipse and reinstalling Java changed nothing.
Azureus (aka Vuze) is malfunctioning as well, apparently due to the same bug."
Wiping the workspace did not solve the problem.
[Updated on: Sat, 07 November 2009 13:53] Report message to a moderator
FUDForum. Page generated in 0.03543 seconds
