Home » Archived » M2M (model-to-model transformation) » [QVTO] Language features enabled by tracing
[QVTO] Language features enabled by tracing [message #488061] Fri, 25 September 2009 09:11 Go to next message
I noticed the resolve* operations documentation refers the usage of a trace.
I presume these features are only available if you QVTO is configured to
generated a trace log (i.e. it does not have some in memory trace buffer
some where). If the previous statement is correct it would imply these
functions are not available when QVTO is called from Java because there is
currently no way to configure tracing for standalone Java execution.
I would appreciate if someone could confirm the above statement since the
resolve* operations are certainly useful for complex transformations.
Derek
Re: [QVTO] Language features enabled by tracing [message #488295 is a reply to message #488061] Sun, 27 September 2009 15:08 Go to previous message
Originally posted by: dvorak.radek.gmail.com
Hi Derek,
The resolve* feature must always work so the traces are kept in memory
during every transformation execution.
The only difference is that if you enable log file generation in QVTO
launch
configuration, the in-memory trace model is persisted.
IOW, traces are involved if a transformation is executed programmatically
using Java API too. There is no need to configure anything about traces to
have resolve* expressions work.
/Radek
On Fri, 25 Sep 2009 15:11:10 +0200, Derek Palma <derek.palma@gmail.com>
wrote:
> trace. I presume these features are only available if you QVTO is
> configured to generated a trace log (i.e. it does not have some in
> memory trace buffer some where). If the previous statement is correct it
> would imply these functions are not available when QVTO is called from
> Java because there is currently no way to configure tracing for
> the resolve* operations are certainly useful for complex transformations.
> Derek
Previous Topic:[ATL] remove from Map Data Type
Next Topic:[QVTO] cloning self
Current Time: Tue Nov 04 07:49:11 EST 2025
Powered by FUDForum. Page generated in 0.03860 seconds
