riena remote Activator is always invalid [message #487220] |
Tue, 22 September 2009 09:27  |
Dear all,
I try to publish a remote service without success. The Following error
always occur:
org.osgi.framework.BundleException: The activator
org.eclipse.emf.example.library.auth.server.Activator for bundle
org.eclipse.emf.example.library.auth.server is invalid
I try it two days but no success. I walk step by step through the
tutorial http://wiki.eclipse.org/Riena_Getting_started_remoteservices
I look at the ping pong example, this run but mine not why? Here ist my
Activator. Hope you can help me.
public class Activator implements BundleActivator {
private ServiceRegistration registry;
public void start(BundleContext context) throws Exception {
AuthServiceImpl service = new AuthServiceImpl();
Hashtable<String, String> properties = new Hashtable<String, String>(3);
properties.put(RSDPublisherProperties.PROP_IS_REMOTE,
Boolean.TRUE.toString());
properties.put(RSDPublisherProperties.PROP_REMOTE_PROTOCOL,
"hessian"); //$NON-NLS-1$
properties.put(RSDPublisherProperties.PROP_REMOTE_PATH,
"/PingPongWS"); //$NON-NLS-1$
registry = context.registerService(IAuthService.class.getName(),
service, properties);
public void stop(BundleContext context) throws Exception {
registry.unregister();
registry = null;
I worked with riena 1.1.0.0 and 1.2.0.0
Thanks in advance
Re: riena remote Activator is always invalid [message #487604 is a reply to message #487220] |
Wed, 23 September 2009 13:00  |
I try many times and the solution was:
You should deactivate the checkbox "This Plugin will make contributions
to the UI" on the new Plug in Project dialog.
Waldi Waldemar schrieb:
> Dear all,
> always occur:
> String>(3);
> registry = null;
> Thanks in advance
Re: riena remote Activator is always invalid [message #583519 is a reply to message #487220] |
> Dear all,
> always occur:
> String>(3);
> registry = null;
> Thanks in advance
FUDForum. Page generated in 0.03879 seconds
