org.eclipse.ui.edit.copy NotHandledException [message #485358] |
Fri, 11 September 2009 13:44 |
Stewart Francis Messages: 9 Registered: July 2009 |
Eclipse 3.4.2/linux
I've included the org.eclipse.ui.edit.copy action in my application, and
supplied my own handler, which is working fine. However, I'm having
problems when the default handler (WidgetMethodHandler) is used. The
copy action in the Edit menu is always enabled, whenever this handler is
being used, regardless of whether or not the handler's isHandled()
evaluates to true.
When the copy command is executed, the isHandled() is checked, returns
false, so the handler isn't used and a NotHandledException is thrown.
This behaviour can be reproduced in eclipse 3.4.2/linux via the
following actions:
Open a plugin.xml editor, select the overview tab, in the outline view
select "overview", in the Edit menu select copy, check the error log.
I've tried to reproduce this on eclipse 3.5/windows/linux and it doesn't
seem to happen (although I've not debugged to find out why).
Is this a 3.4.2 bug? Is there a workaround?
Thanks in advance,
Stew
FUDForum. Page generated in 0.03134 seconds
