Home » Archived » M2M (model-to-model transformation) » Unsupported registration: QS
Unsupported registration: QS [message #478803] |
Fri, 07 August 2009 01:01 |
Originally posted by: valerio.cosentino.gmail.com
hi, i have a problem.
I have created 3 methods..checkName check if two string are igual or
similar, thanks to matches and getSimilarity.
When i launch the atl transformation i get a warning (
Unsupported registration: QS) and an error
What's the warning?
and how i can solved the error?
thank you
helper context String def: matches(s : String) : Boolean =
if( self <> '' and s <> '') then
if self = s then
true
else
false
endif
else
false
endif;
helper context Sequence(String) def: getSimilarity(s : Sequence(String),
sim : Integer) : Integer =
if( self = '' or s = '') then
sim
else
if( self->first() = s->first()) then
(self->excluding(self->first())).getSimilarity(s->excluding(self- >first()),sim+1)
else
(self->excluding(self->first())).getSimilarity(s->excluding(self- >first()),sim)
endif
endif;
helper def: checkName(bpmn : String , uml : String) : Integer =
if bpmn.matches(uml) then
1
else
(bpmn.toSequence()).getSimilarity((uml.toSequence()),0)
endif;
Operation not found: Sequence {'R', 'e', 'q', 'u', 'e', 's', 't', ' ',
'C', 'a', 't', 'o', 'l', 'o', 'g', '
'}.getSimilarity(java.util.ArrayList,java.lang.Integer)
at checkName(modelmatching.atl[82:6-82:63])
local variables: self=thisModule, bpmn='Request Catolog ', uml='Activity'
at __applyClassifierToMatch(modelmatching.atl[136:8-136:49])
link=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@60e9fa,
bpmn=IN1!Request Catolog :BPMN!Activity, uml=IN2!Activity:UML2!Activity,
t1=OUT!<unnamed>:Gambuse!Iguality, t2=OUT!<unnamed>:Gambuse!Disparity
at __exec__(modelmatching.atl)
e=org.eclipse.m2m.atl.engine.emfvm.lib.TransientLink@60e9fa
at main(modelmatching.atl)
[ATL] Re: Unsupported registration: QS [message #482640 is a reply to message #478803] |
Thu, 27 August 2009 12:30 |
William Piers Messages: 301 Registered: July 2009 |
"QS" is the encoded type for Sequence(String), this warning indicates
that ATL doesn't support Sequence as context for helpers.
You have to refactor the getSimilarity helper, for example it could be
defined at the ATLModule level (e.g. as checkName):
helper def: getSimilarity(self_seq: Sequence(String), s :
Sequence(String), sim : Integer) : Integer =
sim
else
if( self_seq->first() = s->first()) then
(self_seq->excluding(self->first())).getSimilarity(s->excluding(self_seq- >first()),sim+1)
else
(self_seq->excluding(self_seq->first())).getSimilarity(s->excluding(self_seq- >first()),sim)
endif
endif;
William
> What's the warning?
> thank you
> helper context String def: matches(s : String) : Boolean = if( self
> if self = s then
> true
> else
> false
> endif
> else
> false
> endif;
> sim
> else
> else
> endif
> endif;
> 1
> else
> endif;
> uml='Activity'
Current Time: Fri Sep 27 00:34:46 GMT 2024
Powered by FUDForum. Page generated in 0.06439 seconds
