Missing 'Generate Java Skeleton' function [message #482219] |
Tue, 25 August 2009 13:39  |
I do not see 'Generate Java Skeleton' function in 2.0.0.200908231911 or
2.0.0.200908021910 weekly loads. Last time we saw the feature was in
2.0.0.200906170711 (June 17th) official load. Any specific reason for
taking that out.
Jamil
Re: Missing 'Generate Java Skeleton' function [message #482631 is a reply to message #482599] |
Thu, 27 August 2009 07:42  |
Vincent,
Here you go:
http://build.eclipse.org/stp/committers/sca-tools/2.0.1.2009 08270736/
Stephane
Vincent Zurczak a écrit :
> I fixed the wizards.
> But the actions work fine from my workspace.
> Stéphane, would it be possible to make another build so that I can test
> all of these elements?
> Vincent.
> Jamil Shaikh a écrit :
>> Hi,
>> It still doesn't work. I installed 2.0.1.200908260835. Still do not
>> see the 'Generate Java Skeleton'; neither SCA > Add SCA Nature.
>> 'SCA Java Project' wizard is broken too. It always gives you error
>> when you press 'Finish'.
>> Jamil
Re: Missing 'Generate Java Skeleton' function [message #575773 is a reply to message #482219] |
Wed, 26 August 2009 08:49  |
> taking that out.
> Jamil
Hi Jamil,
Have you associated the SCA nature to the project that contains your
composite file?
If not, select the project in the Navigator view, then right click > SCA
> Add SCA Nature. Normally, the 'Generate Java Skeleton' function
should reappear.
Stephane
Re: Missing 'Generate Java Skeleton' function [message #575798 is a reply to message #482219] |
Wed, 26 August 2009 08:50  |
Hi Jamil,
On Monday, I committed a fix for that.
This is due to recent changes in the SCA nature ID that were not
correctly propagated.
It will be back in next week build. :)
Vincent.
> taking that out.
> Jamil
Vincent Zurczak
EBM WebSourcing
+33 (0) 4 38 12 91 72
Re: Missing 'Generate Java Skeleton' function [message #575818 is a reply to message #482400] |
Wed, 26 August 2009 09:08  |
The next build is already available ;) I made a build 1 hour ago to test
2.0.1
http://build.eclipse.org/stp/committers/sca-tools/2.0.1.2009 08260835/
Stephane
> Hi Jamil,
> Vincent.
>> or 2.0.0.200908021910 weekly loads. Last time we saw the feature was
>> in 2.0.0.200906170711 (June 17th) official load. Any specific reason
>> for taking that out.
>> Thanks,
>> Jamil
Re: Missing 'Generate Java Skeleton' function [message #575894 is a reply to message #482480] |
Thu, 27 August 2009 04:51  |
Vincent.
> It still doesn't work. I installed 2.0.1.200908260835. Still do not see
> 'SCA Java Project' wizard is broken too. It always gives you error when
> you press 'Finish'.
> Jamil
Vincent Zurczak
EBM WebSourcing
Re: Missing 'Generate Java Skeleton' function [message #575943 is a reply to message #482599] |
Vincent,
Here you go:
Stephane
> Vincent.
>> Hi,
>> Jamil
FUDForum. Page generated in 0.05748 seconds
