Home » Eclipse Projects » Rich Client Platform (RCP) » PropertTester
PropertTester [message #480720] Tue, 18 August 2009 10:09 Go to next message
Jeeeyul Lee is currently offline Jeeeyul LeeFriend
Why Property tester Expression Node does not resolve actual value while
expression runs.
in complex environment, that's not easy to determine point when property
changes.
For example: in word processor, bold state of current text selection.
in this case, we have to call requestEvaluation so many times to use
menu contribution.
Re: PropertTester [message #480830 is a reply to message #480720] Tue, 18 August 2009 15:45 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
The property tester does resolve its value every time the expression is run. Do you mean why do you have to call requestEvaluation(*) when you know your property has changed? Because in any event driven system, something has to create and feed the events into the system.
When using an AbstractSourceProvider to provide a variable (for use with "with" elements) to the evaluation service, the ASP fires events into the system (basically hooking up the client eventing mechanism to the system). When you use a property tester/property, you must hook up your known eventing mechanism to the system.
PW
Thanks! (no contents) [message #480932 is a reply to message #480830] Wed, 19 August 2009 01:39 Go to previous messageGo to next message
I told you.
Re: Thanks! (no contents) [message #481036 is a reply to message #480932] Wed, 19 August 2009 12:07 Go to previous messageGo to next message
"I told you" what, exactly?
You started your post with: "Why Property tester Expression ..." a question. My post was answering your question. So what did you tell me? That you noticed the same thing in your example? Yes, true, but you asked why ... hence my post.
PW
Re: Thanks! (no contents) [message #481180 is a reply to message #481036] Thu, 20 August 2009 01:06 Go to previous messageGo to next message
ooops, "I told you" just means "no contents" in subject.
I told you "no content" in subject because I don't want someone try to
click that post to read, To prevent wasting their time. In Korea, that's
general expression.
I'm sorry if it made you feel bad.
> PW
Re: Thanks! (no contents) [message #481599 is a reply to message #481180] Fri, 21 August 2009 17:25 Go to previous message
Jiyul wrote on Wed, 19 August 2009 21:06
[...snip...]
Don't worry, I'm good Smile
Thank you for the clarification, it makes sense now.
PW
Previous Topic:Load Jar from system variable
Next Topic:Blocking command execution (wainting for results)
Current Time: Wed Feb 05 14:56:13 GMT 2025
Powered by FUDForum. Page generated in 0.09678 seconds
