Eclipse JUnit Plug-in Test [message #65801] |
Fri, 26 June 2009 13:28 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Flavio Donze![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=flavio.donze%40gmx.ch) Messages: 211 Registered: July 2009 Location: Switzerland |
Hello pde team
Right now I'm creating a JUnit Plug-in Lanuch for my server environment.
Doing that, I noticed a few things.
First, since I want to test a server application I don't need any UI
plug-ins. The org.eclipse.test plug-in, actually the UITestApplication
class has dependencies on org.eclipse.ui.ide.application and
org.eclipse.ui. They then have a whole dependency tree on other UI
plug-ins.
This does not affect my tests I just think it's kind of ugly.
So I was wondering if maybe the plug-in should be split up in
org.eclipse.test and org.eclipse.test.ui? What do you think of this?
Second, the launch seems to ignore my start levels if I don't set the
"Auto-Start" to "true". Even though the "Default Auto-Start" option is set
to "true".
Launching in Headless Mode, Test runner JUnit 3.
Is this an intended behavior or should I file a bug report?
cheers
flavio
Prozessmanagement und Qualitätsmanagement Software QMS/IMS
https://www.scodi.ch
Re: Eclipse JUnit Plug-in Test [message #605810 is a reply to message #528521] |
Tue, 18 May 2010 10:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hey Curtis
I updated to the latest Helios Milestone release. The "required" dependency on "org.eclipse.ui.ide.workbench" is gone.
I removed all the UI bundles and launched the JUnit Test. Now I don't get any feedback in the JUnit Result View?
So I did a simple test (the steps that you describe below) and get the following exception:
Caused by: java.lang.NoClassDefFoundError: org/eclipse/ui/testing/ITestHarness
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:621)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund leLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1192)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:174)
... 16 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.ui.testing.ITestHarness
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:506)
... 51 more
What do you think about it? Bug?
greets
Flavio
FUDForum. Page generated in 0.04367 seconds
