Home » Archived » M2M (model-to-model transformation) » Using a matched rule from a lazy rule
Using a matched rule from a lazy rule [message #479562] Tue, 11 August 2009 14:53 Go to next message
Originally posted by: spam.schenkman.info
Hi:
Is it possible to use a matched rule from within a lazy rule?
In the example below, I want MDL!Block.Ports to be converted using a
matched rule for ADL!ADLFlowPort.
The matched rule, of course, exists and is in use in other places in the
code.
I'm using ATL 3.0.0 on Eclipse 3.4.2.
Thanks in advance!
unique lazy rule ADLPort2EncapsulatedBock {
from
s : ADL!ADLFlowPort
to
t : MDL!Block (
Name <- s.name,
Ports <- s,
BlockType <- 'encapsulated'
Re: Using a matched rule from a lazy rule [message #485681 is a reply to message #479562] Mon, 14 September 2009 13:04 Go to previous message
Philipp Simon is currently offline Philipp SimonFriend
Sorry for reviving this one but i have / had a similar problem. If i
understand the execution semantics correctly this is not possible since
the step of matching matched rules to the elements is done before the lazy
rules are executed.
To me this i pretty annoying since once your start using lazy rules for
some element within your models hierarchy everything below this element
has to be created by lazy rules as well ( or it gets created as a root
element).
I would be really interested in why it is that way. I mean why couldn't
one first execute all the imperative stuff and apply the matching phase to
whatever elements did not get handled?
I would be glad if someone with the bigger picture in mind could help me
understand this behavior.
Thanks in advance,
Philipp
Previous Topic:[ATL] Problem refining mode and lazy rules/Iterative target pattern elem
Next Topic:[ATL] result of undefined subSequence call
Current Time: Wed Feb 05 06:44:31 GMT 2025
Powered by FUDForum. Page generated in 0.03195 seconds
