Home » Archived » M2M (model-to-model transformation) » [QVTO]QVTO newbie needs some help here.. :(
[QVTO]QVTO newbie needs some help here.. :( [message #468446] Wed, 05 August 2009 10:41 Go to next message
Originally posted by: kytoz.w.gmail.com
Hi all,
i just created two metamodels "UML.ecore" and "RELATIONAL.ecore" and i
want to use both of them as metamodels for the transformation.
Then i start to write the transformation.qvto and i keep getting the error
that tells me the modeltype can not be found.
i tried to define the modeltype like:
model type uml uses UML;
but also get the error.
what do i need to do if i want that two models work as metamodels for the
transformation? I heard from somewhere that i need to use the extension
point to register the models..but cant find the way to do that.
please help, this problem is killing me :(
thank you very much!
best wishes
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #472106 is a reply to message #468446] Wed, 05 August 2009 15:27 Go to previous messageGo to next message
Hi aslan ,
See some replies in-line, below.
Sergey
aslan wrote:
> Hi all,
> error that tells me the modeltype can not be found.
> the transformation? I heard from somewhere that i need to use the
> extension point to register the models..but cant find the way to do that.
There are two ways to declare modeltype as metamodel consists of
EPackage from given .ecore file.
First is to reference file directly like follows:
modeltype uml uses "platform:/resource/qvto_project/UML.ecore";
Second is to use metamodel mappings.
This can be done from project's context menu "Properties". There is "QVT
Settings / Metamodel Mappings" section. Press "Add", type Source model
URI (usually same as EPackage NsURI) and browse for workspace .ecore model.
Once added (suppose that Source model URI is equal to "my.pack.nsuri")
it can be used in QVTo script like follows:
modeltype uml uses "my.pack.nsuri";
Also there's context assistant (Ctrl + Space) so you can type
modeltype uml uses <Ctrl + Space>
You'll see tool window with all registered metamodels, second <Ctrl +
Space> shows workspace metamodels. In case workspace metamodel being
selected context assistant automatically fills metamodel mappings and
use EPackage NsURI in place of Source model URI.
> best wishes
> aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #478676 is a reply to message #472106] Thu, 06 August 2009 07:26 Go to previous messageGo to next message
hi Sergey,
thank very much for your help! That means a lot for a beginner.
So after I fixed that issue, I wrote my first .qvto file, i fixed almost
all the errors myself except one. I thought that shouldn't be an error but
it just won't go away... :(
Would you please, please give me another hand and help me to check it out?
I made a screen-printing that included all the codes, 2 metamodels and the
error.
you can see it right here:
http://www.realsao.com/error.jpg
Thank you very much for your help!
best wishes,
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #478751 is a reply to message #478676] Thu, 06 August 2009 12:51 Go to previous messageGo to next message
hi there,
umm.. i just deleted the last line of the codes (the line with error),
made an instance .klasse file as Input and excute the first transformation
for me. A .relational file came up but the problem is... It's totally
empty...
I know maybe there is something wrong in the .qvto, but EMPTY? How? =(
Thank you for your help!
regards,
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #478822 is a reply to message #468446] Fri, 07 August 2009 03:13 Go to previous messageGo to next message
I did a simple test for the "nothing transformed" issue:
1.I created an instance of model simpleuml (my.simpleuml) which contains only 1 Model Class as Input and excute the following transformation:
modeltype UML uses 'http://www.eclipse.org/qvt/1.0.0/Operational/examples/simpleuml';
modeltype RDB uses 'http://www.eclipse.org/qvt/1.0.0/Operational/examples/rdb';
transformation Simpleuml_To_Rdb(in uml : UML, out RDB);
main() {
	uml.rootObjects()[UML::Model]->map model2RDBModel();
mapping UML::Model::model2RDBModel() : RDB::Model {
	name := self.name;
that works just fine, a .rdb fild came up with 1 Model class in it.
2. I created an instance of model Klasse ('my.klasse') which contains only 1 'Klasse' Class as Input and excute the following transformation:
modeltype uml uses "platform:/resource/QVT/Klasse.ecore";
modeltype relational uses "platform:/resource/QVT/Relational.ecore";
transformation Klasse2Relational(in xx : uml, out relational);
main() {
	xx.rootObjects()[uml::Klasse]->map class2table();
mapping uml::Klasse::class2table() : relational::Table {
	name := self.name;
after that, an .relational file came up BUT!!: it is empty.. there should be a Table class in it.. but no.. totally empty..
anyone can give me a hand about this plz?
the metamodels that i created for the 2nd transformation you can see em here:
Thank you!
regards,
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479127 is a reply to message #468446] Sun, 09 August 2009 12:40 Go to previous messageGo to next message
still waiting for someone who can give me a hand Sad
anyone please?
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479139 is a reply to message #479127] Sun, 09 August 2009 14:26 Go to previous messageGo to next message
Hi Aslan
In order to solve any problem you need to learn to use the appropriate
analysis technique.
For rich porogramming environments this will be a source level debugger.
For simpler programming langauges there is always some form of 'printf',
so that you can print out a log of what happens and eventually deduce
where it goes wrong. This is tedious but you learn a lot along the way.
Newsgroups are for people with genuine problems or ideas, not people who
think that impatiently waiting for someone else to spend their own often
unpaid time over a weekend is more convenient.
Learn to debug.
Ed Willink
aslan wrote:
> still waiting for someone who can give me a hand :(
> anyone please?
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479208 is a reply to message #479139] Mon, 10 August 2009 05:53 Go to previous messageGo to next message
hallo Willink,
well first of all I have to thank you for your advice.
2nd of all I need to mention that if you can speed maybe your precious half minute on my question that you will find out the debuger won't give me any answer about that.
I did use the debuger and of course I can see in the Console that in the 1st transformation a 'Model' is transformated and in the other one there is none.
As an absolute beginner who is a newbie in QVTO even in programming and almost learning it by himself I do know that my question might be ridiculous. Before Sergey answered me the first question about how to declare Metamodel by 'platform:/...', I spent almost a whole day to try to fix it, cus I did read all the documents in the Internet that I can find and didn't find anything about that.
I spent the whole weekend on this but till now i still don't have any luck. I know that your guys time is precious so don't waste em on me if you don't want to. I am just hoping that maybe my 2nd question is as newbisch as the 1st one and some guy who just knows the answer can give me a hand.
Well, sry to the guys who think I am wasting your time or maybe even wasting the resource of the forum. Confused
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479497 is a reply to message #478676] Tue, 11 August 2009 06:47 Go to previous messageGo to next message
Hi aslan ,
Sergey
aslan wrote:
> hi Sergey,
> but it just won't go away... :(
> the error.
Error explains that collection of type Table can't be assigned to
reference with multiplicity 1. Note that operation on collection (that
is self.pointTo->map ...) results in collection of appropriate type.
You have to change last line to something like (in order to choose
single element from collection):
pointTo := self.pointTo->map class2table()->any(true);
> best wishes,
> aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479510 is a reply to message #478822] Tue, 11 August 2009 06:52 Go to previous messageGo to next message
Hi aslan ,
Sergey
> modeltype UML uses
> ' http://www.eclipse.org/qvt/1.0.0/Operational/examples/simple uml';
> modeltype RDB uses
> main() {
> name := self.name;
> main() {
> name := self.name;
This can appear because input model (xx:uml) contains no root elements
of uml::Klasse type.
Please, attach your metamodel Klasse.ecore and input model my.klasse so
I can figure out why this is happened.
> here:
> Thank you!
> regards,
> aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479671 is a reply to message #468446] Tue, 11 August 2009 17:51 Go to previous messageGo to next message
hi Sergey,
thank you very very much for your reply and your help. I really appreciate it.
You can see the Klasse.ecore here:
http://www.realsao.com/Klasse.eore.jpg
or download here: http://www.realsao.com/Klasse.ecore
And I just created my.klasse by choosing a Model Object 'Klasse' as the root and set the name to 'Kunden',nothing else. I thought this class 'Kunden' should be the root element of the input model,cuz that works in ATL which I have already done for this M2M with the same metamodels. or..there's something different in QVTO?
http://www.realsao.com/my.klasse.jpg
Thank you!
Best wishes,
Aslan
[Updated on: Tue, 11 August 2009 18:03] by Moderator
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479802 is a reply to message #479671] Wed, 12 August 2009 10:57 Go to previous messageGo to next message
Hi aslan ,
Since you gave link only to Klasse.ecore I've made minor changes to the
testing script:
--modeltype relational uses "platform:/resource/QVT/Relational.ecore";
transformation Klasse2Relational(in xx : uml, out uml);
main() {
mapping uml::Klasse::class2table() : uml::Klasse {
name := self.name;
It produces output model with one Klasse instance. So problem might be
in Relational.ecore model.
Sergey
aslan wrote:
> hi Sergey,
> appreciate it.
> 'Kunden' should be the root element of the input model, or?
> Thank you!
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479860 is a reply to message #479802] Wed, 12 August 2009 14:21 Go to previous messageGo to next message
It produces output model with one Klasse instance. So problem might be in Relational.ecore model.
Hi Sergey,
yea it might be. I checked the relational.ecore again (in fact i did this many times already Sad ) after saw your reply, but i really can't find any error in it....
http://www.realsao.com/Relational.ecore
http://www.realsao.com/relational.jpg
thank you for your help.
regards,
aslan
[Updated on: Wed, 12 August 2009 14:23] by Moderator
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479876 is a reply to message #479860] Wed, 12 August 2009 17:00 Go to previous messageGo to next message
Hi aslan ,
Checked with Relational.ecore. No problems in this case too. Exact one
Table was create in output .relational file:
<relational:Table xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:relational="http://relational/1.0"
xsi:schemaLocation="http://relational/1.0 Relational.ecore"/>
Sergey
aslan wrote:
> Quote:
> Hi Sergey,
> this many times already :( ) after saw your reply, but i really can't
> http://www.realsao.com/relational.ecore
> regards,
> aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #479896 is a reply to message #479876] Wed, 12 August 2009 19:00 Go to previous messageGo to next message
Sergey Boyko wrote on Wed, 12 August 2009 17:00
Sergey
hi Sergey,
that means it works just fine on your computer....
It is so strange, why it's just not O.K in my damn eclipse. OMG this issue is going to kill me Sad
I am running the modeling package of Eclipse from here:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/epp/downloads/release/galileo/R/eclipse-modeling-galileo- incubation-win32.zip
this is not suppost to be a problem right? I am really really confused.
anyway THANK YOU very much for everything you did.
regarts,
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #480017 is a reply to message #479896] Thu, 13 August 2009 09:35 Go to previous messageGo to next message
Hi aslan ,
Interesting that everything works for you in case predefined metamodels
(RDB, UML) is used.
It might be that the problem is somewhere in project or launch
configuration properties.
Could you please zip and post your qvto project (with all stuff you use
such as metamodels, script, launch configuration being used for script
execution) so I can figure out where the problem is.
Sergey
>> <?xml version="1.0" encoding="UTF-8"?>
>> Regards,
>> Sergey
> hi Sergey,
> issue is going to kill me :(
> regarts,
> aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #480078 is a reply to message #480017] Thu, 13 August 2009 13:21 Go to previous messageGo to next message
Hi Sergey,
you can download the file here (11.26M):
http://www.realsao.com/workspace+runtime.zip
there are 2 folders:
workspace
runtime-EclipseApplication
and here are the detailed steps that what I did from the beginning, so you can understand the files in the project:
1. open Eclipse, creat an Empty EMF object named "PA", creat the two Metamodels "Klasse.ecore" and "Relational.ecore", then creat the .genmodel for both of em. After that, "Generate All" for both .genmodel.
2. right click on the "PA" project and "run as Eclipse Application" to call the 2nd Instance of Eclipse. In there I created a new QTV project named "QVT". I used "open file" and "save as" to copy the 2 metamodels in the folder "transforms" under project "QVT". And then I created a new Example model of "Klasse": "System.Klasse" and of course the transformation script "Klasse2Relational.qvto" ( the simple one for test)
3. right click on "Klasse2Relational.qvto" and set the run configuration, choose "System.Klasse" as Input and set the name of output and click on "Run".
4.a .relational file came up, but it is empty.
5."my.simpleuml" "UML2RDB.qvto" are also in the transforms folder, they works just fine.
Today I even tested this on a mac laptop from beginning, and the output was also EMPTY.... Mad
ps. that would be nice if you could give me your email adress, if that's ok for you you can send a mail to mein: kytoz.w(at)gmail.com
Thank you very much!
regards,
aslan
[Updated on: Thu, 13 August 2009 13:24] by Moderator
Re: [QVTO]QVTO newbie needs some help here.. :( [message #480330 is a reply to message #468446] Sat, 15 August 2009 04:55 Go to previous messageGo to next message
hi Sergey,
do you think the problem might be the registry of metamodel? That means my two metamodels are not registered as Metamodels?
If that might b e a problem, how can i register my two Metamodels?
regards,
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #480333 is a reply to message #468446] Sat, 15 August 2009 05:10 Go to previous messageGo to next message
hi Sergey,
finally... the problem solved...
i just changed the metamodel declare line to:
modeltype klasse uses "http://klasse/1.0";
modeltype relational uses "http://relational/1.0";
then everything works fine. Very Happy
I want to say thank again, thank you very very much for your help in this topic, it really means a lot to me.
Thank you!
best wishes,
aslan
Re: [QVTO]QVTO newbie needs some help here.. :( [message #480338 is a reply to message #480333] Sat, 15 August 2009 07:50 Go to previous messageGo to next message
--------------080809060503050107090801
Hi aslan ,
Nice to here that it finally works!
I'd like to provide a few comments on content of "workspace+runtime.zip"
you posted.
The problem with your configuration was in 'System.klasse' file. It
references deployed 'Klasse.ecore' model while .qvto script references
workspace copy of 'Klasse.ecore'. I fixed that by opening workspace
'Klasse.ecore' in "QVTO" plug-in and generating new Klasse dynamic
instance ('Klasse.xmi' file). With the new Klasse instance script starts
to work.
Basically, there are two possibly scenarios how to develop and use
metamodels when referencing them from QVTo script.
First one is to create MM in given Eclipse platform (say developer
platform) and generate Java implementation code there. Then launch new
Eclipse Application (say runtime platform) and engineer QVTo script
here. In that case you'll reference deployed MM using their NsURI,
there's no need to copy MM to runtime platform.
Actually you used that scenario for "QVTO" project. But you copied MM to
"QVTO" plug-in that is redundant. Changing modeltype declarations to
was absolutely right. As I mentioned above your 'System.klasse' also
references deployed 'Klasse.ecore' model.
Some inconvenience here is that for every change in MM you should
regenerate implementation code for it and relaunch runtime platform so
that change becomes visible for QVTo script.
The other scenario is to use workspace MM (no need for new Eclipse
Application launching).
In such case you have to use metamodel mappings. This can be done from
project's context menu "Properties". There is "QVT Settings / Metamodel
Mappings" section. Press "Add", type Source model URI (usually same as
After creating MM mappings you can reference MM from QVTo script just
the same way as in first case (using NsURI), i.e.
and MM mappings would handle redirection from NsURI to workspace .ecore
model.
Also all changes made to workspace MM become immediately visible to QVTo
script.
You can migrate your "QVTO" plug-in to the second scenario by specifying
metamodel mappings for the plug-in. You can create them yourself or just
copy attached .urimap file to .settings folder in "QVTO" plug-in. After
that the plug-in can be used right in developer platform.
Don't forget to re-create 'System.klasse' dynamic instance.
Sergey
aslan wrote:
> hi Sergey,
> then everything works fine. :d
> Thank you!
> best wishes,
> aslan
Content-Type: text/xml;
name="org.eclipse.m2m.qvt.oml.mmodel.urimap"
Content-Disposition: inline;
filename="org.eclipse.m2m.qvt.oml.mmodel.urimap"
<?xml version="1.0" encoding="ASCII"?>
<uriMap:MappingContainer xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:uriMap="http:///www.eclipse.org/m2m/qvt/oml/MModelUriMap/1.0.0">
<mapping sourceURI="http://klasse/1.0" targetURI="platform:/resource/QVT/transforms/Klasse.ecore"/ >
<mapping sourceURI="http://relational/1.0" targetURI="platform:/resource/QVT/transforms/Relational.ecore "/>
</uriMap:MappingContainer>
--------------080809060503050107090801--
Re: [QVTO]QVTO newbie needs some help here.. :( [message #480577 is a reply to message #480338] Mon, 17 August 2009 13:08 Go to previous message
Hi Sergey,
Thank you very much for the explanation. They are really helpful for me.
I learn a lot in this topic with your help. Smile Thank you!
best wishes,
aslan
Previous Topic:km3 file
Next Topic:[QVTO] Trying to make logging work
Current Time: Tue Oct 21 19:45:46 EDT 2025
Powered by FUDForum. Page generated in 0.10908 seconds
