Home » Modeling » UML2 » UML2 Context Menu
Re: UML2 Context Menu [message #478597 is a reply to message #478596] |
Wed, 08 July 2009 07:12 |
user Messages: 296 Registered: July 2009 |
--------------060204090103000100020506
And here is the attachment and the code I use to initialize:
ArchiMateActionBarContributor contributor = new
ArchiMateActionBarContributor();
contributor.init((EditorActionBars) ((PartSite) workbenchPart.getSite())
.getActionBars());
user@domain.invalid wrote:
> Hi James,
> I tried to create a ActionBarContributor (see attachment) and hook it
> into the UML2 implementation. I initialize it in the 'selectionChanged'
> method of my plugin. But it all didn't work. Do you have some more
> concrete directions for me about how it should be done. Since I'm a
> newbie to UML2, feel free to give a low level explanation.
> Samuel
name="ArchiMateActionBarContributor.java"
Content-Disposition: inline;
filename="ArchiMateActionBarContributor.java"
package archimate.presentation;
import java.util.ArrayList;
import java.util.Collection;
import java.util.Collections;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.emf.common.notify.AdapterFactory;
import org.eclipse.emf.common.ui.viewer.IViewerProvider;
import org.eclipse.emf.common.util.Diagnostic;
import org.eclipse.emf.common.util.DiagnosticChain;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.util.Diagnostician;
import org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain;
import org.eclipse.emf.edit.domain.EditingDomain;
import org.eclipse.emf.edit.domain.IEditingDomainProvider;
import org.eclipse.emf.edit.provider.IItemLabelProvider;
import org.eclipse.emf.edit.ui.EMFEditUIPlugin;
import org.eclipse.emf.edit.ui.action.ControlAction;
import org.eclipse.emf.edit.ui.action.CreateChildAction;
import org.eclipse.emf.edit.ui.action.CreateSiblingAction;
import org.eclipse.emf.edit.ui.action.EditingDomainActionBarContrib utor;
import org.eclipse.emf.edit.ui.action.LoadResourceAction;
import org.eclipse.emf.edit.ui.action.ValidateAction;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.ActionContributionItem;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.action.IContributionItem;
import org.eclipse.jface.action.IContributionManager;
import org.eclipse.jface.action.IMenuListener;
import org.eclipse.jface.action.IMenuManager;
import org.eclipse.jface.action.MenuManager;
import org.eclipse.jface.action.Separator;
import org.eclipse.jface.action.SubContributionItem;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.jface.viewers.ISelectionProvider;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.PartInitException;
import org.eclipse.uml2.uml.Element;
import org.eclipse.uml2.uml.editor.UMLEditorPlugin;
import archimate.actions.GenerateCode;
public class ArchiMateActionBarContributor extends
EditingDomainActionBarContributor implements ISelectionChangedListener {
protected GenerateCode generateAction;
* This keeps track of the active editor. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected IEditorPart activeEditorPart;
* This keeps track of the current selection provider. <!-- begin-user-doc
* --> <!-- end-user-doc -->
* @generated
protected ISelectionProvider selectionProvider;
* This action opens the Properties view. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected IAction showPropertiesViewAction = new Action(
UMLEditorPlugin.INSTANCE
.getString("_UI_ShowPropertiesView_menu_item")) //$NON-NLS-1$
public void run() {
try {
getPage().showView("org.eclipse.ui.views.PropertySheet"); //$NON-NLS-1$
} catch (PartInitException exception) {
UMLEditorPlugin.INSTANCE.log(exception);
* This action refreshes the viewer of the current editor if the editor
* implements {@link org.eclipse.emf.common.ui.viewer.IViewerProvider}. <!--
* begin-user-doc --> <!-- end-user-doc -->
* @generated
protected IAction refreshViewerAction = new Action(UMLEditorPlugin.INSTANCE
.getString("_UI_RefreshViewer_menu_item")) //$NON-NLS-1$
public boolean isEnabled() {
return activeEditorPart instanceof IViewerProvider;
public void run() {
if (activeEditorPart instanceof IViewerProvider) {
Viewer viewer = ((IViewerProvider) activeEditorPart)
.getViewer();
if (viewer != null) {
viewer.refresh();
* This will contain one
* {@link org.eclipse.emf.edit.ui.action.CreateChildAction} corresponding to
* each descriptor generated for the current selection by the item provider.
* <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> createChildActions;
* This will contain a map of
* {@link org.eclipse.emf.edit.ui.action.CreateChildAction}s, keyed by
* sub-menu text. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Map<String, Collection<IAction>> createChildSubmenuActions;
* This is the menu manager into which menu contribution items should be
* added for CreateChild actions. <!-- begin-user-doc --> <!-- end-user-doc
* @generated
protected IMenuManager createChildMenuManager;
* {@link org.eclipse.emf.edit.ui.action.CreateSiblingAction} corresponding
* to each descriptor generated for the current selection by the item
* provider. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> createSiblingActions;
* {@link org.eclipse.emf.edit.ui.action.CreateSiblingAction}s, keyed by
* submenu text. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Map<String, Collection<IAction>> createSiblingSubmenuActions;
* added for CreateSibling actions. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected IMenuManager createSiblingMenuManager;
* This creates an instance of the contributor. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated NOT
public ArchiMateActionBarContributor() {
super(ADDITIONS_LAST_STYLE);
loadResourceAction = new LoadResourceAction();
generateAction = new GenerateCode();
controlAction = new ControlAction();
* This adds to the menu bar a menu and some separators for editor additions,
* as well as the sub-menus for object creation items.
* <!-- end-user-doc -->
* @generated
public void contributeToMenu(IMenuManager menuManager) {
super.contributeToMenu(menuManager);
System.out.println(UMLEditorPlugin.INSTANCE
.getString("_UI_UMLEditor_menu"));
IMenuManager submenuManager = new MenuManager(UMLEditorPlugin.INSTANCE
.getString("_UI_UMLEditor_menu"), "org.eclipse.uml2.umlMenuID"); //$NON-NLS-1$ //$NON-NLS-2$
menuManager.insertAfter("additions", submenuManager); //$NON-NLS-1$
submenuManager.add(new Separator("settings")); //$NON-NLS-1$
submenuManager.add(new Separator("actions")); //$NON-NLS-1$
submenuManager.add(new Separator("additions")); //$NON-NLS-1$
submenuManager.add(new Separator("additions-end")); //$NON-NLS-1$
// Prepare for CreateChild item addition or removal.
createChildMenuManager = new MenuManager(UMLEditorPlugin.INSTANCE
.getString("_UI_CreateChild_menu_item")); //$NON-NLS-1$
submenuManager.insertBefore("additions", createChildMenuManager); //$NON-NLS-1$
// Prepare for CreateSibling item addition or removal.
createSiblingMenuManager = new MenuManager(UMLEditorPlugin.INSTANCE
.getString("_UI_CreateSibling_menu_item")); //$NON-NLS-1$
submenuManager.insertBefore("additions", createSiblingMenuManager); //$NON-NLS-1$
// Force an update because Eclipse hides empty menus now.
submenuManager.addMenuListener(new IMenuListener() {
public void menuAboutToShow(IMenuManager menuManager) {
menuManager.updateAll(true);
addGlobalActions(submenuManager);
* When the active editor changes, this remembers the change and registers with it as a selection provider.
* @generated
public void setActiveEditor(IEditorPart part) {
super.setActiveEditor(part);
activeEditorPart = part;
// Switch to the new selection provider.
if (selectionProvider != null) {
selectionProvider.removeSelectionChangedListener(this);
if (part == null) {
selectionProvider = null;
} else {
selectionProvider = part.getSite().getSelectionProvider();
selectionProvider.addSelectionChangedListener(this);
// Fake a selection changed event to update the menus.
if (selectionProvider.getSelection() != null) {
selectionChanged(new SelectionChangedEvent(selectionProvider,
selectionProvider.getSelection()));
* This implements
* {@link org.eclipse.jface.viewers.ISelectionChangedListener}, handling
* {@link org.eclipse.jface.viewers.SelectionChangedEvent}s by querying for
* the children and siblings that can be added to the selected object and
* updating the menus accordingly. <!-- begin-user-doc --> <!-- end-user-doc
* @generated
public void selectionChanged(SelectionChangedEvent event) {
// Remove any menu items for old selection.
if (createChildMenuManager != null) {
depopulateManager(createChildMenuManager, createChildActions);
if (createSiblingMenuManager != null) {
depopulateManager(createSiblingMenuManager, createSiblingActions);
// Query the new selection for appropriate new child/sibling descriptors
Collection<?> newChildDescriptors = null;
Collection<?> newSiblingDescriptors = null;
ISelection selection = event.getSelection();
if (selection instanceof IStructuredSelection
&& ((IStructuredSelection) selection).size() == 1) {
Object object = ((IStructuredSelection) selection)
.getFirstElement();
EditingDomain domain = ((IEditingDomainProvider) activeEditorPart)
.getEditingDomain();
newChildDescriptors = domain.getNewChildDescriptors(object, null);
newSiblingDescriptors = domain.getNewChildDescriptors(null, object);
// Generate actions for selection; populate and redraw the menus.
createChildActions = generateCreateChildActions(newChildDescriptors,
selection);
createSiblingActions = generateCreateSiblingActions(
newSiblingDescriptors, selection);
populateManager(createChildMenuManager, createChildActions, null);
createChildMenuManager.update(true);
populateManager(createSiblingMenuManager, createSiblingActions,
null);
createSiblingMenuManager.update(true);
* This generates a {@link org.eclipse.emf.edit.ui.action.CreateChildAction}
* for each object in <code>descriptors</code>, and returns the collection
* of these actions. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> generateCreateChildActions(
Collection<?> descriptors, ISelection selection) {
Collection<IAction> actions = new ArrayList<IAction>();
if (descriptors != null) {
for (Object descriptor : descriptors) {
actions.add(new CreateChildAction(activeEditorPart, selection,
descriptor));
return actions;
* This generates a
* {@link org.eclipse.emf.edit.ui.action.CreateSiblingAction} for each
* object in <code>descriptors</code>, and returns the collection of these
* actions. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> generateCreateSiblingActions(
actions.add(new CreateSiblingAction(activeEditorPart,
selection, descriptor));
return actions;
* This populates the specified <code>manager</code> with
* {@link org.eclipse.jface.action.ActionContributionItem}s based on the
* {@link org.eclipse.jface.action.IAction}s contained in the
* <code>actions</code> collection, by inserting them before the specified
* contribution item <code>contributionID</code>. If
* <code>contributionID</code> is <code>null</code>, they are simply added.
* @generated
protected void populateManager(IContributionManager manager,
Collection<? extends IAction> actions, String contributionID) {
if (actions != null) {
for (IAction action : actions) {
if (contributionID != null) {
manager.insertBefore(contributionID, action);
} else {
manager.add(action);
* This removes from the specified <code>manager</code> all
* <code>actions</code> collection. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected void depopulateManager(IContributionManager manager,
Collection<? extends IAction> actions) {
IContributionItem[] items = manager.getItems();
for (int i = 0; i < items.length; i++) {
// Look into SubContributionItems
IContributionItem contributionItem = items[i];
while (contributionItem instanceof SubContributionItem) {
contributionItem = ((SubContributionItem) contributionItem)
.getInnerItem();
// Delete the ActionContributionItems with matching action.
if (contributionItem instanceof ActionContributionItem) {
IAction action = ((ActionContributionItem) contributionItem)
.getAction();
if (actions.contains(action)) {
manager.remove(contributionItem);
* This populates the pop-up menu before it appears. <!-- begin-user-doc -->
* @generated
super.menuAboutToShow(menuManager);
MenuManager submenuManager = null;
populateManager(submenuManager, createChildActions, null);
menuManager.insertBefore("edit", submenuManager); //$NON-NLS-1$
populateManager(submenuManager, createSiblingActions, null);
* This inserts global actions before the "additions-end" separator. <!--
* @generated
protected void addGlobalActions(IMenuManager menuManager) {
String key = (style & ADDITIONS_LAST_STYLE) == 0 ? "additions-end" : "additions";
if (controlAction != null)
menuManager.insertBefore(key, new ActionContributionItem(controlAction));
* This ensures that a delete action will clean up all references to deleted
* objects. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected boolean removeAllReferencesOnDelete() {
return true;
--------------060204090103000100020506--
Re: UML2 Context Menu [message #627778 is a reply to message #478596] |
.getActionBars());
> Hi James,
> Samuel
* end-user-doc -->
* @generated
* @generated
* end-user-doc -->
* @generated
public void run() {
try {
* @generated
public void run() {
.getViewer();
viewer.refresh();
* @generated
* @generated
* @generated
* @generated
* @generated
* end-user-doc -->
* @generated
* end-user-doc -->
* @generated NOT
* @generated
* @generated
if (part == null) {
} else {
* This implements
* @generated
.getFirstElement();
selection);
null);
* @generated
descriptor));
return actions;
* This generates a
* @generated
return actions;
* @generated
} else {
* end-user-doc -->
* @generated
.getInnerItem();
.getAction();
* @generated
* @generated
* @generated
return true;
Current Time: Thu Sep 26 22:52:15 GMT 2024
Powered by FUDForum. Page generated in 0.04913 seconds
