Home » Eclipse Projects » Equinox » How to add URLs to a plugin/bundle classloader
How to add URLs to a plugin/bundle classloader [message #47702] |
Thu, 28 April 2005 16:31 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Luis![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=lcrespom%40gmail.com) Messages: 20 Registered: July 2009 |
We have developed a plugin under Ecplise 2.1 which makes use of the internal
class org.eclipse.core.internal.plugins.PluginClassLoader.
This class is very useful since it has this method:
public void addURLs(URL[] codePath, URLContentFilter[] codeFilters, URL[]
resourcePath, URLContentFilter[] resourceFilters)
The reason for using this method is that we are forced to load a given
development-time class from our plugin classloader: this is because our
plugin instantiates a class and then makes a typecast in order to manipulate
it locally. The typecast will throw a java.lang.ClassCastException unless
the casting and cast classes come from the same classloader.
Because of the nature of the plugin, we cannot statically add the given
classes to the plugin's classpath, as the plugin should be able to load and
manipulate any class available at the workbench.
The problem is that this class has been removed from Eclipse 3 (I don't
complain, since the "internal" package name was a warning to that, but it
was the only way we knew how to do the above thing). I have been reviewing
the JavaDocs for the osgi and eclipse plugin infrastructure of Eclipse 3...
and found no replacement for such a method.
Is there some way we can do that with Ecplise 3? If not, what would be the
workaround for that?
Thank you very much for your help,
Luis.
Re: How to add URLs to a plugin/bundle classloader [message #47791 is a reply to message #47702] |
Fri, 29 April 2005 19:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ted A. Habeck![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=habeck%40us.ibm.com) Messages: 7 Registered: July 2009 |
Luis wrote:
> Hello,
> Luis.
Have you tried using an interface instead of a class to manipulate the
object? This would eleminate the class cast exception.
Ted :-)
Re: How to add URLs to a plugin/bundle classloader [message #47821 is a reply to message #47791] |
Mon, 02 May 2005 10:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I have been trying your suggestion and I still get a ClassCastException even
when casting to an interface.
After all, it makes sense since the interface I am casting to and the one
that implements the loaded class are the same one, but they come from
different classloaders.
Yes, the ClassCastException name here is a bit misleading, purists may
complain and say it should be called ClassOrInterfaceCastException ;-).
Luis.
"Ted Habeck" <habeck@us.ibm.com> wrote in message
news:d4u3pd$8kg$1@news.eclipse.org...
> Ted :-)
> Luis wrote:
> > Hello,
internal
URL[]
manipulate
unless
and
it
reviewing
3...
the
> > Luis.
> Ted :-)
Re: How to add URLs to a plugin/bundle classloader [message #47851 is a reply to message #47821] |
Thu, 05 May 2005 14:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Luis wrote:
> Regards,
> Luis.
>>Ted :-)
>>Luis wrote:
>>>Hello,
> internal
> URL[]
> manipulate
> unless
> and
> it
> reviewing
> 3...
> the
>>> Luis.
>>Ted :-)
Hi Louis,
Sorry, I should have been more specific. The solution outlined below
works:
In order to access the interface created by the second class loader, the
associated interface must be defined to both classloaders in the same
package.
The Object & Interface can be defined one time in the Demo project. Use
linked folder in the plug-in project, and then add the linked folder as
a source folder to your plug-in project. Finally, add the ouput folder
(/bin) as part of the build.properties (the linked folder /demo can not
be added since the builder does not support linked folders). In this
way, the code is maintained in one place, but compiled into both
projects without requiring the two projects to be dependant, or have
each other on their respective classpaths).
In the example shown below, an object "DemoExample" is instantiated by a
URL classloader through reflection, and its "getDemoObject" method
returns an IDemoObject interface. The attributes of the returned
interface are then presented in a dialogbox.
-------------- sample action -----------------------------------------
* The action has been activated. The argument of the method
represents the
* 'real' action sitting in the workbench UI.
* @see IWorkbenchWindowActionDelegate#run
public void run(IAction action)
URLClassLoader loader;
URL urls[] = new URL[1];
ArrayList urlList = new ArrayList();
try
urlList.add(new File("C:/jars/demo.jar").toURL());
} catch (MalformedURLException e)
e.printStackTrace();
urls = (URL[]) urlList.toArray(urls);
loader = new URLClassLoader(urls, this.getClass().getClassLoader());
try
// now load the DemoLoader through reflection.
Class c = loader.loadClass("org.eclipse.demo.objects.DemoExample");
Object demoExample = c.newInstance();
Method m = c.getDeclaredMethod("getDemoObject", null);
IDemoObject demoObjectInterface = (IDemoObject)
m.invoke(demoExample, null);
MessageDialog.openInformation(window.getShell()
, "MultiLoaderDemo Plug-in", "demoObjectInterface: Line:"+
demoObjectInterface.getLineNumber()+
" Message"+demoObjectInterface.getMessage()+"
Type:"+demoObjectInterface.getType()+" subType:" +
demoObjectInterface.getSubType());
} catch (Exception e)
-------------- DemoExample class---------
package org.eclipse.demo.objects;
import org.eclipse.demo.shared.interfaces.DemoObject;
import org.eclipse.demo.shared.interfaces.IDemoObject;
* DemoExample
public class DemoExample
public DemoExample() {
super();
public IDemoObject getDemoObject()
DemoObject demoObject = new DemoObject();
demoObject.setLineNumber(25);
demoObject.setMessage("Marker hover text goes here...");
demoObject.setSubType("example.subType");
demoObject.setType("demo.Type");
IDemoObject iDemoObject = demoObject;
return iDemoObject;
-------------- IDemoObject Interface -----------
package org.eclipse.demo.shared.interfaces;
* IDemoObject
public interface IDemoObject
public abstract int getLineNumber();
public abstract String getMessage();
public abstract String getSubType();
public abstract String getType();
-------------- DemoObject class -----------------------
* DemoObject
public class DemoObject implements IDemoObject
private String message;
private String type;
private String subType;
private int lineNumber;
public DemoObject() {
super();
// TODO Auto-generated constructor stub
public final int getLineNumber()
return lineNumber;
public final void setLineNumber(int lineNumber)
this.lineNumber = lineNumber;
public final String getMessage()
return message;
public final void setMessage(String message)
this.message = message;
public final String getSubType()
return subType;
public final void setSubType(String subType)
this.subType = subType;
public final String getType()
return type;
public final void setType(String type)
this.type = type;
Current Time: Sun Sep 01 09:49:07 GMT 2024
Powered by FUDForum. Page generated in 0.03074 seconds
