Home » Modeling » UML2 » Complete Project Development
Re: Complete Project Development [message #477883 is a reply to message #477874] |
Fri, 24 October 2008 14:12 |
Gonzalo Aguilar Delgado Messages: 14 Registered: July 2009 |
Hi Ed,
Thank you, I used it to generate a UML graph and generate code. And it
works! But I want to have a more complete solution.
El Thu, 23 Oct 2008 12:32:16 -0400, Ed Merks escribió:
> Gonzalo,
> It might even be the case that you can use EMF's Ecore importer to
> convert to Ecore:
> http://help.eclipse.org/ganymede/index.jsp?topic=/
org.eclipse.emf.doc/tutorials/clibmod/clibmod.html
> You could export that to UML, or you could just use Ecore Tools'
> graphical editor to edit Ecore directly just like a UML class diagram.
> Ecore's not as powerful as UML, but is a lot simpler, and you can
> generate code from it easily...
> Gonzalo Aguilar Delgado wrote:
>> Hi all!
>> I'm really new to Eclipse EMF and UML2. I did some projects with
>> documentation done with UML using Rational Rose some time ago.
>> But Know I find current Eclipse UML2 implementation not usable at all.
>> Do you think it's possible to manage a REAL java project with the
>> Eclipse UML2 tools? I mean do it from the begining to the end.
>> Thank you in advance.
> <!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> <html>
> <head>
> <meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
> </head>
> <body bgcolor="#ffffff" text="#000000"> Gonzalo,<br>
> <br>
> convert to Ecore:<br>
> <blockquote><a
> href="http://help.eclipse.org/ganymede/index.jsp?topic=/
org.eclipse.emf.doc/tutorials/clibmod/clibmod.html">http://
help.eclipse.org/ganymede/index.jsp?topic=/org.eclipse.emf.d oc/tutorials/
clibmod/clibmod.html</a><br>
> </blockquote>
> generate code from it easily...<br>
> <br>
> <br>
> <blockquote cite="mid:gdppbj$hq2$1@build.eclipse.org" type="cite">
> <pre wrap="">Hi all!
> </pre>
> </blockquote>
> </body>
> </html>
Re: Complete Project Development [message #477887 is a reply to message #477885] |
Fri, 24 October 2008 23:19 |
Great!
I tested it a little bit and looks promising...
Let's do a try
Thank you for the answer.
El Fri, 24 Oct 2008 11:30:36 -0400, Kenn Hussey escribió:
> The Papyrus component has yet to make its initial code contribution, but
> the plan is to provide a complely integrated environment for editing UML
> models, which should include things like reverse-engineering from Java.
> Sebastien, the component lead, could perhaps provide more details...
> Kenn
> "Gonzalo Aguilar Delgado" <gad@aguilardelgado.com> wrote in message
> news:gdsl99$mgk$3@build.eclipse.org...
>> Hi Kenn,
>> So do you mean that it's possible to do Papyrus to do all project
>> management and code generation?
>> I will take a look now.
>> Thank's!
>> El Thu, 23 Oct 2008 12:31:09 -0400, Kenn Hussey escribió:
>>> Mind you, the UML2 Tools component is currently focused more on
>>> automatic generation of the standard UML diagrams than a complete
>>> modeling environment that one would expect from a commercial tool.
>>> Note that the new Papyrus component (newsgroup copied) will provide
>>> something more along the lines of an end-user consumable environment
>>> for editing UML (and related) models...
>>> Kenn
>>> "James Bruck" <jbruck@ca.ibm.com> wrote in message
>>> news:gdq45j$i8f$1@build.eclipse.org...
>>>> Hi Gonzalo,
>>>> I'm not certain if your issue is with the UML2 project itself, which
>>>> really just defines the UML API, or with the UML2Tools project? You
>>>> may want to cross post this to the UML2Tools newsgroup.
>>>> There are many great tools built on top of the opensource UML2 API
>>>> that may be what you are looking for.
>>>> Keep in mind that UML2Tools project is just starting out and is also
>>>> a free tool.
>>>> The next version of RationalRose is IBM's RSA product. RSA far out
>>>> performs Rose in many ways. You may want to check that out.
>>>> Cheers,
>>>> - James.
>>>> news:gdppbj$hq2$1@build.eclipse.org...
>>>>> Hi all!
>>>>> all.
Re: Complete Project Development [message #627074 is a reply to message #477864] |
Thu, 23 October 2008 16:32 |
Ed Merks Messages: 33188 Registered: July 2009 |
--------------090004000506030304000100
Gonzalo,
convert to Ecore:
http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/clibmod/clibmod.html
> Hi all!
> Do you think it's possible to manage a REAL java project with the Eclipse
Content-Type: text/html; charset=UTF-8
<html>
<head>
</head>
Gonzalo,<br>
<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/clibmod/clibmod.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/clibmod/clibmod.html</a><br>
</blockquote>
<br>
<br>
</pre>
</blockquote>
</body>
</html>
--------------090004000506030304000100--
Ed Merks
Re: Complete Project Development [message #627083 is a reply to message #477874] |
Hi Ed,
> Gonzalo,
> convert to Ecore:
>> Hi all!
> <head>
> </head>
> <br>
> <blockquote><a
> </blockquote>
> <br>
> <br>
> </pre>
> </blockquote>
> </body>
> </html>
Re: Complete Project Development [message #627097 is a reply to message #477885] |
Great!
Let's do a try
> Kenn
>> Hi Kenn,
>> Thank's!
>>> Kenn
>>>> Hi Gonzalo,
>>>> a free tool.
>>>> Cheers,
>>>> - James.
>>>>> Hi all!
>>>>> all.
Current Time: Sat Jul 27 15:55:04 GMT 2024
Powered by FUDForum. Page generated in 0.07838 seconds
