Re: cdo and linux error [message #47187 is a reply to message #47155] |
Mon, 28 August 2006 16:53 |
Originally posted by: stepper.sympedia.de
Chris,
It looks as if you have missed to deploy EMF to your server instance.
The org.eclipse.emf.ecore plugin and its dependencies should be suffiecient.
Cheers
/Eike
Chris Lenz schrieb:
> Hi all
> My problem I have one eclipse in windows and one in linux
> I use the same launcher skript, but in linux I get the following error:
> [ERROR] at.ac.uibk.qe.squam.cdo.server.CDOServerPlugin: Startup error
> org.eclipse.net4j.spring.ContainerCreationException:
> org.springframework.beans.factory.BeanCreationException: Error creating
> bean with name 'serverCDOProtocol' defined in file
> [/usr/people/space/local/eclipse/workspace/at.ac.uibk.qe.squ am.cdo.server/META-INF/server.xml]:
> Cannot resolve reference to bean 'mapper' while setting bean property
> 'mapper'; nested exception is
> bean with name 'mapper' defined in file
> Instantiation of bean failed; nested exception is
> java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/EObject
> at
> org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:59)
> at
> org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:70)
> at
> at.ac.uibk.qe.squam.cdo.server.CDOServerPlugin.getServerCont ainer(CDOServerPlugin.java:96)
> at
> at.ac.uibk.qe.squam.cdo.server.CDOServerPlugin.doStart(CDOSe rverPlugin.java:56)
> at
> org.eclipse.net4j.util.eclipse.AbstractPlugin.start(Abstract Plugin.java:98)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:995)
> at java.security.AccessController.doPrivileged(Native Method)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:989)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:86)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:409)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:147)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at
> org.eclipse.net4j.util.eclipse.ExecutableElement.createExecu tableExtension(ExecutableElement.java:34)
> at
> at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin$Backend Element.createInitializer(ExampleServerPlugin.java:224)
> at
> at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin$Backend Element.initializeBackend(ExampleServerPlugin.java:204)
> at
> at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin.doStart (ExampleServerPlugin.java:93)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:74)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
> at org.eclipse.core.launcher.Main.run(Main.java:977)
> at org.eclipse.core.launcher.Main.main(Main.java:952)
> Caused by: org.springframework.beans.factory.BeanCreationException:
> Error creating bean with name 'serverCDOProtocol' defined in file
> at
> org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 190)
> at
> org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveValueIfNecessary(BeanDefinitionValueResolve r.java:106)
> at
> org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.applyPropertyValues(AbstractAutowireCapable BeanFactory.java:1046)
> at
> org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.populateBean(AbstractAutowireCapableBeanFac tory.java:857)
> at
> org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:378)
> at
> org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:233)
> at
> org.springframework.beans.factory.support.AbstractBeanFactor y.getBean(AbstractBeanFactory.java:145)
> at
> org.springframework.beans.factory.support.DefaultListableBea nFactory.getBeansOfType(DefaultListableBeanFactory.java:211)
> at
> org.springframework.context.support.AbstractApplicationConte xt.getBeansOfType(AbstractApplicationContext.java:596)
> at
> org.springframework.context.support.AbstractApplicationConte xt.registerListeners(AbstractApplicationContext.java:478)
> at
> org.springframework.context.support.AbstractApplicationConte xt.refresh(AbstractApplicationContext.java:310)
> at
> org.eclipse.net4j.spring.impl.ContainerImpl.<init>(ContainerImpl.java:55)
> ... 64 more
> Error creating bean with name 'mapper' defined in file
> at
> org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:403)
> at
> at
> at
> org.springframework.beans.factory.support.BeanDefinitionValu eResolver.resolveReference(BeanDefinitionValueResolver.java: 186)
> ... 75 more
> Caused by: java.lang.NoClassDefFoundError: org/eclipse/emf/ecore/EObject
> at java.lang.ClassLoader.defineClass1(Native Method)
> at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
> at
> at
> at
> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:388)
> at
> at
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
> at java.lang.Class.getDeclaredMethods0(Native Method)
> at java.lang.Class.privateGetDeclaredMethods(Class.java:2365)
> at java.lang.Class.getDeclaredMethods(Class.java:1763)
> at java.beans.Introspector$1.run(Introspector.java:1265)
> at java.beans.Introspector.getPublicDeclaredMethods(Introspecto r.java:1263)
> at java.beans.Introspector.getTargetMethodInfo(Introspector.jav a:1129)
> at java.beans.Introspector.getBeanInfo(Introspector.java:387)
> at java.beans.Introspector.getBeanInfo(Introspector.java:159)
> at
> org.springframework.beans.CachedIntrospectionResults.<init>(CachedIntrospectionResults.java:150)
> at
> org.springframework.beans.CachedIntrospectionResults.forClas s(CachedIntrospectionResults.java:87)
> at
> org.springframework.beans.BeanWrapperImpl.setIntrospectionCl ass(BeanWrapperImpl.java:237)
> at
> org.springframework.beans.BeanWrapperImpl.setWrappedInstance (BeanWrapperImpl.java:195)
> at
> org.springframework.beans.BeanWrapperImpl.setWrappedInstance (BeanWrapperImpl.java:179)
> at
> org.springframework.beans.BeanWrapperImpl.<init>(BeanWrapperImpl.java:132)
> at
> org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.instantiateBean(AbstractAutowireCapableBean Factory.java:487)
> at
> org.springframework.beans.factory.support.AbstractAutowireCa pableBeanFactory.createBean(AbstractAutowireCapableBeanFacto ry.java:362)
> ... 78 more
> Initializing container SQUAMcdo (net4j)
> [ERROR] at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin: Startup error
> at
> at
> at
> at
> at.ac.uibk.qe.squam.cdo.server.CDOServerBackendInitializer.i nitialize(CDOServerBackendInitializer.java:26)
> at
> at.ac.uibk.qe.squam.net4j.server.AbstractBackendInitializer. initializeContainer(AbstractBackendInitializer.java:34)
> at
> at.ac.uibk.qe.squam.net4j.server.ExampleServerPlugin$Backend Element.initializeBackend(ExampleServerPlugin.java:205)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 41 more
> at
> at
> at
> at
> ... 52 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
> SQUAM QE NET4J Server started!!!
> HIT ENTER FOR SHUTDOWN!!!
Re: cdo and linux error [message #47375 is a reply to message #47304] |
Tue, 29 August 2006 07:23 |
Chris,
The automatic unit tests run on linux:
http://emft.eclipse.org/technology/emft/cdo/downloads/drops/ 1.0.0/N200608281550/testresults/html/org.eclipse.emf.cdo.tes ts_linux.gtk.html
And they all pass. I kow of other users who use CDO on linux. After some initial issues with file system paths and line endings long ago they never complained about issues anymore.
First of all we should clarify why you have the following line in your stack trace:
That's why I asked if you are sure that you have EMF deployed at your server side. Can you please verify that again:
1) start the server instance with "-console" to have access to the OSGi console
2) wait until you see
osgi> Initializing container cdo (net4j)
3) type "ss" followed by Enter and verify that you see the following:
87 ACTIVE org.eclipse.emf.common_2.2.1.v200608100000
88 ACTIVE org.eclipse.emf.ecore_2.2.1.v200608100000
89 RESOLVED org.eclipse.emf.ecore.xmi_2.2.1.v200608100000
Cheers
/Eike
Chris Lenz schrieb:
> But I use the same configuration scripts in windows and in linux.
> I tried to start the Server example from cdo.
> Have anyone of you tried to run this on linux.
> Now I trie to setup a linux environment and test this.
> Chris
> Eike Stepper schrieb:
>> Chris,
>> suffiecient.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> Hi all
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 64 more
>>> at
>>> at
>>> at
>>> at
>>> ... 75 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 78 more
>>> error
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 41 more
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
Re: cdo and linux error [message #47714 is a reply to message #47440] |
Tue, 29 August 2006 16:48 |
Chris Lenz schrieb:
> I can test this tomorrow, but what can I do if I don't have deploed this.
Then you need to copy the three jars into the plugins folder of the server and check that they are at least RESOLVED.
Cheers
/Eike
>> Chris,
>> stack trace:
>> console
>> Cheers
>> /Eike
>>> Chris
>>>> Chris,
>>>> suffiecient.
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> Hi all
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 64 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 75 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 78 more
>>>>> error
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 41 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 52 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 55 more
Re: cdo and linux error [message #47812 is a reply to message #47781] |
Tue, 29 August 2006 17:25 |
Chris Lenz schrieb:
> OK, but I start this out of eclipse shouldn't that do eclipse for me?
Yes, if you use a launch configuration from your IDE then you can click the "Add Required Plug-ins" button or "Validate Plug-in Set".
> ok I trie, thanx for help, Chris
If the problem persists, please send me the whole console log after you have set the defult log level to debug in log4j.xml (org.eclipse.net4j.util plugin).
Cheers
/Eike
Re: cdo and linux error [message #586535 is a reply to message #47155] |
Chris,
Cheers
/Eike
Chris Lenz schrieb:
> Hi all
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 64 more
> at
> at
> at
> at
> ... 75 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 78 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 41 more
> at
> at
> at
> at
> ... 52 more
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 55 more
Cheers
/Eike
http://www.esc-net.de
Re: cdo and linux error [message #586670 is a reply to message #47304] |
Chris,
Cheers
/Eike
> Chris
>> Chris,
>> suffiecient.
>> Cheers
>> /Eike
>> Chris Lenz schrieb:
>>> Hi all
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 64 more
>>> at
>>> at
>>> at
>>> at
>>> ... 75 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 78 more
>>> error
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 41 more
>>> at
>>> at
>>> at
>>> at
>>> ... 52 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 55 more
Cheers
/Eike
Re: cdo and linux error [message #586810 is a reply to message #47440] |
Cheers
/Eike
>> Chris,
>> stack trace:
>> console
>> Cheers
>> /Eike
>>> Chris
>>>> Chris,
>>>> suffiecient.
>>>> Cheers
>>>> /Eike
>>>> Chris Lenz schrieb:
>>>>> Hi all
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 64 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 75 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 78 more
>>>>> error
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 41 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 52 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 55 more
Cheers
/Eike
FUDForum. Page generated in 0.05811 seconds
