Home » Language IDEs » PHP Development Tools (PDT) » XDebug can't find my sources for remote launch
XDebug can't find my sources for remote launch [message #4015] Thu, 08 March 2007 12:18 Go to next message
Originally posted by: mark.howellsfamily.org.uk
When I initiate a remote launch of my scripts the XDebug plugin reports
that it can't find my source.
I have a remote Linux/Apache server. The DocumentRoot is (and has to
be) set to /var/www/localhost/htdocs.
Here's the structure of my Eclipse Project
GiftCertificates [GiftCertificates/trunk]
TestHarness
TestFactory.php <--- This is what I need to execute & break at
VoucherFactory
VoucherFactory.php <--- This is included by TestFactory
The project is copied to the server as
"/var/www/localhost/htdocs/GiftCertificates"
leading to a launch URL of
"http://myserver/GiftCertificates/TestFactory.php"
I've tried just about every setting permutation for Context Root and
script I can think of but I always get a message
"Source not found for
var/www/localhost/htdocs/GiftCertificates/TestHarness/TestFa ctory.php.{main}
: lineno 2. Please add the file to the Project or Include Path in
project, or structure the files in Project/Include Path to more closely
resemble the layout of the files on the server." when I launch
I can debug my variables and step etc so it is debugging, but without
source view it's of limited value... :(
Can you suggest what I should put in the Debug Settings for this
project? If it's relevant, whatever I enter into the dialog leaves an
error message in the top of the dialog "File / Project does not exist"
BTW I'm using the PDT (RC2) "All in one" with XDebug support v0.1.3
Mark
Re: XDebug can't find my sources for remote launch [message #4162 is a reply to message #4015] Thu, 08 March 2007 14:02 Go to previous messageGo to next message
D Kelsey is currently offline D KelseyFriend
Hi Mark. The Xdebug implementation currently requires you to have your document
root point to your workspace, otherwise it cannot locate the source file (see enclosed
PDF user guide)
There is a "Path Mapper" version based on 0.13 available as well which was contributed
by someone else which you could try.
Dave Kelsey
> TestHarness
> VoucherFactory
> Thanks
> Mark
Re: XDebug can't find my sources for remote launch [message #4302 is a reply to message #4162] Thu, 08 March 2007 14:33 Go to previous messageGo to next message
Hi Dave,
> document
> (see enclosed
> PDF user guide)
I saw that in the PDF but didnt realize that it was an absolute
requirement. Just to confirm then, this means that one cannot debug a
remote PHP script using this version?
> was contributed
I saw this in the bugzilla but didn't fully appreciate what it was. I'll
give this a shot and report back..
Cheers
Mark
> Dave Kelsey
>> TestHarness
>> VoucherFactory
>> closely resemble the layout of the files on the server." when I launch
>> Thanks
>> Mark
Re: XDebug can't find my sources for remote launch [message #4441 is a reply to message #4162] Thu, 08 March 2007 15:02 Go to previous messageGo to next message
> was contributed
Hmmm, I extracted the Path Mapper version and it appears to work the
same as before. However I suspect it's not installed properly as I don't
see the mapping dialog described and there's no XDebug feature to emable
(as described). There's a jar file in the features folder, do I just
copy that to eclipse\features and run "eclipse -clean"? All else in
that folder are folders with files...
Cheers
Mark
Re: XDebug can't find my sources for remote launch [message #4511 is a reply to message #4441] Fri, 09 March 2007 07:59 Go to previous messageGo to next message
Originally posted by: johan.bobsworld.be
Mark
You should have a entry when you go to window -> preferences -> PHP.
There should be the option XDebug rewrite where you can enter the
rewrite rules.
If you don't have that, check if the plugin is enabled.
Johan Vandeweerd
Mark Howells wrote:
>> was contributed
> Cheers
> Mark
Re: XDebug can't find my sources for remote launch [message #4580 is a reply to message #4511] Fri, 09 March 2007 09:06 Go to previous messageGo to next message
Johan,
> rewrite rules.
Thanks for that, I had misread the docs and thought the rewrite rules
were in the Debug Launch config. dialog. I now have source level
debugging working so I'll see how I get on.
I feel strongly that this project needs a fully Opensource debugging
system so if there's anything I can do to help...
Mark
Re: XDebug can't find my sources for remote launch [message #4648 is a reply to message #4580] Fri, 09 March 2007 11:19 Go to previous messageGo to next message
Johan,
I can single step my code and evaluate variables, but my breakpoints are
being ignored. Do you have breakpoints working using XDebug with filemapper?
Mark
Re: XDebug can't find my sources for remote launch [message #4716 is a reply to message #4580] Fri, 09 March 2007 12:22 Go to previous messageGo to next message
I am hoping that once PDT 0.7 is complete, my contribution will be accepted
and included in the PDT project.
You can vote on the bugzilla page to show your interest in the XDebug support
as well as continue to discuss it on the forum.
I fully agree that PDT should support an open source debugger as one is
available.
Dave Kelsey
Mark Howells wrote:
> Johan,
>> rewrite rules.
> Mark
Re: XDebug can't find my sources for remote launch [message #4785 is a reply to message #4648] Fri, 09 March 2007 12:23 Go to previous messageGo to next message
Mark
In my configuration I have no problems with the breakpoints. If I set a
breakpoint in the middle of a script or in an include file, he stops at
the breakpoint. I don't use break at first line.
My breakpoints were also ignored in a previous version of PDT. Currently
I'm using PDT Feature 0.70 20070130 and the xdebug feature 1.3 logik
(file mapper version).
Hope this helps.
Johan Vandeweerd
> Johan,
> filemapper?
> Mark
Re: XDebug can't find my sources for remote launch [message #4854 is a reply to message #4785] Fri, 09 March 2007 13:06 Go to previous messageGo to next message
Johan Vandeweerd wrote:
> Mark
I'm using the same s/w then. Perhaps it's to do with the way I have my
mapping set up. I have
Remote Server: Document Root = /var/www/localhost/htdocs
Workspace: C:\Documents and Settings\mark\workspace
Project: C:\Documents and Settings\mark\workspace\GiftCertificates
Launch Config
Script:/GiftCertificates/TestHarness/TestFactory.php
Server:
Context Root:GiftCertificates
Launch URL: http://drno/GiftCertificates/TestHarness/testcerts.php
FileMapping
From - c:/Documents and Settings/mark/workspace/GiftCertificates
To - var/www/localhost/htdocs/GiftCertificates
Breaking on first line works perfectly, and the correct files are opened
as I single step through the app. It's just that breakpoints are
ignored... :(
Mark
Re: XDebug can't find my sources for remote launch [message #4919 is a reply to message #4716] Fri, 09 March 2007 13:08 Go to previous messageGo to next message
Hi Dave,
> support
Will do.
> available.
Thanks for your great work so far.
Cheers
Mark
Re: XDebug can't find my sources for remote launch [message #4987 is a reply to message #4716] Fri, 09 March 2007 15:40 Go to previous messageGo to next message
Patrick Mueller is currently offline Patrick MuellerFriend
> support
And it's has the most votes right now in the PDT:
http://tinyurl.com/2xr3xo
Patrick_Mueller@us.ibm.com / pmuellr@yahoo.com
IBM Research Triangle Park
Re: XDebug can't find my sources for remote launch [message #5125 is a reply to message #4854] Fri, 09 March 2007 23:20 Go to previous messageGo to next message
Hello Mark
The problem is probably in your mapping. I tried a little test and it
seems that the file mapper can handle spaces in the paths very well.
Can you try to use another path without spaces in it.
Regard
Johan Vandeweerd
>> Mark
>> a breakpoint in the middle of a script or in an include file, he stops
>> at the breakpoint. I don't use break at first line.
>> Currently I'm using PDT Feature 0.70 20070130 and the xdebug feature
>> 1.3 logik (file mapper version).
> Launch Config
> Server:
> FileMapping
> ignored... :(
> Mark
Re: XDebug can't find my sources for remote launch [message #5262 is a reply to message #5125] Mon, 12 March 2007 11:19 Go to previous messageGo to next message
> Hello Mark
Still no success... :(
I now have moved my workspace to c:\tech\workspace and deleted/replaced
my breakpoint but it's still ignored....
Workspace: C:tech\workspace
Project: C:\tech\workspace\GiftCertificates
Launch Config
Server:
FileMapping
From - c:/tech/workspace/GiftCertificates
I have a breakpoint set on line 4 of testcerts.php. Source mapping works
fine, as does break on first line. I've also tried including the
'TestHarness' subdir in the mapping but still no changes. Is there some
logging I can enable in the filemapper? Alternatively, how
straightforward is it to debug the filemapper code, I'm OK with working
with Java, but have never had to create anything that links to Eclipse.
Cheers
Mark
Re: XDebug can't find my sources for remote launch [SOLVLED] [message #6093 is a reply to message #4854] Wed, 14 March 2007 12:30 Go to previous messageGo to next message
>> Mark
> Launch Config
> Server:
> FileMapping
> To - /var/www/localhost/htdocs/GiftCertificates
> ignored... :(
The filemapper is very sensitive regarding case and spaces etc. The
above example was fixed using the settings
From - C:/tech/workspace/GiftCertificates
i.e. 'c:' -> 'C:' and the removal of any spaces in the pathnames (both
were required)...
So, I am now happily debugging my remote Linux box via eclipse on my
Windoze PC :)
Thanks to all for the help.
Mark
Re: XDebug can't find my sources for remote launch [message #9012 is a reply to message #4987] Fri, 23 March 2007 12:47 Go to previous message
yay!
Let's see, i wonder why - oh, maybe because XDebug protocol is open and the
zend debugger isn't perhaps?
Just my two cent's, I'm an a funny mood today. :)
Dom
Previous Topic:XDebug with path mapper problem
Next Topic:Zend platform debugging
Current Time: Wed Nov 06 03:21:59 GMT 2024
Powered by FUDForum. Page generated in 0.04206 seconds
