Home » Archived » DSDP - Device Debugging » Re: DSDP/DSF build problems
Re: DSDP/DSF build problems [message #470083] Thu, 10 January 2008 11:32 Go to next message
The classpath that PDE has for your DSF plugins has might be
broken. Try "PDE Tools > Update classpath". Clean all projects
(without rebuild), close project, reopen project might also
help. You do have a Java 1.5 runtime installed that Eclipse can use?
(Window > Preferences > Java > Installed JREs)
AbstractUIPlugin should definitely be found, so somehow your
PDE / Classpath seems to be broken. I've seen that before on other
plugins, but never quite found what's causing this or how to workaround
it exactly... after some time of trying it eventually worked again.
Also copying the dsdp.dd newsgroup and the dsdp-dd-dev list.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Jesper Eskilson wrote:
> Hi all,
> I'm trying to checkout the DSDP/DSF projects in order to study the
> implementations, but I get loads of build errors; things like
> "AbstractUIPlugin cannot be resolved".
>> Severity and Description Path Resource Location Creation
>> Time Id
>> org.eclipse.dd.dsf.mi.ui/src/org/eclipse/dd/dsf/mi/ui
>> DsfMIUIPlugin.java line 75 1199895367690 674
> I've got a couple of other plugins which work fine, so my Eclipse
> installation is not totally broken.
> Can anybody give a hint about where I should start looking?
> /Jesper
Re: DSDP/DSF build problems [message #470092 is a reply to message #470083] Thu, 10 January 2008 15:23 Go to previous messageGo to next message
> help.
No effect.
Yes. Also, the problem appears on both my XP workstation and on my Vista
laptop.
Weird. Well, at the moment I'm just reading code. Lets hope by the time
I need to start hacking things will have fixed themselves. ;-)
/Jesper
Re: DSDP/DSF build problems [message #470094 is a reply to message #470092] Thu, 10 January 2008 16:32 Go to previous message
Hi Jesper,
One thing to keep in mind, DSF HEAD is now dependent on Eclipse 3.4 M4
and CDT 5.0 M4.
-Pawel
>> help.
> No effect.
>> You do have a Java 1.5 runtime installed that Eclipse can use? (Window
> laptop.
>> workaround it exactly... after some time of trying it eventually
>> worked again.
> /Jesper
Re: DSDP/DSF build problems [message #590325 is a reply to message #470083] Thu, 10 January 2008 15:23 Go to previous message
> help.
No effect.
laptop.
/Jesper
Re: DSDP/DSF build problems [message #590337 is a reply to message #470092] Thu, 10 January 2008 16:32 Go to previous message
Hi Jesper,
and CDT 5.0 M4.
-Pawel
>> help.
> No effect.
> laptop.
>> worked again.
> /Jesper
Previous Topic:Re: DSDP/DSF build problems
Next Topic:Disassembly editor
Current Time: Wed Apr 16 12:14:25 EDT 2025
Powered by FUDForum. Page generated in 0.03012 seconds
