Home » Eclipse Projects » Standard Widget Toolkit (SWT) » max value
max value [message #466168] Wed, 04 January 2006 05:30 Go to next message
Originally posted by: ingo.siebertNOSPAM.cas.de
i use a table and i wanted to know, if a user drags the bar from the
vertical scrollbar to the maximum value.
The maximum value is never reached, so i can't do a check like
int scrollBarValue = scrollBar.getSelection();
int maxScrollBarValue = scrollBar.getMaximum();
if (scrollBarValue >= maxScrollBarValue) .... // fails anytime
I think that's the same in Swing and i hoped it doesn't exist in SWT.
Any idea how to solve this problem?
Ingo
Re: max value [message #466195 is a reply to message #466168] Wed, 04 January 2006 14:15 Go to previous messageGo to next message
Possible hack:
Point p = ...; // an arbitrary point just up from the bottom of the table
TableItem lastItem = ...; // the last item added to the table
if (table.getItem(p).equals(lastItem))
    System.out.println("Scrolled to the bottom of the table");
You would have to set up a daemon thread which then put a call in to Display#asyncExec(Runnable) every few seconds (depending on how precise you need your timing to be) and pass a Runnable object which could call similar code to the above.
As you can probably see, this hack isn't a terribly good idea, but I honestly don't know enough about scrolling to give you another alternative. Anyone else want to bail me out? :-)
Re: max value [message #466252 is a reply to message #466168] Thu, 05 January 2006 09:24 Go to previous messageGo to next message
Composite c = new Composite(shell, SWT.V_SCROLL | SWT.H_SCROLL);
final ScrollBar bar = c.getVerticalBar();
bar.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
int scrollBarValue = bar.getSelection();
int maxScrollBarValue = bar.getMaximum();
int thumb = bar.getThumb();
if (scrollBarValue + thumb == maxScrollBarValue) {
System.out.println("Max reached");
"Ingo Siebert" <ingo.siebertNOSPAM@cas.de> wrote in message
news:dpg87i$4pq$1@utils.eclipse.org...
> I think that's the same in Swing and i hoped it doesn't exist in SWT. Any
> Ingo
Re: max value [message #466267 is a reply to message #466252] Thu, 05 January 2006 11:13 Go to previous message
Thank you both.
It looks very promising and i will try i soon.
Ingo
>>Hi,
>>Thanks,
>>Ingo
Previous Topic:Adding an Action to the Navigator View
Next Topic:adding content to a table if user scrolls down
Current Time: Wed Nov 05 22:04:15 EST 2025
Powered by FUDForum. Page generated in 0.08488 seconds
