Home » Eclipse Projects » Standard Widget Toolkit (SWT) » adding columns to a table in a view at runtime
adding columns to a table in a view at runtime [message #466059] Fri, 30 December 2005 04:19 Go to next message
Originally posted by: ayesha.ltp.soft.net
I would like to know if there is a way to add a tablecolumn dynamically
at runtime after the view is opened. The table columns should be added
whenever a new column is added to the data model. I tried adding a table
column and invoked a pack on the table, but it didnt work.
Is there a way to do it?
Ayesha
Re: adding columns to a table in a view at runtime [message #466145 is a reply to message #466059] Tue, 03 January 2006 14:31 Go to previous message
Create a table column and set the width of the table column (e.g.
TableColumn.setWidth()) . You could also use TableColumn.pack() but this
will only work after you have set some data for that column (e.g.
TableColumn.setText() or TableItem.setText(int, String)). Packing the Table
itself will not resize the columns.
"Ayesha" <ayesha@ltp.soft.net> wrote in message
news:dp2tip$kdn$1@utils.eclipse.org...
> Ayesha
Previous Topic:Problem executing SWT Snippet 212, v1.5
Next Topic:dispose
Current Time: Sat Nov 01 22:45:15 EDT 2025
Powered by FUDForum. Page generated in 0.03670 seconds
