Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display [message #465546] Thu, 15 December 2005 01:56 Go to next message
Originally posted by: invalid.invalid.invalid
I have a problem with starting my SWT application from a jar file
under Windows XP. In Eclipse everything works fine. But when I
run the jar file I get this error:
I have copied swt.jar and swt-win32-3064.dll to the jars
directory. And I have added the swt.jar to the manifest file.
I tried this when I started with my project and it worked. Now I
get the above error.
Nick
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465578 is a reply to message #465546] Thu, 15 December 2005 14:25 Go to previous messageGo to next message
Did you point to the directory where you moved the dll in your
java.library.path command line option?
Nicola-Patric Wegner wrote:
> Hello,
> Nick
Rich Kulp
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465582 is a reply to message #465578] Thu, 15 December 2005 15:05 Go to previous messageGo to next message
Yes, I started with
java -Djava.lirary.path="D:\path_to_dll_and_jars" -jar myjar.jar
but I get the same error as before.
I think it should even work without the java.library.path option
because the dll and all the jars are in the same directory.
Any more ideas?
>> Hello,
>> Thanks,
>> Nick
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465584 is a reply to message #465582] Thu, 15 December 2005 15:29 Go to previous messageGo to next message
Stefan Langer is currently offline Stefan LangerFriend
> Yes, I started with
Hope this is just a cut & paste error but you spelled -Djava.lirary not
-Djava.library
> Any more ideas?
>>>Hello,
>>>Thanks,
>>>Nick
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465588 is a reply to message #465584] Thu, 15 December 2005 15:41 Go to previous messageGo to next message
>> Yes, I started with
> -Djava.library
Yes, it is just a cut&paste error. It was on two lines. Sorry.
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465591 is a reply to message #465588] Thu, 15 December 2005 16:25 Go to previous messageGo to next message
Have you tried starting your application using jar in the classpath and
specifiing the startup class manually? Do you get the same result?
Stefan
>>>Yes, I started with
>>-Djava.library
Re: Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Dis [message #465609 is a reply to message #465591] Thu, 15 December 2005 19:57 Go to previous message
Thank you, I have found the error. The manifest file was wrong.
I separated the jars with a ',' and not with a space.
With "Class-Path: swt.jar, jdom.jar" only jdom.jar was used. With
"Class-Path: swt.jar jdom.jar" everything works fine.
Thanks again,
Nick
> Regards
> Stefan
>>>>Yes, I started with
>>>-Djava.library
Previous Topic:SWT button
Next Topic:eclipse crash under linux ppc
Current Time: Thu Dec 26 10:01:41 GMT 2024
Powered by FUDForum. Page generated in 0.04599 seconds
