Home » Eclipse Projects » Rich Client Platform (RCP) » Using env var for default workspace in eclipse.ini
Using env var for default workspace in eclipse.ini [message #465233] Mon, 26 March 2007 11:15 Go to next message
In my Eclipse 3.2.1 RCP app I'm currently specifying the default workspace using the following entry in my eclipse.ini for the RCP app.
-data H:/myApp
I want to use an environment variable called $HOME instead.
ie.
-data ${HOME}/myApp
I'm on Windows. How do I specify the environment variable? Is this possible?
I tried ${app.home}, ${home}, ${home}, $HOME and nothing worked.
Re: Using env var for default workspace in eclipse.ini [message #465241 is a reply to message #465233] Mon, 26 March 2007 12:43 Go to previous message
You use %% for vars on windows. So, if there's a var called HOME set (and it's not guaranteed there will be, by the way) then it would be referenced as %HOME%.
Alex.
Previous Topic:IWorkbenchPage.isPartVisible() doesn't return true for a visible part
Next Topic:Export Feature produces empty bin directory
Current Time: Sat Nov 01 13:19:53 EDT 2025
Powered by FUDForum. Page generated in 0.42953 seconds
