Home » Eclipse Projects » Rich Client Platform (RCP) » deprecated key binding
deprecated key binding [message #464812] Thu, 15 March 2007 12:50 Go to next message
Originally posted by: m.hybler.aegis.cz
This is the part of my plugin.xml
<extension
point="org.eclipse.ui.commands">
<command
id="cz.aegis.cms.viewer.deleteCommand"
name="deleteCommand"/>
<keyBinding
command="cz.aegis.cms.viewer.deleteCommand"
configuration="cz.aegis.cms.viewer.keyConfiguration"
contextId="org.eclipse.ui.globalScope"
string="Ctrl+Shift+D"/>
<keyConfiguration
id="cz.aegis.cms.viewer.keyConfiguration"
name="keyConfiguration"
parent="org.eclipse.ui.defaultAcceleratorConfiguration"/>
</extension>
But my eclipse says that keyconfiguration and keybinding is deprecated.I
can find other way to set keybinding for my action. In eclipse FAQ it is
described by this way. Everything goes right but is it the right way?
Should anyone help me?
Tahnks a lot Michal
Re: deprecated key binding [message #464879 is a reply to message #464812] Fri, 16 March 2007 16:18 Go to previous message
> <extension
> <command
> <keyBinding
> <keyConfiguration
> </extension>
> Tahnks a lot Michal
Yes, look at the 'org.eclipse.ui.bindings' extension. This is what I
use (including the 'commands' extention...):
<extension
<command
categoryId="com.fred.category.commands"
description="Add client"
id="com.fred.clientMgr.addClientCmd"
name="Add client"/>
<extension
point="org.eclipse.ui.bindings">
<key
commandId="com.fred.clientMgr.addClientCmd"
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
sequence="M1+C"/>
</extension>
works like a charm.
Previous Topic:Icon for submenu
Next Topic:crash using SWT_AWT with JDK 1.4
Current Time: Sat Nov 08 22:19:53 EST 2025
Powered by FUDForum. Page generated in 0.02794 seconds
