Home » Eclipse Projects » Standard Widget Toolkit (SWT) » PNG icons in ToolBars
PNG icons in ToolBars [message #464288] Sun, 20 November 2005 18:24 Go to next message
Originally posted by: ng.felicis.org
Hello together,
using PNG icons with transparency for the ToolBar looks pretty well on GTK,
but does not look well on Windows. I found the main bug entry in the
bugzilla system, but I couldn't clearly figure out if the problem has been
completely resolved yet. I made screenshots of my environments:
Linux with GTK 2: http://www.felicis.org/screenshot_toolbar_gtk.png
Windows XP: http://www.felicis.org/screenshot_toolbar_windows.png
One of the PNG files: http://www.felicis.org/zoomXPlus-22.png
Currently I load an image like that:
toolItem = new ToolItem(this.toolBar, SWT.PUSH);
ImageData imageData = new ImageData(filename);
Image image = new Image(SWTGeoGUI.iDisplay, imageData);
toolItem.setImage(image);
Is there a way I can have the ToolBar icons look as smooth on Windows as on
GTK without converting the PNGs to GIFs?
Martin
Re: PNG icons in ToolBars [message #464357 is a reply to message #464288] Tue, 22 November 2005 01:51 Go to previous messageGo to next message
Daniel Spiewak is currently offline Daniel SpiewakFriend
Use SWT 3.1
If you are already, then file a bug report.
Re: PNG icons in ToolBars [message #464383 is a reply to message #464357] Tue, 22 November 2005 14:08 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
Support for PNG on Windows for all widgets was added in 3.1 RC3. If you are
using this release or a later release and are still seeing a problem, please
report a bug against Platform SWT.
"Daniel Spiewak" <djspiewak@gmail.com> wrote in message
news:20832402.1132624348379.JavaMail.root@cp1.javalobby.org...
> Use SWT 3.1
Re: PNG icons in ToolBars [message #464407 is a reply to message #464383] Wed, 23 November 2005 06:43 Go to previous messageGo to next message
> are using this release or a later release and are still seeing a problem,
> please report a bug against Platform SWT.
I am using 3.1. Did you already try to use the provided PNG above in a
ToolBar? What are your results on Windows?
Martin
Re: PNG icons in ToolBars [message #464505 is a reply to message #464383] Wed, 23 November 2005 15:36 Go to previous messageGo to next message
Veronika-
What about Label(s)? I've had quite a bit of trouble displaying alpha blending in an image Label. It doesn't bother me enough to file a bug about it since I always use Canvas anyway. But is Label actually supposed to have PNG support?
Re: PNG icons in ToolBars [message #464508 is a reply to message #464407] Wed, 23 November 2005 15:38 Go to previous messageGo to next message
In my experience, the only problems I've had with PNGs in Windows toolbars in SWT 3.1 is in some of the early milestones (pre M7 I believe). You might want to check to make sure you're not using one of those. (the PNGs themselves would make no difference).
I think at this point, you might want to file a bug report. Since Veronika has posted on this thread, then she's at least aware of the issue now. Your report should be addressed fairly quickly then. I'm rather curious as to how this turns out. If you could post the link to the bug report here, I would appreciate it.
Re: PNG icons in ToolBars [message #464522 is a reply to message #464407] Wed, 23 November 2005 18:02 Go to previous messageGo to next message
Used your PNG on Windows.
With a manifest on Windows XP it looks great. Without the manifest I see
what you are seeing.
Try adding the manifest:
http://eclipse.org/swt/faq.php#xpthemes
"Martin R
Re: PNG icons in ToolBars [message #464524 is a reply to message #464522] Wed, 23 November 2005 18:38 Go to previous messageGo to next message
Hi Veronika,
thanks for that hint. You are right, it works with the manifest as it
should. Unfortunately you were a little too late for my bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=117764 ;-)
I thought the issue with the manifest has been already resolved by SWT 3.1,
but I guess that was some misunderstanding.
Nevertheless there are two problems still remaining. What happens on older
Windows systems (I don't have any here at the moment ...)? Further more, it
is unfortunate to "install" another file into a program's directory that
only the Administrator should be allowed to have write access to.
Is there any chance this problem may be solved in coming releases? Is the
only workaround to use PNGs without alpha channels or GIFs instead?
Martin
Re: PNG icons in ToolBars [message #464531 is a reply to message #464505] Wed, 23 November 2005 21:40 Go to previous messageGo to next message
news:13962468.1132760196600.JavaMail.root@cp1.javalobby.org...
> Veronika-
Re: PNG icons in ToolBars [message #464532 is a reply to message #464524] Wed, 23 November 2005 21:42 Go to previous messageGo to next message
We have done our best for older Windows. Currently, we do not see any
better solution.
(To see the effect on older Windows, just run without the manifest - this
invokes an older version of the common controls DLL).
"Martin R
Re: PNG icons in ToolBars [message #464535 is a reply to message #464531] Thu, 24 November 2005 01:34 Go to previous messageGo to next message
It's been a while since I tried the Label alpha blending on windows, but I tried it on GTK linux a few months ago (in 3.1 gold) and the problem was still there. I'm on the run right at the moment so I don't have time to write a test app on my windows XP machine. I'll try and post something later tonight.
Re: PNG icons in ToolBars [message #464560 is a reply to message #464535] Thu, 24 November 2005 20:19 Go to previous messageGo to next message
------=_Part_686_15742640.1132863639163
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Veronika,
It would seem that I was wrong. It's possible that my information was reguarding one of the milestones of 3.1 and I had simply forgotten about it.
Right at the moment, I don't have a chance to test it on GTK. Anyone else have a box they can run this on?
public class TestClass {
		Display display = new Display();
		Shell shell = new Shell(display);
		shell.setLayout(new RowLayout());
		Label label = new Label(shell, SWT.CENTER);
		label.setImage(new Image(display, TestClass.class.getResourceAsStream("/image.png")));
		Button b = new Button(shell, SWT.PUSH);
		b.setText("Button");
		shell.open();
		while (!shell.isDisposed())
			if (!display.readAndDispatch()) display.sleep();
Content-Type: image/png; name=image.png
Content-Disposition: attachment; filename=image.png
iVBORw0KGgoAAAANSUhEUgAAABYAAAAWCAYAAADEtGw7AAAABHNCSVQICAgI fAhkiAAAABl0RVh0
U29mdHdhcmUAd3d3Lmlua3NjYXBlLm9yZ5vuPBoAAAOMSURBVDiNtZNdbFNl GMf/z/kqPW3XndYO
3PfZaqngzNBdLBC98A6JaPTGu8GlgMQoGhMxqUs04DRwgbEhzgyDRBOXEKNi glcjTpmU+TGcjNF9
ZmuUtqed7U7X0/N4Ybc0TNwy8Z+8yZvn/T+/PO/zPi8xM/4PCXcDQkQPrQIT UZiIeohoiohOlY1h
IvqRiPqI6NF1sFd5JGb+DcDLRFRbEZ8AcJaZ39noLaSK/fMARoioH0AIQLQc p2RyIWzbZikQCIwB
ABEJAB4GIJY9TUTUWd4XAVxdATNzioieA/AxgH2ZTMYxPZ89M57mzowleSTJ Cb+RyWyWF7+9cGHw
wO7dO/+1YqqcCiJSAVzR9ZbR3s+vdAwlFa+4SShKIhYEkXKqAtUtwxmkrImM 8WxHR2ionPcCM5+s
BN8+Ffva2tqeSKWNvWe/+W6zRxNJ8woFl4qcRxXyJIo3LUmIz6leiR1KNBaL yXeqeAVMRI8AiPX3
f9G15/CJwvmeAzKVcumAJpo1XsmqrhLY5yXSPGJeUaV46d4t9em0daScPviP YCLaDqCLmS+n8vaD
Dzz29KJvS4N1rvuQ5oZFioCcexOZfq9Ifk3APdXCksMrZ0hS2svvM7QKXJ7T vQAmiCiUzHPzrbkb
dmt7Z9blq02d7jlumSXT9KoCPCrZVRLBTQSngJyoyvqdWiEx8wCAgeXA1wPX Eg2t4ZrmcGTK53VY
Xg9K1S5RlB1kuQAoAGQAJZuV7B/G5Jo9XhbnjFEFlqgokmjZ/CeBFiUFRQdg KwBUAC4AcmHJOT/7
+/V1gxMJ47g/O1NwyggoImRBBkTxb6NcrlgpWoFfvh9xqip9uG7w/v17EvmZ G68piWmXQ7BaieEA
AAZgA2Sahfqfhq+3wi6pVVW+p+Lvb5dWUXHbB6nUsWMf7fQ31p2qua85qNVV Zx3EbCZSVeM/j41t
CzUl3G5Vk22jXRqJ2FZyPBo+PPrKusDLOnjw3aCmqY9bllUyjOSX0WhkEgB+ +KBra/3Whmu+xqBo
XO4tpqYn3rz/yOwbK4nMvKEVe1tvnjnTNMGzJ9mc7OPEp7vyV9+qjSyfbxjM zLjUrbdMntaGefYE
m1N9PPfJrvxgpK6bmdduxVq6eFRv0WsznwWffH1HoeTHrcFe62Y8995/BgPA +Zda9FCT0b/tmaM7
4uMWhoYXvrorYAA4d0jX6xtdF5f0F+1f59VX/wJnur/gsXTNewAAAABJRU5E rkJggg==
Content-Type: image/bmp; name=swt-image-sample.bmp
Content-Disposition: attachment; filename=swt-image-sample.bmp
Qk0ieQAAAAAAADYAAAAoAAAAkQAAAEcAAAABABgAAAAAAOx4AAAAAAAAAAAA AAAAAAAAAAAAmRQA
jBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMA jBMAjBMAjBMAjBMA
jBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAjBMAAK4WAKAeAKAeAKEe AKAeAKAeAKAeAKAe
AKAeAKAeAKAeAKAeAKEeAKEeAKEeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAd AKAdAKAdAKAdAKAd
AKAdAKAdAKAeAKAeAKAeAKAeAKAdAKAdAKAdAKEeAKEeAKEeAKEeAKAdAKAd AKAdAKEeAKEeAKEe
AKEeAKAeAKAeAKAeAKEdAKEdAKEdAKAeAKAeAKAeAKAeAKEeAKEeAKEeAKEe AKEeAKEeAKEeAKEd
AKEdAKEdAKEdAKEdAKEdAKEdAKAeAKAeAKAeAKEdAKEdAKEdAKEdAKEeAKEe AKEeAKEeAKEeAKEe
AKEeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKEeAKEeAKEeAKAeAKAeAKAeAKAe AKAeAKAeAKAeAKEe
AKEeAKEeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAeAKAe AKAeAKEdAKEdAKEd
AKEdAKAeAKAeAKAeAKEeAKEeAKEeAKEeAKEeAKEeAKEeAKEeAKEeAKEeAKEe AKEeAKEeAKEeAKAe
AKMeAKEeAJsbAIwTAADPGQDZMQjaRw3fVBDZSQrYQQTYQQTYQQTdPgDdPgDd PgDdPgDcPQDcPQDc
PQDcPQDcPQDcPQDcPQDcPQDcPQDcPQDcPgDcPgDcPgDcPgDdPQDdPQDdPQDc PQDcPQDcPQDcPQDc
PQDcPQDcPQDdPQDdPQDdPQDdPQDcPgDcPgDcPgDdPgDdPgDdPgDdPgDcPQDc PQDcPQDcPQDcPQDc
PQDdPgDdPgDdPgDdPgDcPQDcPQDcPQDdPgDdPgDdPgDdPgDcPQDcPQDcPQDd PQDdPQDdPQDdPQDd
PQDdPQDdPQDcPQDcPQDcPQDcPQDcPQDcPQDcPQDdPQDdPQDdPQDdPQDcPQDc PQDcPQDcPgDcPgDc
PgDcPgDdPQDdPQDdPQDcPQDcPQDcPQDcPQDcPQDcPQDcPQDdPQDdPQDdPQDc PQDcPQDcPQDcPQDc
PQDcPQDcPQDdPQDdPQDdPQDdPQDcPgDcPgDcPgDdPQDdPQDdPQDdPQDcPQDc PQDcPQDdPQDdPQDd
PQDdPQDcPQDcPQDcPQDdPQDdPQDdPQDdPQDdPQDdPQDdPQDcPQDQNwC8LACj HgCMEwAAzxkA2TEI
5VIS7moW3VUI6k8H6k8H6k8H8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA 8UgA8UgA8UgA8UgA
8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA8UgA 8UgA8UgA8UgA8UgA
8UgA8UgA8UgA8UgA8UgA8UgA3D0Avi0AoB0AjBMAAM8ZANkxCO5qFt1VCNjp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7PFI
ANw9AKAdAIwTAADPGQDZMQjuahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezxSADcPQCgHgCM EwAAzxkA2TIH7moW
3VUI2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons8UgA3D4AoR0AjBMAAM8ZANkyB+5qFt1VCNjp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7PFIANw+
AKEdAIwTAADPGQDZMQjuahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezxSADcPQCgHgCMEwAA zxkA2DEH7moW3VUI
2Ons2Ons2Ons2Ons8UgA3D0AoR4AjBMAAM8ZANkxCO5qFt1VCNjp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7PFIAN0+AKAd
AIwTAADPGQDZMQfuahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezxSADdPgChHgCMEwAAzxkA 2TEH7moW3VUI2Ons
2Ons2Ons2Ons8UgA3D4AoB4AjBMAAM8ZANkxB+5qFt1VCNjp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7PFIANw+AKAeAIwT
AADPGQDZMQfuahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezxSADdPQCgHgCMEwAAzxkA2TEH 7moW3VUI2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2urt3+3v5/Hz7fX27/b38Pb48Pf48Pf4 8Pf48Pf48Pf48Pf4
8Pf48Pf48Pf48Pf48Pf48Pf48Pf48Pf48Pf48Pf49vr69vr69vr69vr69vr6 9vr69vr69vr69vr6
9vr69vr69vr69vr69vr69vr68Pf48Pf48Pf48vf48vj58ff43u3v2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons8UgA3T0AoB0AjBMAAM8ZANkxB+5qFt1VCNjp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7MDZ4kOWx6Wz wsnNz9jp7Njp7Njp
7NTm6djp7KqZfYNXJXQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8 AHQ8AHQ8AHQ8AHQ8
AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8AHQ8 AHQ8AHQ8AHQ8AHQ8
AHQ8AHQ8AH5NFqSMbOr09O7299jp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFI ANw9AKEeAIwTAADP
GQDZMQjuahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezA2uQ4otmN5P+JwN2XqrvY6ezY6ezY6ezP4eWgh2aF TSfBfU3ugmnugmnu
gmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnu gmnugmnugmnugmnu
gmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnugmnu gmmFTSeii2rr9PXY
6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezxSADcPQChHgCMEwAAzxkA2TEI7moW 3VUI2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Onsv9rmOKXejuT/
oeH4QKjke7DU2Ons2Ons2OnszN7jfk0W5K2J5K2JPERl5K2JPERl5K2JPERl 5K2JPERl5K2JPERl
5K2JPERl5K2JPERl5K2JPERl5K2JPERl5K2JPERl5K2JPERl5K2JPERl5K2J PERl5K2JPERl5K2J
PERl5K2JPERl5K2JPERl5K2JPERl5K2JPERl5K2Jfk0W5vHz2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons8UgA3T4AoR0AjBMAAM8ZANkxCO5qFt1VCNjp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7L/b5zep4o/k/6Dh+EGq5niz2djp 7Njp7Njp7Njp7Mve
4nQ8AOStiTxEZeXr6+Xr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr 7Obr7Obr7Obr7Obr
7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr7Obr 7Obr7Obr7Obr7OXr
6+Ho6eStieStiXQ8AOLu8djp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIAN0+ AKEdAIwTAADPGQDZ
MQjuahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezB3eg2quWQ5P+g4PhBq+h5t93Y6ezY6ezY6ezY6ezY6ezL3uJ0PADkrYvk rYvq8PDq8PDq8PDq
8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq 8PDq8PDq8PDq8PDq
8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDq8PDo7u88RGfl r4t0PADh7vDY6ezY
6ezY6ezY6ezY6ezY6ezY6ezY6ezxSADcPgChHgCMEwAAzxkA2TEI7moW3VUI 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2OnsztfavLm7urm7zdnb2Ons2Onsxd3nfcPm n+D4P6voebrh2Ons
2Ons2Ons2Ons2Ons2Onsy97idDwA5q+OPUdi6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw 6/Dw6/Dw6/Dw6/Dw
6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw 6/Dw6/Dw6/Dw6/Dw
6/Dw6/Dw6/Dw6/Dw6/Dw6/Dw6e/v5q+O5a+NdDwA4O7w2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
8UgA3D4AoR4AjBMAAM8ZANkxCO5qFt1VCNjp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7MzT1cKy
qdzMs+rmxunnzNnQwruvrNPQ0dvX2MzR2FOo3Hm54Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Mve4nQ8
AOexkeaxkezx8ZDU8QAAQwAAAAAAAGsAAOzxtOzx8UGT1AAAAAAAAGtuQ5BD Q+zx1Ozx8QButAAA
AM+TQ+zx8QButAAAAM+TQ5DU8QAAQwAAAGsAAOzxtJDU8ZBDQ+zx1Ozx8ZDU 8ZBDQ+zx1Ozx8evw
8D9YfeaxkXQ8AODu8Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIANw+AKEe AIwTAADPGQDZMQju
ahbdVQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezJztDaw6zz4bT07cTz+NP0 +dz1+eXz9OjUy8jH
vLzNztDW5+vY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezL3uJ0PADotJQwWnjt 8fGQ1PGQQ0Pt8dTt
8fFstPGQQwCQ1NRsAEPt8bTt8fFBk9SQQwDt8dSQ1PFsAEPt8bTt8fGQ1PFs AEPt8bSx8fEAAG7t
tG7t8fFBk9SxbgCQ1PGQQ0Pt8dTt8fGQ1PGQQ0Pt8dTt8fHs8PDotJXotJV0 PADg7vDY6ezY6ezY
6ezY6ezY6ezY6ezY6ezY6ezxSADcPgChHgCMEwAAzxkA2TEI7moW3VUI2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons1eLl1sCw9dqq8eC38u3F8/jT9Pnd9Pnm9Pnu9ffzyr+90t7h2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Onsy97idDwA6riY6biY7fLykNTykERE7fLU7fLysfLybABu kNS1kERE7fLU7fLy
kNTykERE7fLUkNTykERE7fLU7fLykNTykERE7fLUkNTykERE7fLU7fLykNTy bABEkNS1kERE7fLU
7fLykNTykERE7fLU7fLy7PHxMlF16biYdDwA4O7w2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons8UgA
3D4AoR4AjBMAAM8ZANgxCO5qFt1VCNjp7Njp7Njp7Njp7Njp7Njp7Njp7M3M zvDMnPHYqPDftfLq
w/P20fT52/T54/T56vT57vHy58G+v9jp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Mve4nQ8AOq7
nDNVce7z85HV85FERO7z1e7z85HV85FERJHV1ZFERO7z1e7z85HV85FERO7z 1ZHV85FERO7z1e7z
85HV85FERO7z1ZHV85FERO7z1e7z85HV82wARJHVtpFERO7z1e7z85HV85FE RO7z1e7z8+3y8uu7
neu7nHQ8AODu8Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIANw+AKEeAIwT AADPGQDYMQjuahbd
VQjY6ezY6ezY6ezY6ezY6ezY6ezY6ezVzMbzzJju06Xz4LTz6sH08s31+db0 +d70+eP0+eb29+PK
xMPY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezY6ezL3uJ0PADsvqDsvqDv8/OS 1fMAAEQAAAAAAABD
AADv1ZSS1fOSRETv89Xv8/OS1fOSRETv89WS1fOSRETv89Xv8/OS1fOSRETv 89Wz8/MAAG7vtm7v
8/NDlNWzbgCS1fMAAETvtm7v8/NttvOSRADv89Xv8/Pu8vI1V03svqF0PADg 7vDY6ezY6ezY6ezY
6ezY6ezY6ezY6ezY6ezxSADcPgChHgCMEwAAzxkA2TIH7moW3VUI2Ons2Ons 2Onso7Czcnp8cHl6
uMbJ3c2/z6x8fGxUf3NcjYVt6+S+9PXR9PnW9Pnb9Pnd9vna1M/I2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Onsy97idDwA7cGlNStI8PT0ktb0kkRE8PTW8PT0bbf0tG8Aktb0 kkRE8PTW8PT0ktb0
kkRE0/TWAESVAAAAAAAAtJVEAESVAAAAAAAA05VEktb0AABEAAAAbQAA8PS3 ktb0kkREAG+VAAAA
AAAA8Ldv8PT08PT07/Pz7sOl7sKldDwA4O7w2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons8UgA3D0A
oB4AjBMAAM8ZANgxCO5qFt1VCNjp7Njp7Njp7Njp7LTCxFRaXNjp7N3Y0/HD jkA2KV9ZRvPow/Ln
w/PtxvTyzPP20fP41Pb40tLOzdjp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Mve4nQ8AO/FqfDG
qPH19ZPX9ZNERPH11/H19ZPX9ZNERPH11/H19fH19fH19fH19fH19fH19ZPX 9ZNERPH11/H19ZPX
9ZNERPH11/H19fH19fH19fH19fH19fH19fH19fH19fH19fH19fH19fH19fH1 9fH19fD09DcsRe/F
qXQ8AODu8Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIANw9AKAeAIwTAADP GQDZMgfuahbdVQjY
6ezY6ezY6ezY6ezY6eyksbSpt7nd4eOjg2AhHBTp0aH36Ln05bv05rvy57/y 6sPz7cT168rR09XY
6eyquLrY6ezY6ezY6ezY6ezY6ezY6ezY6ezL3uJ0PADwyK0pLkHy9vaU2PYA AEQAAAAAAAAAAADy
uHDy9vby9vby9vby9vby9vby9vby9vaU2PaURETy9tjy9vaU2PaURETy9tjy 9vby9vby9vby9vby
9vby9vby9vby9vby9vby9vby9vby9vby9vby9vbx9fXwx63wx6x0PADg7vDY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezY6ezxSADdPQCgHgCMEwAAzxkA2TEI7moW3VUI2Ons2Ons2Ons 2Ons2Ons2OnsfoiK
wM/SFRQTtpFl9dOa9dmk8dio8tuv8Nyy8eC09eS43tfQ2Ojr2OnseYOE2Ons 2Ons2Ons2Ons2Ons
2Ons2Onsy97idDwA8sux8sux8/b28/b28/b28/b28/b28/b28/b28/b28/b2 8/b28/b28/b28/b2
8/b28/b28/b28/b28/b28/b28/b28/b28/b28/b28/b28/b28/b28/b28/b2 8/b28/b28/b28/b2
8/b28/b28/b28vX1KiJd8syxdDwA4O7w2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons8UgA3D0AoB4A
jBMAAM8ZANgxCO5qFt1VCNjp7Njp7Njp7Njp7Njp7Njp7NDg4yMlJlxhYuvV xPPDjvTKk/LPm/HS
ofPXpfTbrufc0Njj5djp7Njp7HmDhNjp7Njp7Njp7Njp7Njp7Njp7Njp7Mve 4nQ8APPNtCsnWfb4
+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4 +Pb4+Pb4+Pb4+Pb4
+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4+Pb4 +PX39/POtPPOtXQ8
AODu8Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIANw9AKAdAIwTAADPGQDY MQjuahbdVQjY6ezY
6ezY6ezY6ezY6ezY6eyVoaMVFxedqava6uzp5+Xu18Lz0rHy1rXu3Mni4uLX 5uirubuptriptrhf
Zmiptriptritur3X6OvY6ezY6ezY6ezL3uJ0PAD00Lf00bj5+vr5+vr5+vr5 +vr5+vr5+vr5+vr5
+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5 +vr5+vr5+vr5+vr5
+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr5+vr4+votOFT10Lh0PADg7vDY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezY6ezxSADcPQCgHQCMEwAAzxkA2DEH7moW3VUI2Ons2Ons2Ons2Ons 2OnsydnbFRcXoa6w
gYuNzt7h2Ons2Ons3Ors2+ns2Ons2Ons1ufqq7m7qba4qba4X2Zoqba4qba4 rbq91+jr2Ons2Ons
2Onsyt3hdDwA9dO6LjpW/Pz8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8 +/z8+/z8+/z8+/z8
+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8+/z8 +/z8+/z8+/z8+/z8
+/z8+/z8+/z89dK69tO6dDwA3+3v2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 8UgA3T0AoR4AjBMA
AM8ZANgxCO5qFt1VCNjp7Njp7Njp7Njp7Njp7ExSU1tiY9jp7NLj5nZ/gdjp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7HmDhNjp7Njp7Njp7Njp7Njp7Njp7Njp7Mve4oNX JfbUvPbUvC49UPbU
vC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49 UPbUvC49UPbUvC49
UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbUvC49UPbU vC49UPbUvINXJdrq
7djp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIANw+AKEdAIwTAADPGQDYMQfu ahbdVQjY6ezY6ezY
6ey2xMdiamsZGxxbYmPY6ey2xMcoKytQV1ijsLPY6ezY6ezY6ezY6ezY6ezY 6ezY6ezY6ex5g4TY
6ezY6ezY6ezY6ezY6ezY6ezY6ezL3uKolXqFTSf/587/587/587/587/587/ 587/587/587/587/
587/587/587/587/587/587/587/587/587/587/587/587/587/587/587/ 587/587/587/587/
587/587/587/587/587/587/587/587/587/586FTSeplXvV5+nY6ezY6ezY 6ezY6ezY6ezY6ezY
6ezY6ezxSADcPQCgHgCMEwAAzxkA2DEH7moW3VUI2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Onsrru+2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
zt/k0OHmqJV6g1cldDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwA dDwAdDwAdDwAdDwA
dDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwAdDwA dDwAdDwAdDwAdDwA
dDwAdDwAfk0WoIhn0uTo0uTo2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons8UgA 3D0AoB4AjBMAAM8Z
ANkxCO5qFt1VCNjp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7NXn6c7f5Mrd 4cnc4Mnc4Mnc4Mnc
4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc4Mnc 4MLW3MLW3MLW3MLW
3MLW3MLW3MLW3MLW3MLW3MLW3MLW3MLW3MLW3MLW3MLW3Mnc4Mnc4Mnc4Mrd 4cve4s7f5NXn6djp
7Njp7Njp7Njp7Njp7Njp7Njp7Njp7PFIANw9AKAdAIwTAADPGQDZMQjuahbd VQjY6ezY6ezY6ezY
6ezxSADcPQCgHQCMEwAAzxkA2jQJ7moW3VUI2Ons2Ons2Ons2Ons2Ons2Ons 2Ons2Ons2Ons2Ons
2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons2Ons8UgA3D0A oB0AjBMAAM8ZANo0
B+5qFt1VCNjp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp7Njp 7Njp7Njp7Njp7Njp
7Njp7Njp7Njp7Njp7Njp7Njp7PFIANo7AKkhAIwTAADPGgDgOwDgOwDgSwDP QwDPQwDPQwHQRAHQ
RAHQRQLQRQLQRQLQRQLQRQLQRQLQRQLQRQLQRQLQRAHQRAHQRAHPQwHPQwHQ RAHPQwHPQwHQRAHQ
RAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQ RAHQRAHQRAHQRAHQ
RAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHQRAHPQwDPQwDPQwDPQwDPQwDPQwDP QwDPQwDPQwDPQwDP
QwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDP QwDPQwDPQwDPQwHP
QwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHP QwHPQwHPQwHPQwHP
QwHPQwHPQwHPQwHPQwHPQwHPQwHPQwHPQwDPQwDPQwDPQwDPQwDPQwDPQwDP QwDPQwDPQwDPQwDP
QwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDPQwDP QwDPQwDPQwDPQwDg
OwDcLgDBMgCSFQAAzxoA4DsA4DsA4EsAzD0Az0MA0EQB0EUC0EUC2EoA2EoA 2EoA3E0B3E0B3E0B
4FAA400A4lAA4lAA4lAA4VMA4lAA4lAA4lAA4lAA4lAA400A400A400A400A 400A400A400A400A
400A400A400A400A400A400A400A400A400A400A400A400A400A400A400A 400A400A400A400A
400A400A400A400A400A400A400A400A400A400A400A4EYA4EYA4EYA4EYA 4EYA4EYA4EYA4EYA
4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA4EYA 4EYA4EYA4EYA4EYA
4EsA40sA4EYA4EYA4EYA4EYA4EYA4EYA4EYA3EMA3EAA3EAA3D0A3D0A3D0A 2j4A3EAA3D0A3EAA
3EAA3EAA2j4A3EAA2j4A2ToA2ToA2DgA2ToA2DUA2DgA2DUA4DsA6jgAwTIA ixMAAM8aAOA7AOtL
AONNAONUAOZYAOZYAOtYAOxcAO5gAPJfAPFlA/FlA/FlA/RoA/RoA/RoA/Ro A/poA/pqAfpqAfpq
AfpqAfpqAfpqAf1lAPlkAflkAflgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlg APlgAPlgAPlgAPlg
APlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPxg APxgAPxgAPxgAPxg
APxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxgAPxg APxgAPxgAPxgAPxg
APxgAPxgAPxgAPxgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlg APlgAPlgAPlgAPlg
APlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlgAPlcAPxgAPlc APhZAPVaAPNYAPZX
APdYAPdYAPZXAPRVAPRRAPRVAPRRAPRRAPRVAPRVAPRVAPRVAPBRAO9MAPBR APRVAPRRAPNMAPNM
AO9HAO9HAO9HAO9HAO9HAO9HAOo4AMEyAIsTAADPGgDgOwDrSwDuWADyWwDu WADyWwDxYAPxYAP2
YQP0aAP6aAP5agb5agb5agb8bAb8bAb8bAb7awP7awP7awP7awP7awP7awP7 awP+agL+agL6aAP6
aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP6 aAP6aAP6aAP6aAP6
aAP6aAP6aAP6aAP6aAP6aAP6aAP6aAP9ZQD9ZQD9ZQD9ZQD9ZQD9ZQD9ZQD9 ZQD9ZQD9ZQD9ZQD9
ZQD9ZQD9ZQD9ZQD9ZQD9ZQD5Zwrwvqf///////////////////////////// ////////////////
///////////////////99vTwvqf5Zwr9ZQD9ZQD5Zwrwvqf///////////// ////////////////
///////////////////////////////////99vTwvaf1Ygr5YAD5XAD1Xwrw vaf/////////////
///////////////////////////////////////////////////99vTvvKfx UQrzTADvRwDqRgDq
OADBMgCLEwAAzxoA4jsA60sA7lgA8lsA9WAB9mED+WUC+WUC+mgD+WoG/GwG /W8H/W8H/XIH/XIH
/XIH/nEG/nEG/nEG/nEG/3ID/3ID/3ID/24D/24D/24D/moC/moC/moC/moC /moC/moC/moC/moC
/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC /moC/moC/moC/moC
/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC /moC/moC/moC8L6n
8drQw1Yotj8NvUQRu0USuUUUuUQSvEUTvUYTvkUQwEUNwUUKw0QIwEEGwD8D wz8BvjsAuU4f7djP
8L6n/moC/moC8L6n8drQw1Yotj8NvUQRu0USuUUUuUQSvEUTvUYTvkUQwEUN wUUKw0QIwEEGwD8D
wz8BvjsAuU4f7djP8L6n/WUA/GAA8L2n0NbuKES1DSumETCsEjGrFDKpEjCp EzKsEzKtEDGuDTCx
Ci6yCC20BiqxAyixASe0ACSuHzysz9Tq77yn9FEA80wA70cA6jgAwTIAixMA AM8aAOI7AOtLAO5Y
APVgAfVgAfZhA/poA/poA/xsBv1vB/1vB/1yB/1yB/50B/50B/50B/50B/50 B/50B/5xBv5xBv9y
A/9yA/9yA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9u A/9uA/9uA/9uA/9u
A/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/9uA/5qAv5q Av5qAv5qAv5qAv5q
Av5qAv5qAv5qAv5qAv5qAv5qAv5qAv5qAv5qAv5qAv5qAv329N9eKN9PE99V G+JaIeFcJeBdJuFc
JOJeI+JeIeJeHuVfG+VeFuZdE+VbDuZYCeZUBOJOAdNFALhOH/////5qAv5q Av329N9eKN9PE99V
G+JaIeFcJeBdJuFcJOJeI+JeIeJeHuVfG+VeFuZdE+VbDuZYCeZUBOJOAdNF ALhOH/////1lAPxg
AP329ChJzRM4zBs+zCFEzyVHzyZHzyRGzyNH0CFG0R5F0htF1RZC1RNA1g49 1Qk51gQ11QEw0QAq
wh88q/////RRAPNMAO9HAOo4AMEyAIsTAADPGgDiOwDrSwDuWAD1YAH2YQP5 ZQL6aAP7awP6bwb9
bwf+cQb+cQb9cgf+dAf+dAf+dAf+dAf+dAf+cQb+cQb/cgP/cgP/cgP/bgP/ bgP/bgP/bgP+agL+
agL+agL+agL+agL+agL+agL+agL+agL+agL+agL+agL+agL+agL+agL+agL+ agL+agL+agL+agL+
agL+agL+agL+agL+agL////tUA7vWxzwYyjwaC/xazPxbDTybDHybTHyby7y cCrzcCXzbx/0bRn0
ahP0Zg3zYAfwWgLiTQC5OgD////+agL+agL////tUA7vWxzwYyjwaC/xazPx bDTybDHybTHyby7y
cCrzcCXzbx/0bRn0ahP0Zg3zYAfwWgLiTQC5OgD////8YAD8YAD///8ON9gc Q9soTN0vUt4zVd80
V+AxVeAxVuAuVuEqVeIlU+QfUOQZTOUTSOUNQ+UHPuQCOOAAL9EAI6r////z TADzTADvRwDqOADB
MgCSFQAA0h8A4jsA60sA7lgA8l8A9WAB7GAC52AD6GMD6GMD6WQG6mcG62kG 62kG5WcG5mkG5mkG
5WcG5mYF5mYF5mYF/m4D/24D/mwB/mwB/moC/moC/moC/moC/moC/moC/moC /moC/moC/moC/moC
/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC/moC /moC/moC////81YU
9GIl9Gsx9HE59XQ99nQ99XU79XY59Xc39ngy93gs93cl93Yf93IZ+G4R92gL 9GAF5lMCvj0B////
/WUA/WUA////81YU9GIl9Gsx9HE59XQ99nQ99XU79XY59Xc39ngy93gs93cl 93Yf93IZ+G4R92gL
9GAF5lMCvj0B/////GAA+VwA////FDzdJUvgMVThOVvjPV7kPV/kO17kOV7l N17lMl3mLFvnJVfo
H1TpGVDpEUrpC0ToBT3kAjPWASav////80wA70cA6kYA6jgAxjEAkhUAANYj AOA7AOdLAOtYAPJf
APVgAZFAFoo7Eoo6Eoo7Eoo8Eoo8Eoo8Eoo8Eok8Eok8Eok8Eok8Eok8Eok8 Eng3E9JYAv5qAvpq
AfpqAf1lAP1lAPlkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflk AflkAflkAflkAflk
AflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAflk AflkAflkAflkAflk
AflkAflkAflkAflkAflkAflkAflkAflkAflkAflkAf////NZGPRoLvRxOvV3 Qv//////////////
//////////////h8Kvh6JPh3HfhzFfhsDvRjCedWBb8/Av////xgAPxgAP// //NZGPRoLvRxOvV3
Qv////////////////////////////////////////////hsDvRjCedWBb8/ Av////lcAPhZAP//
/xhA3i5R4Tpc40Ji5LXB9f///0Nl5kFl5j1k5jhi5zJg6Cpc6SRZ6v///6G4 9w5I6QlA5QU21wIn
sP///+9HAO9HAOhBAOo4AMgsAJIVAADWIwDgOwDqRgDrUQDyXwDyXwD///// ///////6///7////
///////////////////////////////9///Jl3POVgL5ZQL5ZQL5ZAH5ZAH5 YAD5YAD5YAD5YAD5
YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5YAD5 YAD5YAD5YAD5YAD5
YAD5YAD5YAD5YAD////zXR70bjb1dkL1e0n///////////////////////// ///3fS34eiX4dx74
cxf3bRH0Zg3nWQvAQQb////5YAD5YAD////zXR70bjb1dkL1e0n////3fkr2 fkj2f0X2gEH2fzv3
fzX3fS34eiX4dx7////3bRH0Zg3nWQvAQQb////zWAD0VQD///8eRd82WOJC YuRJZ+X/////////
//9FaOZBZ+c7ZOc1YugtXur///////////8RSukNROYLO9cGK7H////vRwDq RgDoQQDiOwDBMgCS
FQAA0h8A4DsA5EYA6lUA7FwA8l8A/////P//+v//+v//+v//+v//+v//+v// +v//+v//+v//+v//
+v///P//yJRzz1QC9mED9mED9mED9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB 9WAB9WAB9WAB9WAB
9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB9WAB 9WAB9WAB9WAB9VoA
9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA9VoA 9VoA////82Il9HM9
9XtI9oBO////////////////////////////93wt+Hkm93cg93MZ928W9GkT 6F0Qv0QK////9VoA
9VoA////82Il9HM99XtI9oBO////9oFO9oBL9n9H9n9C9n88938293wt+Hkm 93cg////928W9GkT
6F0Qv0QK////8VUA8VUA////JUvgPV7jSGflTmzmUG3m////////////Qmjn PGXnNmLo////////
////GVDpFkzoE0fkED/YCi2x////6EEA6EEA4jsA3C4AtyoAkhUAANIfANw9 AORGAOVVAOtYAOxc
AP////v///z///r///r///r///r///r///r///r///r///r///r///v//8yW cc1RAvZhA/VgAfVa
APVaAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJb APJbAPJbAPJbAPJb
APJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJb APJbAPJbAPJbAPJb
APJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAPJbAP////RmK/V4RPZ/TvaCUvaD U/aCUfeBTfZ/SPZ/
Q/Z+PfZ8Nfd6Lfd3Jvd0IfdxG/duGPRqGOdfFsBHD/////NYAPNYAP////Rm K/V4RPZ/TvaCUv//
//aCUfeBTfZ/SPZ/Q/Z+PfZ8Nfd6Lfd3Jvd0If////duGPRqGOdfFsBHD/// //FVAPBRAP///ytP
4URj5E5r5lJv51Nv51Fu5v///////////z1l5/////////H1/iFU6BtQ6BhN 5xhK5BZC1w8xsv//
/+hBAOFAAOA7ANwuALcqAJIVAADIIADYOADkRgDlUQDrWADsXAD////5///6 ///6///6///6///6
///6///6///6///6///6///6///7///QmW3IUALxYAPyWwDyWwDuWADuWADu WADuWADuWADuWADu
WADuWADuWADuWADuWADuWADuWADuWADuWADuWADuWADuWADuWADuWADuWADu WADuWADuWADuWADu
WADuWADuWAD////0azL1fUv2g1T3hFb3g1X2glL2gE32fUj2fEL2ejz2eDT2 di33cyb3cSH2bxz2
bRz0ahzmYRy/SBL////uWADuWAD////0azL1fUv2g1T3hFb////2glL2gE32 fUj2fEL2ejz2eDT2
di33cyb3cSH////2bRz0ahzmYRy/SBL////rUQDrUQD///8yVOJLaeVUcOdW cedVcOhSb+dNbOb/
//////////////////8mVechUuccTuYcTeYcTOMcRtYSM7D////iOwDgOwDY NQDWIwC3KgCLEwAA
yCAA2DgA5EYA5VEA6lUA61gA////+f//+v//+v//+v//+v//+v//+v//+v// +v//+v//+v//+v//
+///1ZtrzFAD7F0D7F0D7FwA61gA61gA61gA61gA61gA61gA61gA61gA61gA 61gA61gA61gA61gA
61gA61gA61gA61gA61gA61gA61gA61gA61gA61gA61gA61gA61gA61gA61gA 61gA61gA6lUA6lUA
6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA6lUA ////9G439oFR94VX
94ZZ94VX9oFS9n5N9ntH9nlB9Xc79XQ09nIs9m8m9m0i9mse9mof82oh5mIh vkkW////6lUA6lUA
////9G439oFR94VX94ZZ////9oFS9n5N9ntH9nlB9Xc79XQ09nIs9m8m9m0i ////9mof82oh5mIh
vkkW////61EA5VEA////N1njUW3nV3LoWXPoV3HnUm7mTWrmR2fl//////// ////LFflJlPlIlDl
Hk3lH03lIU7iIUnWFjWv////3D0A2ToA2DUA0CkArCYAixMAALwaANI2ANxA AOJQAOZYAOhZAP//
//n///r///n///r///r///r///r///r///r///r///r///r///r//9ecas1R A+xdA+xcAOtYAOhZ
AOhZAOhZAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpV AOpVAOpVAOpVAOpV
AOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpV AOpVAOpVAOpVAOpV
AOpVAOpVAOpVAOpVAOpVAOpVAOpVAOpVAP////RyPPaHWfeKXfeJXfeGWfaB U/Z+TvV6R/V4QfV0
OvVyNPVvLPVsJ/ZqI/ZpIPVoIvJpJeZiJb5LGf///+pVAOpVAP////RyPPaH WfeKXfeJXf////aB
U/Z+TvV6R/V4QfV0OvVyNPVvLPVsJ/ZqI/////VoIvJpJeZiJb5LGf///+NN AONNAP///zxd41l0
6F136F126Fly51Nv5k5r5f///////////////////ydR5CNP5CBM4yJN4yVP 4SVK1Rk3r////9g4
ANg1ANI2ANApALcqAH0OAAC8GgDSNgDcQADcSgDlUQDlVQD////5///8///7 ///6///6///6///6
///6///6///6///6///6///////bnmjNUQPsXQPpXADoWQDoWQDmWADmWADl VQDlVQDlVQDlVQDl
VQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDlVQDl VQDlVQDlVQDlVQDl
VQDlVQD////1eUb3jGD4jWL3i2D3h1v3glT2fE72eEf1dEH1cTr0bjT1ay31 aSj1ZyT1ZiL1ZyXy
aCnkYym9Sxv////lVQDlVQD////1eUb3jGD4jWL3i2D////3glT2fE72eEf1 dEH1cTr0bjT1ay31
aSj1ZyT////1ZyXyaCnkYym9Sxv////jSwDgSwD///9GZeVgeuhifOhgeuhb dOhUbuf/////////
//86XOP///////////8kTeIiS+IlTeIpUOApTNQbOa7////YOADYNQDQKQDI IACsJgB9DgAAvBoA
0jYA3EAA3EoA41QA5VUA////+f//+f//+v//+v//+v//+v//+v//+f//+v// +v///f///v//////
36JlylEC6FkA6FkA6FkA5lgA5lgA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA 5VUA5VUA5VUA5VUA
5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA 5VUA5VUA5VUA5VUA
5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA//// 9XlG+JJo+JNq+I9l
94le94NX9n5Q9nlK9XVD9XE99G429Wsv9Wkr9Wco9WYn9Wgq8mks5GIqvUwc ////5VUA5VUA////
9XlG+JJo+JNq+I9l//////////////////////////////////////////// 9Wgq8mks5GIqvUwc
////400A4EsA////RmXlaIHpaoPqZX7pXnfo////////////Q2HkPV3kNljj ////////////J07i
KlDiLFHgKk3THDmt////2DgA0jYA0CkAyCAArCYAfQ4AALwaAMs3ANI7ANxK AOFTAOVVAP////r/
//r///r///r///r///r///r///r///r///r///r///r//////+KjYshOAOda AOdaAOZYAOZYAOVV
AOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVV AOVVAOVVAOVVAOVV
AOVVAOVVAOVVAOVVAOVVAOVVAOVVAP////Z+TfiXbviZcPiTaviMYveGW/eA VPZ7TfZ3R/VyQPVv
OvRtNPRrMPRpLfVpLPVpLfJpLuVjLLxMHf///+VRAOVRAP////Z+TfiXbviZ cPiTav//////////
//////////////////////////////////VpLfJpLuVjLLxMHf///+NNAOBL AP///01q5m6H63CK
62qD6v///////////01o5Udk5EBf5Dpb4zRW4v///////////y1S4i5S3yxN 0x06rf///9I2ANI2
AMgsAMggAKYkAH0OAACrGADGMQDSPwDYSgDgUADjVADc387Z0rna07na0rna 07na07nZ07nZ0rna
0rnZ0rnYz7bZ0bfYz7Tj0qrUjTfITgDnWgDnWgDmWADmWADlVQDlVQDlVQDl VQDlVQDlVQDlVQDl
VQD////2glL4n3n4oXz4mXH4kWf3i2D3hVn2gVP2e031d0b1c0H0bzr0bjj0 bDT0bDL0azHxaTDk
Yiy8TB3////lVQDlVQD////2glL4n3n4oXz4mXH///////////////////// ////////////////
///////0azHxaTDkYiy8TB3////jTQDgSwD///9Sb+d5kex8k+xxiuvCzPf/ //9ZcudTbedNaOVG
ZORBX+Q6W+M4WeP///+tu/MxVeIwU98sTtMdOq3////SNgDSNgDILADIIACs JgB9DgAAqxgAxjEA
0j8A2EoA4FAA41QAy2sA0WsA0G4A0W0A0nID0XEF0W4Az20A0W4Az28A5ZdA z2oA9qJELmr9z28A
y08A51oA51oA5lgA5lgA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA 5VUA5VUA5VUA5VUA
5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA////9oZY +aqJ+a2N+KN/+Jlx
+JNq945k94pe94ZZ9oJU9oBR9XxL9XxK9XhE9XU/9HI68mw042Equ0gY//// 5VUA5VUA////9oZY
+aqJ+a2N+KN/+Jlx+JNq945k94pe94ZZ9oJU9oBR9XxL9XxK9XhE9XU/9HI6 8mw042Equ0gY////
400A4EsA////WHToiZ3ujaHvf5XtcYrraoPqZH3pXnjoWXPnVG/nUW3mS2jl SmjlRGPkP2DkOlzj
NFbgKkzSGDas////0jYA0jYAyCwAyCAArCYAfQ4AAKsYAMEyAMw9ANdHANpT AN9aANV4Ctx/Fdt6
DNt5Cdt5CNx7Ddx8Dtt9Etp5Ctp4CNhyANp3BthzAOd7ANhmAOlcAOdaAOda AOZYAOZYAOZYAOVV
AOVVAOVVAOVVAOVVAOVVAOVVAOVVAOVVAONUAONUAONUAONUAONUAONUAONU AONUAONUAONUAONU
AONUAONUAONUAONUAONUAONUAP////eQZfm0l/q3mvmqifigeviacviVbfiS aPePZfeOYveNYfeK
XfaHWfaDUvZ+TPV3Q/JuN+NfKLlGFf///+FTAOFTAP////eQZfm0l/q3mvmq ifigeviacviVbfiS
aPePZfeOYveNYfeKXfaHWfaDUvZ+TPV3Q/JuN+NfKLlGFf///+BQAOBLAP// /2V/6Zep8Jqs8Ymd
7nqR7HKL622F6miB6WV+6GJ86WF76V136Fl06FJv5kxq5UNj5DdZ4ShK0hUz qv///8s3AMs3AMgs
AMggAKYkAH0OAACrGADBMgDMPQDQRQLaUwDaUwDfWgDkWgDnXgDqYQHpYgDq YQHpYgDrZQHrZQHq
YQHqYQHpYgDqYQHpXgDpXADnWgDnWgDnWgDmWADmWADmWADjVADjVADjVADj VADjVADjVADjVADj
VADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADj VADjVADjVADjVADj
VADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADjVADj VADjVADjVADjVAD/
///4nHb5r5D5spT4p4X4nHX4l273kmj3kGb3jmL3jF/3i172iFn2hVb2glD1 fEn1dT/yazLjXCPF
XDD99vThUwDhUwD////4nHb5r5D5spT4p4X4nHX4l273kmj3kGb3jmL3jF/3 i172iFn2hVb2glD1
fEn1dT/yazLjXCPFXDD99vTgUADgUAD///92jeyQo++UpvCFmu51jetuh+po gepmf+lifOlfeehe
eehZdehWcudQbuZJaOU/YOQyVeAjRtAwS7b99vTLNwDGMQDILAC5IgCmJAB9 DgAApiQAwTIAykEA
0EwB2lMA2lMA31oA5FoA514A6WIA6WIA62UB62UB62UB62UB62UB62UB6WIA 6WIA6mEB6V4A514A
514A51oA51oA51oA5lgA5lgA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA 5VUA5VUA5VUA5VUA
5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA5VUA41QA 41QA41QA41QA41QA
41QA41QA41QA41QA41QA41QA41QA41QA41QA41QA41QA41QA7ryn/eXc+Jpz 94xg9oRV9n5N9XpI
9XZC9XhE9XM+9XM+9XE79XE79Gwz9Gwz9Gow9GQo710f4Gc08tvS7ryn4VMA 4VMA7ryn/eXc+Jpz
94xg9oRV9n5N9XpI9XZC9XhE9XM+9XM+9XE79XE79Gwz9Gwz9Gow9GQo710f 4Gc08tvS7ryn4lAA
4FAA7byn3OH6c4vrYHvpVXHnTWrmSGblQmHkRGPkPl/kPl/kO1zjO1zjM1bi M1biMFPiKE3gH0Xc
NFPQ0tjv7LqnxjEAxjEAwTIAuSIApiQAfQ4AAMEyAMEyAMpBANBMAdpTANpT AN9aAN9aAOdeAOli
AOliAOtlAetlAetlAetlAe1nAO1nAO1nAO1nAOtlAetlAeliAOphAeleAOle AOlcAOdaAOdaAOZY
AOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZYAOZY AOZYAOZYAOZYAOZY
AOZYAOZYAOZYAOZYAOZYAOVcCu69p/329P////////////////////////// ////////////////
/////////////////////+69p+VcCuZYAOZYAOVcCu69p/329P////////// ////////////////
/////////////////////////////////////+68p+NYCuNUAOJQAOBUCu28 p/329P//////////
/////////////////////////////////////////////////////+y6p80/ Css3AMYxAMEyALcq
AKwmAKAVAADBMgDcSgDNSwDaUwDaUwDaUwDfWgDfWgDnXgDpYgDpYgDrZQHt ZwDtZwDtZwDyaQDy
aQDyaQDyaQDtZwDtZwDtZwDtZwDrZQHuYADuYADuYADsXADsXADsXADsXADs XADsXADsXADsXADs
XADsXADsXADsXADsXADsXADsXADsXADsXADsXADsXADsXADsXADsXADsXADs XADsXADsXADsXADs
XADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADp XADpXADpXADpXADp
XADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADpXADp XADpXADpXADpXADn
WgDnWgDnWgDnWgDnWgDnWgDmWADlVQDjVADhUwDhUwDgUADgUADcTQHcTQHc SgDcSgDcSgDYSgDY
SgDYSgDYSgDXRwDXRwDTQwDTQwDSPwDMPQDMPQDMPQDLNwDBMgDBMgCgFQAA ////ykEAzUsA31oA
31oA31oA31oA514A6WIA62UB7WcA8WwC8WwC8WwC9W4D9W4D9W4D9W4D9W4D 9W4D9W4D9W4D9W4D
8WwC9GgD9GgD9GgD9GgD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD 8WUD8WUD8WUD8WUD
8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD 8WUD8WUD8WUD8WUD
8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD8WUD 8WUD8WUD7GMD7GMD
62ED6mEB6V0C6V0C51oA5lgA5lgA5VUA5VUA5VUA41QA41QA41QA4VMA4VMA 4FAA4FAA3E0B3EoA
2EoA10cA10cA2EoA00MAyzcAqxgA////AP///8pBAOJQANpTAOtlAetlAe1n AO1nAO1nAPFsAvVu
A/pvA/50B/1zAP9yA/9yA/50B/1zAP50B/50B/1zAP9yA/50B/1zAP1zAP50 B/5xBv1yB/9yA/9y
A/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9y A/9yA/9yA/9yA/9y
A/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9yA/9y A/5sAf5sAf5sAf5s
Af5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5sAf5s Af5sAf5sAf5sAf5s
Af5sAf5sAf5sAf5sAf9yA/5sAf1zAP9yA/1zAP1zAP1zAP1zAPpqAfllAvRo A/FlA/VgAfJfAPVa
APJfAPJbAPVgAfVgAfJfAO5gAO5gAO5gAOxcAO5gAPJfAOpVAOtYAOtYAOxc AOxcAONUANNDANw9
AP///wD////////QTAHpXQL0ZwbxbAL+dAf/ehP/ehP/ghr/ghr/iSH/iSH/ jSf/kCv/kCv/kCv/
kCv/lDH/lDH/lDH/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/ kCv/kCv/kCv/kCv/
kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/ kCv/kCv/kCv/kCv/
kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/kCv/ kCv/kCv/jSf/jSf/
jSf/kCv/kCv/jSf/jSf/hSP/hSP/hSP/jSf/iSH/iSH/iSH/iSH/iSH/hSP/ iSH/iSH/iSH/iSH/
ghr/ghr/ghr/ghr/ghr/ehP/ehP/ehP9bwf9bwfzWADSOwD///////8A//// ////////0EwB0EwB
9GcG/XIH/3oT/4Ia/4Ia/4Uj/40n/4wx/5Qx/5E6/5E6/5U9/5U9/5c//5c/ /5c//5c//5c//5c/
/5c//5c//5c//5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9 /5U9/5U9/5U9/5U9
/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5c//5c//5c/ /5c//5c//5c//5c/
/5c//5c//5c//5c//5c//5c//5c//5c//5c//5c//5c//5c//5c//5c//5c/ /5c//5c//5c//5c/
/5c//5c//5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9 /5U9/5U9/5U9/5U9
/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5U9/5c//5c//5c//5c/ /5c//5U9/5E6/5U9
/5E6/5U9/5E6/5E6/5E6/5E6/5E6/5E6/5E6/5E6/5E6/4wx/4wx/4wx/4wx /4wx/4wx/4Uj/4Uj
/3oT/GwG0j8AxjEA////////////AP///////////////////81LANBMAdBM AddHANdHANhKANhK
ANhKAOBQAOFTAORaAOdeAORaAOdeAOphAeleAOdaAOlcAOleAOlcAOlcAOlc AOtYAOtYAOtYAOtY
AOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtYAOtY AOtYAOtYAOtYAOtY
AOtYAOtYAOtYAOtYAOtYAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5Y AO5YAO5YAO5YAO5Y
AO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAO5YAOhZ AOhZAOhZAOhZAOhZ
AOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZAOhZ AOhZAOhZAOhZAOhZ
AOhZAOhZAOhZAOtYAOtYAOtYAOtYAO5YAOtYAOtYAOtYAOtYAOtYAOtRAOtR AOVRAOtRAOdLAOVR
AOVRAOdLAOtRAOtLAOdLAONLAORGAORGAONLAOdLAOdLAOtLAOpGANI/AP// ////////////////
/wA=
------=_Part_686_15742640.1132863639163--
Re: PNG icons in ToolBars [message #464576 is a reply to message #464560] Fri, 25 November 2005 10:07 Go to previous messageGo to next message
> about it.
It looks the same on Linux with GTK. So I suppose there is full PNG support
for labels as well on GTK.
BTW: Your code causes some errors here. Instead of
I had to use
Re: PNG icons in ToolBars [message #464578 is a reply to message #464576] Fri, 25 November 2005 10:08 Go to previous messageGo to next message
(uups)
I had to use
ImageData imageData = new ImageData("zoomXPlus-22.png");
Image image = new Image(display, imageData);
label.setImage(image);
to make it work.
Re: PNG icons in ToolBars [message #464639 is a reply to message #464578] Fri, 25 November 2005 17:33 Go to previous messageGo to next message
Yeah, I attached the icon I used (one of yours) but it would have to be in the directory you run the program in to work. I use Class#getResourceAsStream(String) because it allows the code to work within a JAR without modification.
It would seem that both my test results were from a milestone of 3.1 Sorry for the trouble.
Re: PNG icons in ToolBars [message #464693 is a reply to message #464532] Mon, 28 November 2005 21:34 Go to previous messageGo to next message
Jeff Yuan is currently offline Jeff YuanFriend
Member
Question, can you still use the manifest file if you release using JAWS
instead of exe? In other words, how do you package a manifest file for
release?
Re: PNG icons in ToolBars [message #464709 is a reply to message #464693] Tue, 29 November 2005 01:51 Go to previous messageGo to next message
Take a look at the source code for Azureus (azureus.sourceforge.net). They package as an installer, but the manifest isn't installed until the client selects a specific preference setting. I'm assuming that they grab the jre.path property and copy the manifest over (it needs to go in jre\bin). Unless you write some sort of sub-application launcher, you can't actually just run a jar out of the box (so to speak) and have it use Luna. Come to think of it, you can't use SWT using a single jar out of the box.
Re: PNG icons in ToolBars [message #464717 is a reply to message #464709] Tue, 29 November 2005 05:55 Go to previous messageGo to next message
Member
Well, I was not really referring to a Jar, but Java Webstart (JNPL file or
JAWS). I was wondering if that's possible.
Also, related question, I copied the manifest file javaw.exe.manifest, but
Eclipse still doesn't use the Luna look. How come? My own SWT apps do
though.
Re: PNG icons in ToolBars [message #464833 is a reply to message #464717] Wed, 30 November 2005 15:03 Go to previous message
> My own SWT apps do
> hough.
You should check how many different "javaw.exe-files" are installed on your system. If you are using Windows it could be possible that Eclipse uses "javaw.exe" from the WINDOWS_HOME\system32-Directory. In this case you have to copy your manifest-file into the sytem32-Directory.
Previous Topic:Plug or Features
Next Topic:What is this widget?
Current Time: Thu Dec 26 11:22:40 GMT 2024
Powered by FUDForum. Page generated in 0.05653 seconds
