Home » Eclipse Projects » Rich Client Platform (RCP) » Headless Build Problem
Headless Build Problem [message #463065] Mon, 05 February 2007 16:10 Go to next message
Originally posted by: bdberry.us.ibm.com
I am having trouble with the headless product build in Eclipse 3.2.1. I
have followed the instructions provided in the help files but I keep
getting an empty feature.xml in the generated
org.eclipse.pde.build.container.feature directory which ultimately
causes the whole build to fail. I am seeing a bunch of log messages
regarding plugin dependancies as follows...
[eclipse.generateFeature] Some inter-plug-in dependencies have not been
satisfied.
[eclipse.generateFeature] Bundle org.eclipse.birt.chart.cshelp:
[eclipse.generateFeature] Another singleton version selected:
org.eclipse.birt.chart.cshelp_2.2.0.v20061229
[eclipse.generateFeature] Bundle org.eclipse.birt.chart.device.extension:
org.eclipse.birt.chart.device.extension_2.2.0.v20061130
[eclipse.generateFeature] Bundle org.eclipse.birt.chart.device.pdf:
org.eclipse.birt.chart.device.pdf_2.2.0.v20061120-1200
Am I supposed to copy every single Eclipse plugin that I need to my
build directory? The instructions make it seem like setting the Eclipse
home will let the build process find the dependancies aside of my own
plugins/features. However, it seems like it cannot see everything - any
ides?
Re: Headless Build Problem [message #463095 is a reply to message #463065] Tue, 06 February 2007 13:40 Go to previous message
Brian,
It appears that the bundles you are building also exist in your baseLocation.
And the binary versions are being selected in the state. Try using a
baseLocation that does not also have the things you are building.
-Andrew
Brian Berry wrote:
> satisfied.
> ides?
Previous Topic:Cannot export RCP application
Next Topic:EditorContributor: only Constructor is called
Current Time: Sun Sep 14 05:47:50 EDT 2025
Powered by FUDForum. Page generated in 0.04916 seconds
