Home » Eclipse Projects » Rich Client Platform (RCP) » delete-key doesn't work
delete-key doesn't work [message #462823] Thu, 01 February 2007 09:41 Go to next message
Originally posted by: febro.gmx.net
I've created an editor as "normal" eclipse-plugin (within the
eclipse-environment), and everything works fine. Now I want to integrate
this editor into a rcp-application, but the "delete"-key doesn't work
anymore... how can I activate this key? It shall not do anything special,
just the "normal" delete-behaviour as in every other normal text editor.
any hints?
thanks!
Felix
Re: delete-key doesn't work [message #462869 is a reply to message #462823] Thu, 01 February 2007 17:09 Go to previous message
Snjezana Peco is currently offline Snjezana PecoFriend
You have to register the global action handler for your action.
The BasicTextEditorActionContributor can serve as an example.
Snjeza
Felix Brossmann wrote:
> any hints?
> thanks!
> Felix
Previous Topic:Access Classpath from "child" Plugin by "parent" plugin
Next Topic:Problems with TableViewer and ComboboxCellEditors
Current Time: Sat Dec 21 13:55:07 GMT 2024
Powered by FUDForum. Page generated in 0.03085 seconds
