Home » Eclipse Projects » Rich Client Platform (RCP) » Reusing workbench messages
Reusing workbench messages [message #462402] Mon, 29 January 2007 04:23 Go to next message
Where can we find general workbench messages for menu texts, like
"File", "Edit", "Help", etc.
I use ActionFactory where possible, but it doesn't contain all actions.
Thank you.
Patrick
Re: Reusing workbench messages [message #462416 is a reply to message #462402] Mon, 29 January 2007 08:08 Go to previous messageGo to next message
Originally posted by: krzysztofHMMMMdaniel.gmail.com
Hi Patrick
In general there is no something like 'general workbench messages'.
But please look at the org.eclipse.ui.workbench plugin, at the class
WorkbenchMessages.
Please let me know, if this helped you.
Christopher Daniel
Re: Reusing workbench messages [message #462418 is a reply to message #462416] Mon, 29 January 2007 08:16 Go to previous messageGo to next message
Krzysztof Daniel a écrit :
> Hi Patrick
There are however messages for general actions defined in the
ActionFactory class, for example ABOUT, PRINT, SAVE, QUIT, etc.
> WorkbenchMessages.
Not really, because it doesn't contain common action or menu messages
such as File or Help. Also this class has an access restriction
(discouraged access).
Other ideas?
Patrick
Re: Reusing workbench messages [message #462420 is a reply to message #462418] Mon, 29 January 2007 08:28 Go to previous messageGo to next message
plugin org.eclipse.ui.ide, class IDEWorkbenchMessages
Chris
Re: Reusing workbench messages [message #462422 is a reply to message #462420] Mon, 29 January 2007 08:36 Go to previous messageGo to next message
Thanks for your suggestion, Daniel. I had also seen this class, however
it's not in RCP plugins, and I'm reluctant to add the IDE plugin for
only a couple of messages...
I believe that File and Help, for example, are general messages that
should be found in any application, and so belong to RCP plug-in.
Other ideas?
Re: Reusing workbench messages [message #462424 is a reply to message #462402] Mon, 29 January 2007 08:49 Go to previous messageGo to next message
I think you'll find them in the org.eclipse.ui plugin as various command/category names.
Alex.
Re: Reusing workbench messages [message #462431 is a reply to message #462424] Mon, 29 January 2007 09:43 Go to previous messageGo to next message
Thanks Alex, but how do I get the message bundle of org.eclipse.ui
plug-in from my own plug-in?
Re: Reusing workbench messages [message #462432 is a reply to message #462431] Mon, 29 January 2007 10:06 Go to previous messageGo to next message
All messages of the org.eclipse.ui plugin are located in the
plugin.properties file.
If you want to translate the messages to your language, you can download
the Language Pack and use the org.eclipse.ui.nl1 fragment as example.
Snjeza
Re: Reusing workbench messages [message #462443 is a reply to message #462432] Mon, 29 January 2007 11:36 Go to previous messageGo to next message
What I'd like is not to use these messages as an example for my plug-in,
but to _reuse_ them directly.
Is there a ResourceBundle class in org.eclipse.ui plug-in to get
directly the localized messages, or else how can I get an instance of
such a ResourceBundle?
Patrick
Re: Reusing workbench messages [message #462457 is a reply to message #462443] Mon, 29 January 2007 13:06 Go to previous messageGo to next message
There isn't any message bundle in the org.eclipse.ui plugin except the
plugin.properties contains the localized messages from the plugin.xml
file. When you add org.eclipse.ui, you will get its localized messages
directly.
If you want to include IDEWorkbenchMessages, you don't have to include
the org.eclipse.ui.ide plugin. You should only copy IDEWorkbenchMessages
to your plugin.
Snjeza
Re: Reusing workbench messages [message #462533 is a reply to message #462457] Tue, 30 January 2007 04:25 Go to previous messageGo to next message
Hi again,
When I try
Platform.getResourceBundle(Platform.getBundle("org.eclipse.ui "))
or
Platform.getResourceBundle(Platform.getBundle("org.eclipse.ui.nl1 "))
I get an EmptyResouceBundle.
What did I miss, please?
Re: Reusing workbench messages [message #462536 is a reply to message #462533] Tue, 30 January 2007 05:31 Go to previous message
Nevermind, it finally works all right:
Platform.getResourceBundle (Platform.getBundle
("org.eclipse.ui")).getString ("category.file.name")
Previous Topic:using Preferences
Next Topic:Prevent Editor from Closing
Current Time: Tue Sep 16 23:52:29 EDT 2025
Powered by FUDForum. Page generated in 0.07323 seconds
