Home » Eclipse Projects » Rich Client Platform (RCP) » Removing "-k" from default make command
Removing "-k" from default make command [message #462034] Mon, 22 January 2007 17:35 Go to next message
Delicia is currently offline DeliciaFriend
Member
How can I remove the "-k" option from the default build command?
My builder element has 'arguments' set to <blank>, but a new managed make
project still contains 'make -k' as the default.
Delicia.
Re: Removing "-k" from default make command [message #462035 is a reply to message #462034] Mon, 22 January 2007 17:34 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You want eclipse.tools.cdt
Later,
PW
Re: Removing "-k" from default make command [message #462036 is a reply to message #462035] Mon, 22 January 2007 18:37 Go to previous message
Member
Yup, realized just after I hit the Send button! (I've posted it there)
Delicia.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:ep2slv$584$2@utils.eclipse.org...
> Later,
> PW
Previous Topic:XML Editor problem
Next Topic:How to Refresh the UI -Table
Current Time: Wed Jan 15 04:37:37 GMT 2025
Powered by FUDForum. Page generated in 0.02634 seconds
