Home » Eclipse Projects » Rich Client Platform (RCP) » file change events
- file change events [message #460101] Wed, 13 December 2006 11:57 Go to next message
Originally posted by: peter_ossipov.mail.ru
Hi everybody!
Is there a way to add a listener somewhere, so that if an *.xml file is
changed from somewhere I could be notified of it. I mean, I have
searched regarding this and everybody talks about
IResourceChangeListener and some workspaces. But it just confuses me - I
do not have any workspaces - it is just a file somewhere in the file
system, not related to eclipse at all!
So, thanks so much in advance.
- Re: file change events [message #460102 is a reply to message #460101] Wed, 13 December 2006 12:26 Go to previous messageGo to next message
The IResourceChangeListener support (AFAIK) is only effective within an
eclipse workspace.
For regular files, I think you would have to rely on some 3rd party
library, since I don't recall java having the capability.
Later,
PW
- Re: file change events [message #460104 is a reply to message #460101] Wed, 13 December 2006 13:06 Go to previous messageGo to next message
You could create links to the XML Files outside of the eclipse workspace.
Then register a document provider for xml extensions in the plugin.xml.
So, if you have an XML File object, the steps would be:
IFile linkFile = ..// create a File link for the XML File
IEditorInput inp = new FileEditorInput(linkFile);
DocumentProviderRegistry dpr = DocumentProviderRegistry.getDefault();
IDocumentProvider dp = dpr.getDocumentProvider(inp);
dp.connect(inp);
Your registered document provider will be invoked when changes are made to
the underlying
XML file.
Hope this helps
"Peter Osipov" <peter_ossipov@mail.ru> wrote in message
news:elpbcs$1ht$1@utils.eclipse.org...
> Hi everybody!
> changed from somewhere I could be notified of it. I mean, I have searched
> regarding this and everybody talks about IResourceChangeListener and some
> workspaces. But it just confuses me - I do not have any workspaces - it is
> just a file somewhere in the file system, not related to eclipse at all!
- Re: file change events [message #460114 is a reply to message #460104] Thu, 14 December 2006 04:23 Go to previous messageGo to next message
Thanks, Vikram!
Let me try it out!
> dp.connect(inp);
> the underlying
> XML file.
> Hope this helps
>> Hi everybody!
- Re: file change events [message #460115 is a reply to message #460102] Thu, 14 December 2006 04:23 Go to previous messageGo to next message
Thanks Paul again for your answer! :-) You are always there to help us!
> eclipse workspace.
> Later,
> PW
- Re: file change events [message #460116 is a reply to message #460114] Thu, 14 December 2006 05:27 Go to previous messageGo to next message
Huh, I cannot figure out where DocumentProviderRegistry in 3.2
Documentations says org.eclipse.ui.texteditor.DocumentProviderRegistry,
but I have not got this plug-in...
Peter Osipov wrote:> Thanks, Vikram!
> Let me try it out!
>> dp.connect(inp);
>> made to the underlying
>> XML file.
>> Hope this helps
>>> Hi everybody!
>>> is changed from somewhere I could be notified of it. I mean, I have
>>> - I do not have any workspaces - it is just a file somewhere in the
- Re: file change events [message #460118 is a reply to message #460116] Thu, 14 December 2006 05:36 Go to previous messageGo to next message
> Documentations says
> org.eclipse.ui.texteditor.DocumentProviderRegistry, but I have not got
> this plug-in...
It's in org.eclipse.ui.editors which is not officially part of RCP.
Dani
>> Let me try it out!
>>> workspace.
>>> dp.connect(inp);
>>> XML file.
>>> Hope this helps
>>>> Hi everybody!
>>>> file is changed from somewhere I could be notified of it. I mean, I
>>>> have searched regarding this and everybody talks about
>>>> me - I do not have any workspaces - it is just a file somewhere in
- Re: file change events [message #460120 is a reply to message #460118] Thu, 14 December 2006 05:45 Go to previous messageGo to next message
Huh. thanks God, you told me!
Let me try it.
Daniel Megert wrote:
>> Documentations says
>> this plug-in...
> Dani
>>> Let me try it out!
>>>> workspace.
>>>> dp.connect(inp);
>>>> XML file.
>>>> Hope this helps
>>>>> Hi everybody!
- Re: file change events [message #460121 is a reply to message #460120] Thu, 14 December 2006 05:47 Go to previous messageGo to next message
Dani, can you tell me where I can download that plug-in?
> Let me try it.
>>> Documentations says
>>> got this plug-in...
>> Dani
>>>> Let me try it out!
>>>>> workspace.
>>>>> plugin.xml.
>>>>> dp.connect(inp);
>>>>> XML file.
>>>>> Hope this helps
>>>>>> Hi everybody!
>>>>>> I have searched regarding this and everybody talks about
- Re: file change events [message #460123 is a reply to message #460121] Thu, 14 December 2006 05:57 Go to previous message
Either download Eclipse Platform or Eclipse SDK.
Dani
>> Let me try it.
>>>> Documentations says
>>>> got this plug-in...
>>> Dani
>>>>> Let me try it out!
>>>>>> workspace.
>>>>>> plugin.xml.
>>>>>> dp.connect(inp);
>>>>>> are made to the underlying
>>>>>> XML file.
>>>>>> Hope this helps
>>>>>>> Hi everybody!
>>>>>>> mean, I have searched regarding this and everybody talks about
>>>>>>> confuses me - I do not have any workspaces - it is just a file
Previous Topic:Applying TreeViewer Filter for a specific node
Next Topic:Add a progress bar to splash screen in eclipse product
Current Time: Sat Apr 26 15:41:54 EDT 2025
Powered by FUDForum. Page generated in 0.05056 seconds
