Home » Eclipse Projects » Remote Application Platform (RAP) » JS Libraries in RAP
JS Libraries in RAP [message #39110] |
Tue, 17 July 2007 15:31 |
Originally posted by: andreasruempel.gmx.net
I am experimenting with integrating a simple graphical editor in RAP.
Thererfore I wanted to include a javascript graphic library using the
resource mechanism. For little js-files containing custom widgets this
works fine, but e.g. using the Draw2d library
(http://www.openjacob.org/draw2d.html) causes (even without using its
functionality) the workbench not to appear in the browser window. There
is only the blue-white background visible. That is very bad, because
there is no js error message or log entry in the server console.
Does anyone have any experiences with js graphic libraries in connection
with RAP or knows about some further logging, so that the debugging
could become more convenient?
Thanks in advance.
Andi
Re: JS Libraries in RAP [message #39325 is a reply to message #39110] |
Tue, 17 July 2007 19:55 |
Originally posted by: rherrmann.innoopract.com
Andreas,
try to launch you application with the
-Dorg.eclipse.swt.clientLogLevel=ALL
VM argument. Then you should see an error and debug messages in a popup
browser window or in FireBug if installed.
HTH
Rüdiger
Andreas Rümpel wrote:
> Thanks in advance.
> Andi
Re: JS Libraries in RAP [message #42161 is a reply to message #41331] |
Mon, 20 August 2007 10:43 |
I also thought about a naming conflict, but then I took the jsGraphics
library from Walter Zorn: http://walterzorn.de/jsgraphics/jsgraphics.htm
(it is also used by OpenJacob/Draw2D) to render my graphic primitives.
This works fine in some cases. The jsGraphics lib needs a kind of canvas
(a div element) specified to render into: "new jsGraphics(div_id);". I
simply passed an id (e.g. "w23") of a previously constructed RAP widget
for this purpose. In Firefox the lib-generated graphics are rendered
fine (in some of the cases), but in Opera it is never rendered.
In my eyes, the graphics rendering function depends on the existence of
the specified div element, but you cannot ensure this. It works only
"randomly" and looks like a race condition. In the "bad" cases the
graphics have no div element to be rendered into.
Does anybody see the chance to "force" the existence of a div element
representing a specific RAP widget or knows some other solution, to get
the described graphics rendering work?
Thanks!
Andi
FreeGroup schrieb:
> can you post your result.
> Maybe it is a problem of the namespace of the different JavaScript classes.
> Open-jACOB Draw2d has a class called Rectangle, Line, ArrayList....
> these classes are very common. Maybe it is possible to change the
> namespace of Draw2D.
> It is very interesting to integrate Draw2D into RAP......ok,ok it is
> absolute not compareable to the GEF/Draw2D!
> GEF/Draw2D is absolute greate!!
> greetings
> Andreas
> Andreas Rümpel schrieb:
>> Hi,
>> There is only the blue-white background visible. That is very bad,
>> because there is no js error message or log entry in the server console.
>> connection with RAP or knows about some further logging, so that the
>> debugging could become more convenient?
>> Thanks in advance.
>> Andi
Re: JS Libraries in RAP [message #42231 is a reply to message #42161] |
Mon, 20 August 2007 17:55 |
Hi Andreas,
if I got your posting right, the main problem seems to be the id.
qooxdoo does mark its widgets with an (HTML) id attribute. You might
have seen some widget id's but these solely map server-side widget
instances to qooxdoo widgets (the JavaScript objects, not the
corresponding HTML elements).
To integrate a third-party component I would suggest to wrap it into a
qx.ui.embed.HtmlEmbed widget. Within the qooxdoo widget you can set an
id attribute and pass this to the third-party component.
The client-side code could look like this (no tested):
qx.Class.define("org.demo.Canvas", {
extend: qx.ui.embed.HtmlEmbed,
construct : function( canvasId ) {
this.base( arguments );
this.setHtml( "<div id=\"" + canvasId + "\" />" );
this.graphics = new jsGraphics( canvasId );
members {
drawLine : function( fromX, fromY, toX, toY ) {
// call whatever is required to draw a line on 'this.graphics'
However, this is just a raw sketch in the hope to get you started.
Rüdiger
> Thanks!
> Andi
> FreeGroup schrieb:
>> Hi,
>> classes.
>> greetings
>> Andreas
>>> Hi,
>>> this works fine, but e.g. using the Draw2d library
>>> Thanks in advance.
>>> Andi
Re: JS Libraries in RAP [message #42259 is a reply to message #42231] |
Mon, 20 August 2007 18:07 |
confuse the cat ... there is a mistake in the previous post:
qooxdoo does *not* mark its widgets with an (HTML) id attribute
(see the asterisk marked line below)
Sorry for the noise
Rüdiger
Rüdiger Herrmann wrote:
> Hi Andreas,
> qooxdoo does ***not*** mark its widgets with an (HTML) id attribute. You might
> members {
> Cheers,
> Rüdiger
>> Hi,
>> http://walterzorn.de/jsgraphics/jsgraphics.htm (it is also used by
>> OpenJacob/Draw2D) to render my graphic primitives. This works fine in
>> some cases. The jsGraphics lib needs a kind of canvas (a div element)
>> specified to render into: "new jsGraphics(div_id);". I simply passed
>> an id (e.g. "w23") of a previously constructed RAP widget for this
>> purpose. In Firefox the lib-generated graphics are rendered fine (in
>> of the specified div element, but you cannot ensure this. It works
>> only "randomly" and looks like a race condition. In the "bad" cases
>> the graphics have no div element to be rendered into.
>> get the described graphics rendering work?
>> Thanks!
>> Andi
>> FreeGroup schrieb:
>>> Hi,
>>> classes.
>>> greetings
>>> Andreas
>>>> Hi,
>>>> RAP. Thererfore I wanted to include a javascript graphic library
>>>> using the resource mechanism. For little js-files containing custom
>>>> widgets this works fine, but e.g. using the Draw2d library
>>>> its functionality) the workbench not to appear in the browser
>>>> window. There is only the blue-white background visible. That is
>>>> very bad, because there is no js error message or log entry in the
>>>> server console.
>>>> Thanks in advance.
>>>> Andi
Re: JS Libraries in RAP [message #42310 is a reply to message #42231] |
Mon, 20 August 2007 18:13 |
thanks for the hint. I think the problem was, that I wanted to render
some graphical stuff while or directly after constructing the widget.
But when starting the rendering later, e.g. caused by a mouse event, the
graphics are rendered well in all browsers.
Andi
> Hi Andreas,
> members {
> Cheers,
> Rüdiger
>> Hi,
>> Thanks!
>> Andi
Re: JS Libraries in RAP [message #42381 is a reply to message #42310] |
Tue, 21 August 2007 07:32 |
when your code relies on the fact that a qooxdoo widget was created
completely, you might use a workaround like the on in the 'focus'
function in WidgetManager.js (starts in line 251).
Cheers
Rüdiger
> Andi
>> Hi Andreas,
>> members {
>> Cheers,
>> Rüdiger
>>> Hi,
>>> jsGraphics library from Walter Zorn:
>>> Thanks!
>>> Andi
Re: JS Libraries in RAP [message #42787 is a reply to message #39110] |
Wed, 22 August 2007 10:30 |
Originally posted by: giuliapo.gmail.com
Hi there. I read all the threads about the javascript graphics library
and I'm also trying to use one. But my only problem until now is that I
just can't get the css file from the javascript to load.
Error in firebug: GET http://localhost:8081/jsCharts.css 404 (27ms)
The jsCharts.js is in the exact same folder as the jsCharts.css and
added to the project.
I have already tried to add it as a resource but nothing. Probably it
isn't supposed to be a resource as the javascript file is.
Do you have any ideas?
Many thanks in advance,
Bruno.
> Thanks in advance.
> Andi
Re: JS Libraries in RAP [message #43761 is a reply to message #42787] |
Wed, 29 August 2007 07:39 |
Bruno,
in order to make the css file accessible for the browser you have to
register it. Resource requests such as obtaining a css file aren't
served by RAP itself, but by the HttpService.
Therefore you have to register those resources to let the HttpService
know that it should deliver them.
You can use the org.eclipse.rap.ui.resources extension point to register
resources.
Rüdiger
> Bruno.
>> Hi,
>> Thanks in advance.
>> Andi
Re: JS Libraries in RAP [message #45591 is a reply to message #42381] |
Fri, 07 September 2007 02:54 |
No real name Messages: 9 Registered: July 2009 |
I attempt to create a widget use OpenJacob/Draw2D(with_namespace), There was
no Javascript errors and no figure was showed.
Waiting replys online, Thanks.
qx.Class.define( "org.eclipse.org.rap.rwt.draw2d.Draw2D", {
//extend: qx.ui.layout.CanvasLayout,
construct: function( id ) {
this.setHtml( "<div id=\"" + id + "\" />" );
//this.setHtmlAttribute( "id", id );
this._id = id;
this._canvas = null;
destruct : function() {
members : {
load : function() {
qx.ui.core.Widget.flushGlobalQueues();
if( this._canvas == null ) {
this._canvas = new draw2d.Canvas( document.getElementById( this._id ) );
var canvas = this._canvas;
var oval= new draw2d.Oval();
oval.setDimension(100,40);
oval.setBackgroundColor(new draw2d.Color(255,0,0));
canvas.addFigure(oval,130,180);
"R
Re: JS Libraries in RAP [message #45651 is a reply to message #45591] |
Fri, 07 September 2007 08:30 |
Tiago Messages: 55 Registered: July 2009 |
Member |
Hi, why don't you extend CanvasLayout insted of HtmlEmbed? I personaly had
more success with CanvasLayout when creating a widget. Also I don't know the
draw2d framework but wouldn't the following line
be
new draw2d.Canvas( this._id );
Hope it helps.
Tiago
"toolang" <toolang@gmail.com> wrote in message
news:fbqeh9$a1r$1@build.eclipse.org...
> was no Javascript errors and no figure was showed.
> this._id = id;
> members : {
> load : function() {
> this._id ) );
> "R
Re: JS Libraries in RAP [message #45710 is a reply to message #45591] |
Fri, 07 September 2007 13:14 |
just from reading the code there are two things that look suspicious.
First I would think you need to set the size and position of the
manually created div element. As it has no connection to qooxdoo you
also would have to resize it when the qooxdoo widget changes its size.
The JSDoc of draw2d lacks documentation for teh constructor but lists it
like "draw2d.Canvas( canvasId )". It seems that draw2d expects the
element id, not the element itself to be passed to the constructor:
this._canvas = new draw2d.Canvas( this._id ) );
Given this you could also switch back to using CanvasLayout as this
would free you from maintaining the size of your self-created div
element. Creating the draw2d Canvas then could look like this
this._canvas = new draw2d.Canvas( this.getElement() ) );
Rüdiger
toolang wrote:
> this._id = id;
> members : {
> load : function() {
> "Rüdiger Herrmann" <rherrmann@innoopract.com> ????
> news:fae4f9$2f3$1@build.eclipse.org...
>> completely, you might use a workaround like the on in the 'focus' function
>> Cheers
>> Rüdiger
>>> Hi,
>>> some graphical stuff while or directly after constructing the widget. But
>>> Andi
>>>> Hi Andreas,
>>>> members {
>>>> Cheers,
>>>> Rüdiger
>>>>> Hi,
>>>>> specified to render into: "new jsGraphics(div_id);". I simply passed an
>>>>> Thanks!
>>>>> Andi
Re: JS Libraries in RAP [message #45740 is a reply to message #45710] |
Fri, 07 September 2007 13:19 |
sorry, there is a mistake in the previous post. Please see below.
the line above is wrong, instead:
this.setHtmlProperty( "id", this._id );
this._canvas = new draw2d.Canvas( this._id );
> Cheers,
> Rüdiger
> toolang wrote:
>> Hi,
>> There was no Javascript errors and no figure was showed.
>> this._id = id;
>> members : {
>> load : function() {
>> this._id ) );
>>> Cheers
>>> Rüdiger
>>>> Hi,
>>>> render some graphical stuff while or directly after constructing the
>>>> widget. But when starting the rendering later, e.g. caused by a
>>>> mouse event, the graphics are rendered well in all browsers.
>>>> Andi
>>>>> Hi Andreas,
>>>>> into a qx.ui.embed.HtmlEmbed widget. Within the qooxdoo widget you
>>>>> can set an id attribute and pass this to the third-party component.
>>>>> members {
>>>>> Cheers,
>>>>> Rüdiger
>>>>>> Hi,
>>>>>> in some cases. The jsGraphics lib needs a kind of canvas (a div
>>>>>> widget for this purpose. In Firefox the lib-generated graphics are
>>>>>> rendered fine (in some of the cases), but in Opera it is never
>>>>>> rendered.
>>>>>> existence of the specified div element, but you cannot ensure
>>>>>> this. It works only "randomly" and looks like a race condition. In
>>>>>> the "bad" cases the graphics have no div element to be rendered into.
>>>>>> element representing a specific RAP widget or knows some other
>>>>>> solution, to get the described graphics rendering work?
>>>>>> Thanks!
>>>>>> Andi
Re: JS Libraries in RAP [message #47324 is a reply to message #45591] |
Mon, 17 September 2007 17:28 |
Hi toolang,
I found a quite good solution for my graphical editor problem and maybe
it is also helpful for you.
First, I created a canvas widget extending qx.ui.layout.CanvasLayout and
gave it a special unique id using setHtmlAttribute(). Then, invisible
container widgets (also extending qx.ui.layout.CanvasLayout) are created
having special incremental ids. Those ids of the container widgets are
used to render the jsGraphics-shapes (from the wz library, that is used
in OpenJacob/Draw2D) into. Each of the containers is added via add() to
the "canvas". The trick is to "pool" one container in advance before the
next "graphical widget" is created, so that the graphics library can
render in the previously generated "container div" whose existence is
ensured then. This works, because the creation of the graphical widgets
in my application is triggered by mouse interaction. So the container
widgets have the "time they need" to be created as DIV elements, whose
existence is required by the graphical library.
The widget structure is the following:
canvas DIV with id="canvas"
+--container DIV with id="foobar1"
| +--graphical shape DIVs generated by library
+--container DIV with id="foobar2"
"foobar1" is created during initialization. When the contents for
"foobar1" should be placed, it is existing already and in the same step
the "foobar2"-DIV is being prepared for its future contents.
Andi
Current Time: Sat Oct 19 14:40:32 GMT 2024
Powered by FUDForum. Page generated in 0.04770 seconds
