Bug in headless pde build? [message #453348] |
Thu, 27 July 2006 07:22 |
Originally posted by: azachar.simpleway.cz
Hello!
I am trying to build simple eclipse plugin with eclipse.pde.build.
If i run antRunner using command line i get following error:
BUILD FAILED
/opt/eclipse32/plugins/org.eclipse.pde.build_3.2.0.v20060603 /scripts/genericTargets.xml:80:
A cycle was detected when generating the classpath
cz.simpleway.plugin_0.1.1.0, org.eclipse.ui_3.2.0.I20060605-1400,
org.eclipse.core.runtime_3.2.0.v20060603,
org.eclipse.equinox.registry_3.2.0.v20060601, cz.simpleway.plugin_0.1.1.0.
I wonder why org.eclipse.equinox.registry... depends on my plugin and
also why i'm able to build application without any problems using export
feature in eclipse ui. Thus it seems to be a bug.
May be this bug is due to custom pluginPath settings. (My plugin depends
on thirdy party plugins, which are installed in extension locations and
of course which are included in pluginPath variable in build.properties)
Thanks for advices.
Andrej Zachar
FUDForum. Page generated in 0.03259 seconds
