Home » Eclipse Projects » Standard Widget Toolkit (SWT) » AWT component into SWT image
AWT component into SWT image [message #443938] |
Mon, 04 October 2004 14:39  |
I'm trying to make a snapshot of an AWT component and convert it into a
SWT image. All of this should happen offscreen, so I cannot embed the AWT
component into SWT canvas and then take a screenshot.
Also, I didn't get any reasonable content at all (only black), when I
tried to create a java.awt.image.BufferedImage image and use
awtComponent.paint(image.getGraphics()).
How can I do this? My apologies if the question is slightly off topic.
Jaakko Lindvall
Re: AWT component into SWT image [message #444446 is a reply to message #443938] |
Tue, 12 October 2004 19:00   |
--------------050008090608050005030402
I saw the snippets referred to by the other posters for creating SWT
images from AWT images. They looks interesting, if not complex. I've
implemented similar routines for converting AWT images to SWT. I use one
adaptor for opaque images and another for images with an alpha channel.
You may find these easier to use than the other snippets.
Both the RGB and ARGB adaptors share a common superclass:
import java.awt.image.BufferedImage;
import org.eclipse.swt.graphics.Image;
public abstract class ImageAdaptor extends BufferedImage
public ImageAdaptor(int inWidth, int inHeight, int inType)
super(inWidth, inHeight, inType);
public abstract Image toSwtImage();
The idea is that you create an adaptor, which is an AWT image, draw to
it, and then take an SWT snapshot. Here is the RGB implementation:
import java.awt.Graphics;
import java.awt.image.DataBufferByte;
import java.awt.image.WritableRaster;
import org.eclipse.swt.graphics.ImageData;
import org.eclipse.swt.graphics.PaletteData;
public final class RgbImageAdaptor extends ImageAdaptor
public RgbImageAdaptor(int inWidth, int inHeight)
super(inWidth, inHeight, BufferedImage.TYPE_3BYTE_BGR);
public Image toSwtImage()
int vnWidth = getWidth();
int vnHeight = getHeight();
int vnDepth = 24;
PaletteData vpPalette = new PaletteData(0xff, 0xff00, 0xff0000);
int vnScanlinePad = vnWidth * 3;
WritableRaster vpRaster = getRaster();
DataBufferByte vpBuffer = (DataBufferByte) vpRaster.getDataBuffer();
byte[] vabData = vpBuffer.getData();
ImageData vpImageData = new ImageData(vnWidth, vnHeight, vnDepth, vpPalette, vnScanlinePad, vabData);
Image vpImage = new Image(Display.getDefault(), vpImageData);
return vpImage;
The above class is an AWT image. To make use of it, simply instantiate
one and draw on it (using ordinary AWT drawing techniques). You can even
paint Swing components on this image! Then, when you're ready, just call
|toSwtImage()| and you've got an SWT image!
On the other hand, if all you want to do is convert an already existing
AWT image, just use this helper::
public static Image toSwt(java.awt.Image ipImage)
RgbImageAdaptor vpAdaptor = new RgbImageAdaptor(ipImage.getHeight(null), ipImage.getWidth(null));
Graphics vpG = vpAdaptor.getGraphics();
vpG.drawImage(ipImage, 0, 0, null);
vpG.dispose();
return vpAdaptor.toSwtImage();
I've been using the above code; it works. Now here's the answer to your
question. I suppose you could adapt this code to draw a Swing component
just as easily. /Just make sure you're component has been sized first,
or you may get all black pixels!/
// Warning: Untested code:
public static Image toSwt(Component ipComponent)
RgbImageAdaptor vpAdaptor = new RgbImageAdaptor(ipComponent.getWidth(), ipComponent.getHeight());
ipComponent.paint(vpG);
vpG.dispose();
As I mentioned earlier, I also have an image converter for images with
transparency. This also works, but is much slower:
public final class ArgbImageAdaptor extends ImageAdaptor
public ArgbImageAdaptor(int inWidth, int inHeight)
super(inWidth, inHeight, BufferedImage.TYPE_4BYTE_ABGR);
// This implementation is horribly unoptimized.
int vnDepth = 32;
int vnScanlinePad = vnWidth * vnDepth / 8;
WritableRaster vpAlphaRaster = getAlphaRaster();
DataBufferByte vpAlphaBuffer = (DataBufferByte) vpAlphaRaster.getDataBuffer();
byte[] vabAlphaData = vpAlphaBuffer.getData();
for (int vnX = 0; vnX < vnWidth; ++ vnX)
for (int vnY = 0; vnY < vnHeight; ++ vnY)
vpImageData.setAlpha(vnX, vnY, 0xff & vabAlphaData[(vnY * vnWidth + vnX) * 4]);
return vpImage;
I've been using these adaptors for quite some time and have never had
any problems with them. They make it really easy to draw in Swing and
show in SWT. I hope you find them useful. I would also appreciate public
comment on these.
> a SWT image. All of this should happen offscreen, so I cannot embed
> the AWT component into SWT canvas and then take a screenshot.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
<p>I saw the snippets referred to by the other posters for creating SWT
implemented similar
routines for converting AWT images to SWT. I use one adaptor for opaque
Re: AWT component into SWT image [message #466203 is a reply to message #444446] |
Wed, 04 January 2006 14:56  |
thanks for the codesnippet. It was very useful. But I got a black
background.
I used your code to convert an awt image (based on a gif) to a swt
image. The result is pretty good, except the background. I guess, the
problem might be within the convertion of the transparency.
If you have any idea how solve this, I'd appreciate this.
Florian
> import org.eclipse.swt.widgets.Display;
> int vnDepth = 24;
> return vpImage;
> vpG.dispose();
> vpG.dispose();
> int vnDepth = 32;
> return vpImage;
> comment on these.
Current Time: Sun Sep 14 03:56:55 EDT 2025
Powered by FUDForum. Page generated in 0.04692 seconds
