Home » Eclipse Projects » Rich Client Platform (RCP) » Classpath problem when exporting RCP app
Classpath problem when exporting RCP app [message #437994] Tue, 11 October 2005 09:20 Go to next message
Martin is currently offline MartinFriend
Member
my RCP app consists of a functionality plug-in and an
application-launching plug-in. The former depends on an external .jar
file I added to the project's Java Build Path. Now I want to export the
application as an eclipse product. I added the .jar to Extra Classpath
Entries in plugin.xml and had to remove it from the Java Build Path
(double referencing -> build error). Now I can export my product without
errors, but the .jar is not exported to the .zip file; so when my code
uses a class from the .jar a NoClassDefError is thrown. The same happens
when I run the app from within eclipse with the launch config that used
to work prior to the changes described above.
I guess I've done something wrong, added the .jar in the wrong place or
something like that. Can anyone give me advice on this?
Thanks & regards,
Martin
Re: Classpath problem when exporting RCP app [message #437996 is a reply to message #437994] Tue, 11 October 2005 10:01 Go to previous messageGo to next message
arne anka is currently offline arne ankaFriend
make a plugin from the jar and add it to the dependencies. how to do is
explained several times in the list-archive (www.eclipsezone.com/forums/).
basically it comes down to new -> other -> "plug-in from existing jar
archives".
Re: Classpath problem when exporting RCP app [message #438039 is a reply to message #437996] Tue, 11 October 2005 11:51 Go to previous messageGo to next message
Member
> (www.eclipsezone.com/forums/). basically it comes down to new -> other
> -> "plug-in from existing jar archives".
Thanks a lot, that worked fine :) I was not aware that creating a
jar-wrapping plug-in was so easy.
Martin
Re: Classpath problem when exporting RCP app [message #438040 is a reply to message #438039] Tue, 11 October 2005 11:57 Go to previous message
> I was not aware that creating a jar-wrapping plug-in was so easy.
me too -- until i tried it for the first time ;-)
Previous Topic:How to use Platfrom Images without the discouraged access warning?
Next Topic:exporting product for WebStart
Current Time: Mon Jan 13 20:43:39 GMT 2025
Powered by FUDForum. Page generated in 0.06721 seconds
