Home » Eclipse Projects » Rich Client Platform (RCP) » unable to build RCP
unable to build RCP [message #436873] Mon, 19 September 2005 14:38 Go to next message
Eric Suen is currently offline Eric SuenFriend
Member
I try build RCP myself, but got error:
set JAVA_HOME=D:\jdk1.4
set PATH=%JAVA_HOME%\bin;D:\tools\infozip;D:\Program Files\cvsnt
%JAVA_HOME%\bin\java -cp ..\org.eclipse.releng.basebuilder\startup.jar
org.eclipse.core.launcher.Main
-application org.eclipse.ant.core.antRunner
-buildfile build.xml -Dcomponent=rcp -Dconfigs="win32,win32,x86"
-DjavacDebugInfo=off -Djavacfailonerror=true -DjavacVerbose=false
-DbuildType=R -DmapVersionTag=R3_1 -DbuildDirectory=G:\eclipse
-DbaseLocation=G:\tmp -Dbaseos=win32 -Dbasews=win32 -Dbasearch=x86
-Dbootclasspath=D:\jdk1.4\jre\lib\rt.jar
F:\tmp\eclipse\workspace\org.eclipse.releng.eclipsebuilder\b uild.xml:27: The
following error occurred while executing this line:
F:\tmp\eclipse\workspace\org.eclipse.releng.basebuilder\plug ins\org.eclipse.pde.build_3.1.0\scripts\build.xml:22:
The following error occurred while executing this line:
F:\tmp\eclipse\workspace\org.eclipse.releng.basebuilder\plug ins\org.eclipse.pde.build_3.1.0\scripts\build.xml:54:
F:\tmp\eclipse\workspace\org.eclipse.releng.eclipsebuilder\r cp\customTargets.xml:157:
F:\tmp\eclipse\workspace\org.eclipse.releng.basebuilder\plug ins\org.eclipse.pde.build_3.1.0\scripts\genericTargets.xml:6 7:
org.eclipse.core.runtime.CoreException: Unable to find element:
org.eclipse.swt.tools.
org.eclipse.swt.tools I can find in folder: ${buildDirectory}\plugins
can anyone tell me what is wrong....
Eric
Re: unable to build RCP [message #436883 is a reply to message #436873] Mon, 19 September 2005 18:08 Go to previous messageGo to next message
Member
Does this auto-build things really works? for example:my previous error,
after debug, I found it failed because it require plugins
"org.eclipse.core.runtime.compatibility", first, why RCP need that?
second, if really need, why the script not check out it, after I
manually add it to baseLocation, the builder now has new problem:
F:\tmp\eclipse\workspace\org.eclipse.releng.eclipsebuilder\r cp\customTargets.xml:176:
Warning: Could not find file
G:\eclipse\plugins\org.eclipse.swt.motif.linux.x86\about_lau ncher_libraries.html
to copy.
this is because
getFromCVS:
[cvs] cvs export: cwd=G:\eclipse\plugins ,current=G:\eclipse\plugins
[cvs] cvs server: cannot find module
`org.eclipse.swt.motif.linux.x86/fragment.xml' - ignored
[cvs] cvs [export aborted]: cannot expand modules
can anyone help?
Re: unable to build RCP [message #436884 is a reply to message #436883] Mon, 19 September 2005 18:55 Go to previous messageGo to next message
Alex Blewitt is currently offline Alex BlewittFriend
For some reason, you're using a Windows system to build something that's configured to use a Linux SWT implementation. It's possible that you're just copying this from a book or website that is set up to use Linux.
You'll need to change any references to 'motif' and 'linux' to 'win32' and 'win32'.
Re: unable to build RCP [message #436915 is a reply to message #436884] Tue, 20 September 2005 02:37 Go to previous message
Member
> 'win32'.
I don't think so, according org.eclipse.releng.eclipsebuilder/readme.html,
the only thing I
need is check out org.eclipse.releng.basebuilder and
org.eclipse.releng.eclipsebuilder, and
add zip, unzip, jre\bin to PATH, and my build command is:
I can't find anything about 'linux' & 'motif', if the build if really
automatic, I not suppose to modifed anything check out, it should
control by some paramaters. Besides, according readme, you can build
linux component on Windows, bacause it is all about java things, you
don't need a c/c++ compiler, that means all native lib is prebuild,
and according the message:
getFromCVS:
it seems something missing in server, so, is this the auto-build bug?
Previous Topic:Workbench ActionFactory and i18n
Next Topic:Hibernate + Spring + RCP hibernate error
Current Time: Fri Dec 27 02:31:54 GMT 2024
Powered by FUDForum. Page generated in 0.04889 seconds
