Home » Modeling » Epsilon » [HUTN] Null value on a reference
Re: [HUTN] Null value on a reference [message #415 is a reply to message #409] |
Mon, 13 October 2008 13:37 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Pau,
useCase is a multi-valued feature (collection). Why would you need to
set it to null? If you don't specify a value for it at all in HUTN, it
should be left empty by default.
Dimitrios
Pau Giner wrote:
> Hello,
> is there any way of indicating in HUTN that a reference is empty?
> I tried unsuccessfully different options ( null, OclUndefined, none,
> nil, etc.) being null the one that provides a non-standard error
> message. With null I get the following error (trying to assign the
> useCase attribute of a UML Class to null):
> org.eclipse.epsilon.hutn.exceptions.HutnTranslationException : Property
> 'values' not found in object
> org.eclipse.epsilon.hutn.model.hutn.impl.NullSlotImpl@1f36902 [line: 0,
> col: 0] [feature: useCase] (262:21)
> Thanks.
Re: [HUTN] Null value on a reference [message #420 is a reply to message #415] |
Mon, 13 October 2008 13:46 |
Louis Rose Messages: 440 Registered: July 2009 Location: York, United Kingdom |
Hi Pau,
As Dimitrios mentions, the following HUTN will produce a model
containing a single class whose useCase feature is empty:
@Spec {
metamodel "UML" {
nsUri: "http://www.eclipse.org/uml2/2.1.0/UML"
UML {
Class {
(If you receive an error about required features not being specified,
please run HUTN from source, as described here:
http://www.eclipse.org/gmt/epsilon/doc/EpsilonSVN.pdf)
Louis.
Dimitrios Kolovos wrote:
> Hi Pau,
> Cheers,
> Dimitrios
> Pau Giner wrote:
>> Hello,
>> 0, col: 0] [feature: useCase] (262:21)
>> Thanks.
Re: [HUTN] Null value on a reference [message #870 is a reply to message #415] |
Mon, 13 October 2008 15:43 |
Pau Giner Messages: 18 Registered: July 2009 |
Ok, the problem was more a conceptual issue (stating something
explicitly), than a practical problem. In this case I can always write
it as a comment and obtain the same effect ;-)
Dimitrios Kolovos escribió:
> Hi Pau,
> Cheers,
> Dimitrios
> Pau Giner wrote:
>> Hello,
>> Thanks.
Pau Giner Blasco
Centro de Investigación en Métodos de Producción de Software
Universidad Politécnica de Valencia
Camí de Vera, s/n 46022 Valencia
Office 2L04. Building 1F
e-mail: pginer@pros.upv.es
web: http://www.dsic.upv.es/~pginer/
Re: [HUTN] Null value on a reference [message #560965 is a reply to message #409] |
Hi Pau,
Dimitrios
Pau Giner wrote:
> Hello,
> Thanks.
Re: [HUTN] Null value on a reference [message #560978 is a reply to message #415] |
Hi Pau,
@Spec {
metamodel "UML" {
UML {
Class {
Louis.
> Hi Pau,
> Cheers,
> Dimitrios
> Pau Giner wrote:
>> Hello,
>> Thanks.
Re: [HUTN] Null value on a reference [message #561014 is a reply to message #415] |
> Hi Pau,
> Cheers,
> Dimitrios
> Pau Giner wrote:
>> Hello,
>> Thanks.
Pau Giner Blasco
Current Time: Sat Jul 27 18:32:41 GMT 2024
Powered by FUDForum. Page generated in 0.05285 seconds
