Home » Archived » GEF3D » Some refactoring, standalone draw3d viewers.
Re: Some refactoring, standalone draw3d viewers. [message #4422 is a reply to message #3884] |
Wed, 03 June 2009 01:04 |
Miles Parker Messages: 1341 Registered: July 2009 |
On 2009-06-02 16:13:02 -0700, Kristian Duske
<kristian.duske@fernuni-hagen.de> said:
> Hi everyone,
> just a quick pointer that I have refactored some gef3d and draw3d code.
> I have created a new plugin called org.eclipse.draw3d.ui, which you
> need to check out (from eclipse.org) in order to compile everything the
> next time you update (if you are using SVN Head).
Nice.. The whole IEditPart vs. IViewPart thing is really a relic at
this point. I find views to be much more suitable for a lot of stuff.
> This was neccessary in order to support standalone draw3d viewers with
> a working camera without duplicating lots of code. I will check in
> another project containing the base classes and an example
> implementation of such a viewer soon.
I just wrote one as well, but it's tied into all of the AGF pieces.
Found it really simple to do though. Unfortuntaly I don't have my CQs
for initial contributions in yet so I can't point to the code. But see
below..
For camera all I needed was to
CameraTool camera = new CameraTool();
getEditDomain().setActiveTool(camera);
> Miles: I will work on shapes after I finished the draw3d viewer. I will
> add cones and cylinders first. Is there anything in particular that you
> need?
Thanks for asking. :)
One thing that I'd like though I don't know if it would be useful for
anyone else is the ability to supply a 2D figure and then either rotate
it or
> Oh, and I have implemented the 3.5 Graphics methods, but will not
> commit this until 3.5 is out. If you need patches against current SVN
> for this, let me know.
The obvious hacks are working just fine.. I'm away for a week or so, btw..
package org.eclipse.amp.agf3d;
import org.eclipse.amp.agf.gef.EditPartListener;
import org.eclipse.amp.agf.gef.EditPartViewPart;
import org.eclipse.amp.axf.view.IModelPart;
import org.eclipse.gef.EditPartViewer;
import org.eclipse.gef.RootEditPart;
import org.eclipse.gef3d.preferences.ScenePreferenceListener;
import org.eclipse.gef3d.tools.CameraTool;
import org.eclipse.gef3d.ui.parts.GraphicalViewer3DImpl;
import org.eclipse.gef3d.ui.parts.IScene;
import org.eclipse.swt.widgets.Composite;
public class GEF3DViewPart extends EditPartViewPart {
* The preference listener for this editor.
protected ScenePreferenceListener sceneListener;
public void createPartControl(Composite parent) {
super.createPartControl(parent);
parent.addDisposeListener(((GraphicalViewer3DImpl)
viewer).getLightweightSystem3D());
if (viewer instanceof IScene) {
sceneListener = new ScenePreferenceListener((IScene) viewer);
sceneListener.start();
EditPartListener rootListener;
public void createModelListeners() {
if (viewer.getContents() instanceof IModelPart) {
((IModelPart) viewer.getContents()).createModelListeners();
protected void createZoomer(RootEditPart rootEditPart) {
protected EditPartViewer createViewer() {
return new GraphicalViewer3DImpl();
* {@inheritDoc}
* @see org.eclipse.gef.ui.parts.GraphicalEditor#dispose()
public void dispose() {
if (sceneListener != null) {
sceneListener.stop();
super.dispose();
[Note for below ModelViewPart can be ignored -- it does some AGF stuff
and extends ViewPart implements IPropertyChangeListener.]
* <copyright>
* Copyright (c) 2009 Metascape, LLC.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Metascape - Initial API and Implementation
* </copyright>
package org.eclipse.amp.agf.gef;
import java.util.Collections;
import java.util.List;
import org.eclipse.amp.axf.view.ModelViewPart;
import org.eclipse.draw2d.IFigure;
import org.eclipse.gef.DefaultEditDomain;
import org.eclipse.gef.EditPart;
import org.eclipse.gef.GraphicalEditPart;
import org.eclipse.gef.editparts.ScalableFreeformRootEditPart;
import org.eclipse.gef.editparts.ZoomManager;
import org.eclipse.gef.ui.parts.ScrollingGraphicalViewer;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.jface.viewers.ISelectionProvider;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.StructuredSelection;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.ui.IEditorInput;
import org.eclipse.ui.IWorkbenchPart;
public abstract class EditPartViewPart extends ModelViewPart {
private final class PropertySelectionListener implements
ISelectionChangedListener {
public void selectionChanged(SelectionChangedEvent event) {
if (!event.getSelection().isEmpty() && event.getSelection()
instanceof StructuredSelection) {
StructuredSelection sel = (StructuredSelection)
event.getSelection();
propertySheetPage.selectionChanged(EditPartViewPart.this, new
StructuredSelection(sel
.getFirstElement()));
private DefaultEditDomain editDomain;
protected EditPartViewer viewer;
private EditPartListener rootListener;
public static double[] ZOOM_LEVELS = { .125, .25, .5, .75, 1.0,
1.25, 1.5, 2.0, 2.5, 3, 4, 6, 8 };
private ZoomManager zoomer;
private PropertySelectionListener selectionListener;
public EditPartViewPart() {
super();
setEditDomain(new DefaultEditDomain(null));
viewer = createViewer();
viewer.createControl(parent);
getEditDomain().addViewer(viewer);
createSelectionListener(viewer);
protected void createSelectionListener(ISelectionProvider provider) {
super.createSelectionListener(provider);
selectionListener = new PropertySelectionListener();
provider.addSelectionChangedListener(selectionListener);
return new ScrollingGraphicalViewer();
public void setInput(IEditorInput input) {
super.setInput(input);
final ModelEditPartInput mInput = (ModelEditPartInput) input;
// setPartName(getName());
if (input != null) {
RootEditPart rootEditPart = mInput.getRootEditPart();
if (rootEditPart != null) {
viewer.setRootEditPart(rootEditPart);
createZoomer(rootEditPart);
viewer.setEditPartFactory(mInput.getFactory());
viewer.setContents(getModel());
} else {
// viewer.setContents(null);
if (rootEditPart instanceof ScalableFreeformRootEditPart) {
zoomer = ((ScalableFreeformRootEditPart)
rootEditPart).getZoomManager();
zoomer.setZoomLevels(ZOOM_LEVELS);
zoomer.setZoomLevelContributions(Collections.singletonList(Z oomManager.FIT_ALL));
super.createModelListeners();
rootListener = new EditPartListener(viewer.getControl(),
getEditPart());
rootListener.setWaitForPaint(false);
addModelListener(rootListener);
viewer.getControl().addPaintListener(new PaintListener() {
public void paintControl(PaintEvent e) {
rootListener.endPainting();
public EditPart getEditPart() {
List children = viewer.getRootEditPart().getChildren();
if (children.size() > 0) {
return (EditPart) children.get(0);
return null;
public Object getAdapter(Class type) {
if (type == ISelectionProvider.class) {
return getViewer();
if (type == EditPartViewer.class) {
return getViewer();
// TODO -- this should really be the child..
if (type == EditPart.class && getViewer() != null) {
return getViewer().getRootEditPart();
if (type == IFigure.class && getViewer() != null) {
return ((GraphicalEditPart)
getViewer().getRootEditPart()).getFigure();
if (type == ZoomManager.class) {
return getZoomer();
return super.getAdapter(type);
public EditPartViewer getViewer() {
return viewer;
public EditPartListener getRootListener() {
return rootListener;
* Sets the EditDomain for this EditorPart.
* @param ed
* the domain
protected void setEditDomain(DefaultEditDomain ed) {
this.editDomain = ed;
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
super.dispose();
removeSelectionListener(viewer);
((ISelectionProvider)
viewer).removeSelectionChangedListener(selectionListener);
* Returns the edit domain.
* @return the edit domain
protected DefaultEditDomain getEditDomain() {
return editDomain;
public ZoomManager getZoomer() {
return zoomer;
Re: Some refactoring, standalone draw3d viewers. [message #4630 is a reply to message #3884] |
Wed, 03 June 2009 09:37 |
Hi Kristian,
On 2009-06-03 01:13:02 +0200, Kristian Duske
I would expect a new plugin called org.eclipse.draw3d.examples for that
purpose? You could move my viewer part demo from the gef3 examples to
that new plugin (or remove it, if it is only a duplicate).
> need?
Hehe... Although I'm not Miles I would like to vote for spheres :-D
Cheers
Jens
Re: Some refactoring, standalone draw3d viewers. [message #561955 is a reply to message #3884] |
> Hi everyone,
below..
> need?
it or
* {@inheritDoc}
super.dispose();
* <copyright>
* Contributors:
* </copyright>
super();
} else {
getEditPart());
return null;
return getViewer();
return getViewer();
return getZoomer();
return viewer;
* @param ed
* the domain
super.dispose();
return editDomain;
return zoomer;
Re: Some refactoring, standalone draw3d viewers. [message #562010 is a reply to message #3884] |
Hi Kristian,
> need?
Cheers
Jens
Current Time: Sat Jul 27 16:40:14 GMT 2024
Powered by FUDForum. Page generated in 0.04762 seconds
