Home » Archived » Buckminster » NullPointerException in update site tutorial
NullPointerException in update site tutorial [message #388181] Mon, 27 July 2009 13:24 Go to next message
Gabriel BARBIER is currently offline Gabriel BARBIERFriend
Hello, I'm using Eclipse Galileo and I have followed buckminster tutorial to build an update site
( http://wiki.eclipse.org/Buckminster/Examples/Building_an_Upd ate_Site#The_properties_provided_when_building).
When I invoke site.p2 action from my feature project, all jars for plugins and features are created, but it failed
during site creation with a NPE.
Here is the message:
org.eclipse.core.runtime.CoreException:
D:\MoDisco\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\562\1\.cp\org\eclipse\buckminster\pde\antscripts\build .xml:208:
java.lang.NullPointerException: java.lang.NullPointerException
I have check this xml file, and it seems that task create.source.feature is not available.
(line <buckminster.createSourceFeature inputFile="${sp:manifest}" outputFile="${sp:action.output}">)
I have update also buckminster using your update site (core 1.1.350.r10486, PDE support 1.1.350.r10473 and Subversive
support 1.0.0.r10356)
Another interesting detail, when I try to use a site project (as usual), I've got this new error:
eclipse.buildId=I20090611-1540
java.version=1.6.0_13
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Framework arguments: -product org.eclipse.epp.package.rcp.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.rcp.product
Error
Mon Jul 27 15:18:11 CEST 2009
D:\MoDisco\buckminster\workspace\.metadata\.plugins\org.ecli pse.pde.core\temp\org.eclipse.pde.container.feature\assemble .org.eclipse.pde.container.feature.p2.xml:28:
The following error occurred while executing this line:
D:\MoDisco\buckminster\workspace\.metadata\.plugins\org.ecli pse.pde.core\temp\org.eclipse.pde.container.feature\assemble .org.eclipse.pde.container.feature.p2.xml:38:
D:\MoDisco\buckminster\workspace\.metadata\.plugins\org.ecli pse.pde.core\temp\org.eclipse.pde.container.feature\assemble .org.eclipse.pde.container.feature.p2.xml:14:
D:\MoDisco\SVN\org.eclipse.gmt.modisco.omg.kdm\build.xml:109 :
D:\MoDisco\buckminster\workspace\.metadata\.plugins\org.ecli pse.pde.core\temp\destination\plugins\org.eclipse.gmt.modisc o.omg.kdm_0.7.0.200907271518\@dot
not found.
What do I miss when installing and using Buckminster ?
Best regards
Gabriel
Re: NullPointerException in update site tutorial [message #388186 is a reply to message #388181] Tue, 28 July 2009 10:25 Go to previous messageGo to next message
Thomas Hallgren is currently offline Thomas HallgrenFriend
Hi Gabriel,
> plugins and features are created, but it failed during site creation
> with a NPE.
Can you please run with DEBUG trace enabled and if you run from the command line, use -displaystacktrace. Check the log
in <workspace>/.metadata/.log and see if there's a stack backtrace that can help us pin this down.
Ideally, you should enter all of that information in a Bugzilla. An NPE should never happen. It's always a bug IMO.
> is not available.
> 1.1.350.r10486, PDE support 1.1.350.r10473 and Subversive support
> 1.0.0.r10356)
It is available. It's provided by the Buckminster PDE support. This is the task that fails on an NPE.
> Error
> not found.
No idea what this is. What does your build.xml do at line 109?
Thomas Hallgren
Re: NullPointerException in update site tutorial [message #388387 is a reply to message #388186] Tue, 28 July 2009 15:16 Go to previous messageGo to next message
Hello Thomas,
I have created a bug entry: https://bugs.eclipse.org/bugs/show_bug.cgi?id=284874
And here is the log file (also available in bug attachments).
To perform further check with buckminster, I have installed a clean platform. I have checkout tutorials projects, and
when I use site.p2 on org.eclipse.buckminster.tutorial.rcpp2.feature with my properties, it works fine.
The difference I see, is that I'm using projects in my workspace, and these plugins and features projects have all a
properties file to define name, provider, update site ...
Gabriel
Thomas Hallgren wrote:
> Hi Gabriel,
>> with a NPE.
> command line, use -displaystacktrace. Check the log in
>> 1.0.0.r10356)
>> Error
>> not found.
> Regards,
> Thomas Hallgren
Re: NullPointerException in update site tutorial [message #388388 is a reply to message #388387] Tue, 28 July 2009 15:17 Go to previous message
--------------080809010904030703000902
log file:
!SESSION 2009-07-28 16:51:05.640 -----------------------------------------------
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.rcp.product -debug
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-28 16:51:47.734
!MESSAGE org.eclipse.core.runtime.CoreException:
!STACK 1
at org.eclipse.buckminster.ant.AntRunner.handleInvocationTarget Exception(AntRunner.java:189)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:352 )
at org.eclipse.buckminster.ant.actor.AntActor.internalPerform(A ntActor.java:281)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:201)
at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:361)
at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:405)
at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:298)
at org.eclipse.buckminster.ui.InvokeAction$ActionJob.runInWorks pace(InvokeAction.java:112)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
Caused by:
at org.eclipse.buckminster.pde.ant.SourceFeatureCreatorTask.exe cute(SourceFeatureCreatorTask.java:100)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1337)
at org.apache.tools.ant.Project.executeTarget(Project.java:1306 )
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
at org.apache.tools.ant.Project.executeTargets(Project.java:118 9)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:622)
at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:455)
at org.eclipse.buckminster.ant.AntRunner.run(AntRunner.java:344 )
... 8 more
at org.eclipse.buckminster.pde.tasks.SourceFeatureCreator.run(S ourceFeatureCreator.java:131)
at org.eclipse.buckminster.pde.ant.SourceFeatureCreatorTask.exe cute(SourceFeatureCreatorTask.java:96)
... 28 more
Gabriel wrote:
> Hello Thomas,
> platform. I have checkout tutorials projects, and when I use site.p2 on
> works fine.
> these plugins and features projects have all a properties file to define
> Regards
> Gabriel
>> Hi Gabriel,
>>> with a NPE.
>>> 1.0.0.r10356)
>>> Error
>>> not found.
>> Regards,
>> Thomas Hallgren
name=".log"
Content-Disposition: inline;
filename=".log"
!MESSAGE org.eclipse.core.runtime.CoreException: D:\MoDisco\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\562\1\.cp\org\eclipse\buckminster\pde\antscripts\build .xml:208: java.lang.NullPointerException
!STACK 1
Caused by: D:\MoDisco\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\562\1\.cp\org\eclipse\buckminster\pde\antscripts\build .xml:208: java.lang.NullPointerException
... 8 more
... 28 more
!SUBENTRY 1 org.eclipse.ant.core 4 1 2009-07-28 16:51:47.734
!MESSAGE D:\MoDisco\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\562\1\.cp\org\eclipse\buckminster\pde\antscripts\build .xml:208: java.lang.NullPointerException
!STACK 0
... 28 more
--- Nested Exception ---
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-28 16:51:47.750
!MESSAGE D:\MoDisco\galileo\eclipse\configuration\org.eclipse.osgi\bu ndles\562\1\.cp\org\eclipse\buckminster\pde\antscripts\build .xml:208: java.lang.NullPointerException: java.lang.NullPointerException
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-28 17:00:13.375
!MESSAGE org.eclipse.buckminster.core.metadata.MissingComponentExcept ion: No component named org.eclipse.gmt.modisco.updates.features:eclipse.feature$0.7 .0.qualifier is known to Buckminster
!STACK 1
at org.eclipse.buckminster.core.metadata.WorkspaceInfo.getResol ution(WorkspaceInfo.java:438)
at org.eclipse.buckminster.core.metadata.MetadataSynchronizer$M etadataRefreshJob.run(MetadataSynchronizer.java:115)
!SUBENTRY 1 org.eclipse.buckminster.runtime 4 0 2009-07-28 17:00:13.375
!MESSAGE No component named org.eclipse.gmt.modisco.updates.features:eclipse.feature$0.7 .0.qualifier is known to Buckminster
!ENTRY org.eclipse.buckminster.runtime 4 0 2009-07-28 17:00:13.390
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-28 17:02:01.187
!MESSAGE Problems during metadata refresh
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-28 17:02:01.203
!MESSAGE E No component named org.eclipse.emf.compare.match:osgi.bundle(!(eclipse.p2.optio nal=false)) is known to Buckminster
!MESSAGE E No component named org.eclipse.gmt.modisco.updates.features:eclipse.feature/[0. 7.0,0.7.0] is known to Buckminster
!MESSAGE E No component named org.eclipse.emf.compare.diff:osgi.bundle(!(eclipse.p2.option al=false)) is known to Buckminster
!ENTRY org.eclipse.buckminster.core 4 293 2009-07-28 17:05:03.406
!STACK 1
at sun.reflect.GeneratedMethodAccessor40.invoke(Unknown Source)
at sun.reflect.GeneratedMethodAccessor31.invoke(Unknown Source)
... 8 more
... 27 more
!SUBENTRY 1 org.eclipse.ant.core 4 1 2009-07-28 17:05:03.406
!STACK 0
... 27 more
--------------080809010904030703000902--
Previous Topic:Ho to replicate IDE RCP Export with Buckminster
Next Topic:local reader type, scm meta-data and qualifier replacement
Current Time: Wed Feb 05 08:49:27 GMT 2025
Powered by FUDForum. Page generated in 0.04459 seconds
