Home » Language IDEs » PHP Development Tools (PDT) » XDebug Support for PDT 1.0 I20070712 is available.
XDebug Support for PDT 1.0 I20070712 is available. [message #37889] Sat, 21 July 2007 19:36 Go to next message
D Kelsey is currently offline D KelseyFriend
I have just uploaded to https://bugs.eclipse.org/bugs/show_bug.cgi?id=169408
xdebug support for PDT 1.0 version I20070712 Integration build
This version also fixes a some bugs
1. Web launch didn't remember the server URL
2. check box for conditional breakpoints didn't disable the condition
3. Watch expression such as $a.$b didn't work
4. sample mapper didn't correctly handle remapping of inbound filenames
I don't know if this version will work with 1.0 M1 though, it may do.
Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #37922 is a reply to message #37889] Sat, 21 July 2007 23:18 Go to previous messageGo to next message
Originally posted by: foo.foo.com
Thx a lot.
It s working fine.
Only one problem until now, debug output or browser output tab still
empty, but the file in external browser is correctly displayed.
Thx again
> Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #38129 is a reply to message #37922] Sun, 22 July 2007 15:42 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Sorry the xdebug support doesn't output to those views.
Dave Kelsey
foo wrote:
> Thx a lot.
> It s working fine.
> Thx again
>> Dave Kelsey
Re: XDebug Support for PDT 1.0 / Error Message [message #38741 is a reply to message #37889] Mon, 23 July 2007 19:56 Go to previous messageGo to next message
Originally posted by: eclipse.markus.lauff.com
I installed I20070712 and your plugins from below.
Opening the Windows / Preferences / PHP / Debug screen I get the
following error:
Error creation extension for extension-point
org.eclipse.php.ui.phpPreferencePageBlocks
Plug-in org.eclipse.php.xdebug.ui was unable to load class
org.eclipse.php.xdebug.ui.preferences.XDebugAddOnPreferenceP age.
I already tried a clean installation of the PDT all-in-one package
(pdt-all-in-one-incubation-I20070712-win32.zip ) but this does not help.
Thanks for your help,
Markus
> Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #38806 is a reply to message #37922] Tue, 24 July 2007 06:24 Go to previous messageGo to next message
I have strange behavior.
With the last all in one pdt (M1) and this version of xdebug, when i set
breakpoints, if i modify and save the file where breakpoints are set, the
breakpoints vanish.
Re: XDebug Support for PDT 1.0 / Error Message [message #38839 is a reply to message #38741] Tue, 24 July 2007 11:21 Go to previous messageGo to next message
Hi Marcus. Can you look in the error log to get more information on this.
The error log is in your workspace directory In the ".metadata" subdirectory
there is a file called ".log" which should contain this error information
and more details of the problem.
What level of Java are you running PDT with ?
Dave Kelsey
Markus Lauff wrote:
> following error:
> Markus
>> Dave Kelsey
Re: XDebug Support for PDT 1.0 / Error Message [message #38929 is a reply to message #38839] Tue, 24 July 2007 18:54 Go to previous messageGo to next message
--------------040100040803040101000100
Dear Dave,
I use the following Java version:
java version "1.6.0_01"
Java(TM) SE Runtime Environment (build 1.6.0_01-b06)
Java HotSpot(TM) Client VM (build 1.6.0_01-b06, mixed mode, sharing)
The log-file is attached.
Thanks for your help!
Markus
> subdirectory
> Dave Kelsey
> Markus Lauff wrote:
>> Hi,
>> following error:
>> Markus
>>> Dave Kelsey
name=".log"
Content-Disposition: inline;
filename=".log"
IVNFU1NJT04gMjAwNy0wNy0yMyAyMTo1NTowMC41NzggLS0tLS0tLS0tLS0t LS0tLS0tLS0t
LS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0tLS0NCmVjbGlwc2UuYnVpbGRJZD1J MjAwNzA2MjUt
MTUwMA0KamF2YS52ZXJzaW9uPTEuNi4wXzAxDQpqYXZhLnZlbmRvcj1TdW4g TWljcm9zeXN0
ZW1zIEluYy4NCkJvb3RMb2FkZXIgY29uc3RhbnRzOiBPUz13aW4zMiwgQVJD SD14ODYsIFdT
PXdpbjMyLCBOTD1kZV9ERQ0KQ29tbWFuZC1saW5lIGFyZ3VtZW50czogIC1v cyB3aW4zMiAt
d3Mgd2luMzIgLWFyY2ggeDg2IC1kYXRhIEM6XGVjbGlwc2Vfd29ya3NwYWNl LXRtcA0KDQoh
RU5UUlkgb3JnLmVjbGlwc2UuamZhY2UgMiAwIDIwMDctMDctMjMgMjE6NTU6 MDYuMzU5DQoh
TUVTU0FHRSBLZXliaW5kaW5nIGNvbmZsaWN0cyBvY2N1cnJlZC4gIFRoZXkg bWF5IGludGVy
ZmVyZSB3aXRoIG5vcm1hbCBhY2NlbGVyYXRvciBvcGVyYXRpb24uDQohU1VC RU5UUlkgMSBv
cmcuZWNsaXBzZS5qZmFjZSAyIDAgMjAwNy0wNy0yMyAyMTo1NTowNi4zNTkN CiFNRVNTQUdF
IEEgY29uZmxpY3Qgb2NjdXJyZWQgZm9yIEFMVCtTSElGVCtRIFA6DQpCaW5k aW5nKEFMVCtT
SElGVCtRIFAsDQoJUGFyYW1ldGVyaXplZENvbW1hbmQoQ29tbWFuZChvcmcu ZWNsaXBzZS5q
ZHQudWkuUGFja2FnZUV4cGxvcmVyLEphdmEgUGFja2FnZSBFeHBsb3JlciwN CgkJU2hvdyB0
aGUgUGFja2FnZSBFeHBsb3JlciwNCgkJQ2F0ZWdvcnkob3JnLmVjbGlwc2Uu dWkuY2F0ZWdv
cnkudmlld3MsVmlld3MsQ29tbWFuZHMgZm9yIG9wZW5pbmcgdmlld3MsdHJ1 ZSksDQoJCW9y
Zy5lY2xpcHNlLnVpLmludGVybmFsLnJlZ2lzdHJ5LlNob3dWaWV3SGFuZGxl ckAxNGIxZmRh
LA0KCQksLHRydWUpLG51bGwpLA0KCW9yZy5lY2xpcHNlLnVpLmRlZmF1bHRB Y2NlbGVyYXRv
ckNvbmZpZ3VyYXRpb24sDQoJb3JnLmVjbGlwc2UudWkuY29udGV4dHMud2lu ZG93LCwsc3lz
dGVtKQ0KQmluZGluZyhBTFQrU0hJRlQrUSBQLA0KCVBhcmFtZXRlcml6ZWRD b21tYW5kKENv
bW1hbmQob3JnLmVjbGlwc2UucGhwLnVpLmV4cGxvcmVyLFBIUCBTY3JpcHQg RXhwbG9yZXIs
DQoJCVNob3cgdGhlIFNjcmlwdCBFeHBsb3JlciwNCgkJQ2F0ZWdvcnkob3Jn LmVjbGlwc2Uu
dWkuY2F0ZWdvcnkudmlld3MsVmlld3MsQ29tbWFuZHMgZm9yIG9wZW5pbmcg dmlld3MsdHJ1
ZSksDQoJCW9yZy5lY2xpcHNlLnVpLmludGVybmFsLnJlZ2lzdHJ5LlNob3dW aWV3SGFuZGxl
ckAxMTgzODcxLA0KCQksLHRydWUpLG51bGwpLA0KCW9yZy5lY2xpcHNlLnVp LmRlZmF1bHRB
Y2NlbGVyYXRvckNvbmZpZ3VyYXRpb24sDQoJb3JnLmVjbGlwc2UudWkuY29u dGV4dHMud2lu
ZG93LCwsc3lzdGVtKQ0KDQohRU5UUlkgb3JnLmVjbGlwc2Uub3NnaSAyIDAg MjAwNy0wNy0y
MyAyMTo1NTowOC40MjENCiFNRVNTQUdFIFRoZSBhY3RpdmF0b3Igb3JnLmVj bGlwc2UucGhw
LnhkZWJ1Zy51aS5BY3RpdmF0b3IgZm9yIGJ1bmRsZSBvcmcuZWNsaXBzZS5w aHAueGRlYnVn
LnVpIGlzIGludmFsaWQNCiFTVEFDSyAwDQpvcmcub3NnaS5mcmFtZXdvcmsu QnVuZGxlRXhj
ZXB0aW9uOiBUaGUgYWN0aXZhdG9yIG9yZy5lY2xpcHNlLnBocC54ZGVidWcu dWkuQWN0aXZh
dG9yIGZvciBidW5kbGUgb3JnLmVjbGlwc2UucGhwLnhkZWJ1Zy51aSBpcyBp bnZhbGlkDQoJ
YXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5B YnN0cmFjdEJ1
bmRsZS5sb2FkQnVuZGxlQWN0aXZhdG9yKEFic3RyYWN0QnVuZGxlLmphdmE6 MTQxKQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVu ZGxlQ29udGV4
dEltcGwuc3RhcnQoQnVuZGxlQ29udGV4dEltcGwuamF2YTo5NzApDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0LnN0 YXJ0V29ya2Vy
KEJ1bmRsZUhvc3QuamF2YTozNDYpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5m cmFtZXdvcmsu
aW50ZXJuYWwuY29yZS5BYnN0cmFjdEJ1bmRsZS5zdGFydChBYnN0cmFjdEJ1 bmRsZS5qYXZh
OjI2MCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay51dGlsLlNl Y3VyZUFjdGlv
bi5zdGFydChTZWN1cmVBY3Rpb24uamF2YTo0MDApDQoJYXQgb3JnLmVjbGlw c2Uub3NnaS5m
cmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0LmxvYWRDbGFzcyhC dW5kbGVIb3N0
LmphdmE6MjM0KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmlu dGVybmFsLmNv
cmUuQWJzdHJhY3RCdW5kbGUubG9hZENsYXNzKEFic3RyYWN0QnVuZGxlLmph dmE6MTI2OSkN
CglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5Lm9zZ2ku UmVnaXN0cnlT
dHJhdGVneU9TR0kuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihSZWdpc3Ry eVN0cmF0ZWd5
T1NHSS5qYXZhOjE2MCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFs LnJlZ2lzdHJ5
LkV4dGVuc2lvblJlZ2lzdHJ5LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24o RXh0ZW5zaW9u
UmVnaXN0cnkuamF2YTo3ODgpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRl cm5hbC5yZWdp
c3RyeS5Db25maWd1cmF0aW9uRWxlbWVudC5jcmVhdGVFeGVjdXRhYmxlRXh0 ZW5zaW9uKENv
bmZpZ3VyYXRpb25FbGVtZW50LmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xpcHNl LmNvcmUuaW50
ZXJuYWwucmVnaXN0cnkuQ29uZmlndXJhdGlvbkVsZW1lbnRIYW5kbGUuY3Jl YXRlRXhlY3V0
YWJsZUV4dGVuc2lvbihDb25maWd1cmF0aW9uRWxlbWVudEhhbmRsZS5qYXZh OjUxKQ0KCWF0
IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaFBsdWdpbiQxLnJ1 bihXb3JrYmVu
Y2hQbHVnaW4uamF2YToyNDMpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LmN1c3Rv bS5CdXN5SW5k
aWNhdG9yLnNob3dXaGlsZShCdXN5SW5kaWNhdG9yLmphdmE6NDkpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuV29ya2JlbmNoUGx1Z2luLmNyZWF0ZUV4dGVuc2lv bihXb3JrYmVu
Y2hQbHVnaW4uamF2YToyMzkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJu YWwuRWFybHlT
dGFydHVwUnVubmFibGUuZ2V0RXhlY3V0YWJsZUV4dGVuc2lvbihFYXJseVN0 YXJ0dXBSdW5u
YWJsZS5qYXZhOjExNykNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5F YXJseVN0YXJ0
dXBSdW5uYWJsZS5ydW4oRWFybHlTdGFydHVwUnVubmFibGUuamF2YTo2NikN CglhdCBvcmcu
ZWNsaXBzZS5jb3JlLnJ1bnRpbWUuU2FmZVJ1bm5lci5ydW4oU2FmZVJ1bm5l ci5qYXZhOjM3
KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaCQ1NC5y dW4oV29ya2Jl
bmNoLmphdmE6MjE5MCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFs LmpvYnMuV29y
a2VyLnJ1bihXb3JrZXIuamF2YTo1NSkNCkNhdXNlZCBieTogamF2YS5sYW5n LkNsYXNzTm90
Rm91bmRFeGNlcHRpb246IG9yZy5lY2xpcHNlLnBocC54ZGVidWcudWkuQWN0 aXZhdG9yDQoJ
YXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmZpbmRDbGFzcyhVbmtub3duIFNv dXJjZSkNCglh
dCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIubG9hZENsYXNzKFVua25vd24gU291 cmNlKQ0KCWF0
IGphdmEubGFuZy5DbGFzc0xvYWRlci5sb2FkQ2xhc3MoVW5rbm93biBTb3Vy Y2UpDQoJYXQg
b3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5k bGVMb2FkZXIu
ZmluZENsYXNzSW50ZXJuYWwoQnVuZGxlTG9hZGVyLmphdmE6NDI5KQ0KCWF0 IG9yZy5lY2xp
cHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlTG9hZGVy LmZpbmRDbGFz
cyhCdW5kbGVMb2FkZXIuamF2YTozNjkpDQoJYXQgb3JnLmVjbGlwc2Uub3Nn aS5mcmFtZXdv
cmsuaW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIuZmluZENsYXNzKEJ1bmRs ZUxvYWRlci5q
YXZhOjM1NykNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmludGVybmFsLmJhc2Vh ZGFwdG9yLkRl
ZmF1bHRDbGFzc0xvYWRlci5sb2FkQ2xhc3MoRGVmYXVsdENsYXNzTG9hZGVy LmphdmE6ODMp
DQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmxvYWRDbGFzcyhVbmtub3du IFNvdXJjZSkN
CglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3Jl LkJ1bmRsZUxv
YWRlci5sb2FkQ2xhc3MoQnVuZGxlTG9hZGVyLmphdmE6Mjg5KQ0KCWF0IG9y Zy5lY2xpcHNl
Lm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlSG9zdC5sb2Fk Q2xhc3MoQnVu
ZGxlSG9zdC5qYXZhOjIyNykNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1l d29yay5pbnRl
cm5hbC5jb3JlLkFic3RyYWN0QnVuZGxlLmxvYWRCdW5kbGVBY3RpdmF0b3Io QWJzdHJhY3RC
dW5kbGUuamF2YToxMzQpDQoJLi4uIDE4IG1vcmUNClJvb3QgZXhjZXB0aW9u Og0KamF2YS5s
YW5nLkNsYXNzTm90Rm91bmRFeGNlcHRpb246IG9yZy5lY2xpcHNlLnBocC54 ZGVidWcudWku
QWN0aXZhdG9yDQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmZpbmRDbGFz cyhVbmtub3du
IFNvdXJjZSkNCglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIubG9hZENsYXNz KFVua25vd24g
U291cmNlKQ0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRlci5sb2FkQ2xhc3Mo VW5rbm93biBT
b3VyY2UpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJu YWwuY29yZS5C
dW5kbGVMb2FkZXIuZmluZENsYXNzSW50ZXJuYWwoQnVuZGxlTG9hZGVyLmph dmE6NDI5KQ0K
CWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUu QnVuZGxlTG9h
ZGVyLmZpbmRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YTozNjkpDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIuZmlu ZENsYXNzKEJ1
bmRsZUxvYWRlci5qYXZhOjM1NykNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmlu dGVybmFsLmJh
c2VhZGFwdG9yLkRlZmF1bHRDbGFzc0xvYWRlci5sb2FkQ2xhc3MoRGVmYXVs dENsYXNzTG9h
ZGVyLmphdmE6ODMpDQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmxvYWRD bGFzcyhVbmtu
b3duIFNvdXJjZSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5p bnRlcm5hbC5j
b3JlLkJ1bmRsZUxvYWRlci5sb2FkQ2xhc3MoQnVuZGxlTG9hZGVyLmphdmE6 Mjg5KQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVu ZGxlSG9zdC5s
b2FkQ2xhc3MoQnVuZGxlSG9zdC5qYXZhOjIyNykNCglhdCBvcmcuZWNsaXBz ZS5vc2dpLmZy
YW1ld29yay5pbnRlcm5hbC5jb3JlLkFic3RyYWN0QnVuZGxlLmxvYWRCdW5k bGVBY3RpdmF0
b3IoQWJzdHJhY3RCdW5kbGUuamF2YToxMzQpDQoJYXQgb3JnLmVjbGlwc2Uu b3NnaS5mcmFt
ZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVDb250ZXh0SW1wbC5zdGFydChC dW5kbGVDb250
ZXh0SW1wbC5qYXZhOjk3MCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1l d29yay5pbnRl
cm5hbC5jb3JlLkJ1bmRsZUhvc3Quc3RhcnRXb3JrZXIoQnVuZGxlSG9zdC5q YXZhOjM0NikN
CglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5jb3Jl LkFic3RyYWN0
QnVuZGxlLnN0YXJ0KEFic3RyYWN0QnVuZGxlLmphdmE6MjYwKQ0KCWF0IG9y Zy5lY2xpcHNl
Lm9zZ2kuZnJhbWV3b3JrLnV0aWwuU2VjdXJlQWN0aW9uLnN0YXJ0KFNlY3Vy ZUFjdGlvbi5q
YXZhOjQwMCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRl cm5hbC5jb3Jl
LkJ1bmRsZUhvc3QubG9hZENsYXNzKEJ1bmRsZUhvc3QuamF2YToyMzQpDQoJ YXQgb3JnLmVj
bGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5BYnN0cmFjdEJ1 bmRsZS5sb2Fk
Q2xhc3MoQWJzdHJhY3RCdW5kbGUuamF2YToxMjY5KQ0KCWF0IG9yZy5lY2xp cHNlLmNvcmUu
aW50ZXJuYWwucmVnaXN0cnkub3NnaS5SZWdpc3RyeVN0cmF0ZWd5T1NHSS5j cmVhdGVFeGVj
dXRhYmxlRXh0ZW5zaW9uKFJlZ2lzdHJ5U3RyYXRlZ3lPU0dJLmphdmE6MTYw KQ0KCWF0IG9y
Zy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkuRXh0ZW5zaW9uUmVn aXN0cnkuY3Jl
YXRlRXhlY3V0YWJsZUV4dGVuc2lvbihFeHRlbnNpb25SZWdpc3RyeS5qYXZh Ojc4OCkNCglh
dCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5LkNvbmZpZ3Vy YXRpb25FbGVt
ZW50LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oQ29uZmlndXJhdGlvbkVs ZW1lbnQuamF2
YToyNDMpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZWdpc3Ry eS5Db25maWd1
cmF0aW9uRWxlbWVudEhhbmRsZS5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9u KENvbmZpZ3Vy
YXRpb25FbGVtZW50SGFuZGxlLmphdmE6NTEpDQoJYXQgb3JnLmVjbGlwc2Uu dWkuaW50ZXJu
YWwuV29ya2JlbmNoUGx1Z2luJDEucnVuKFdvcmtiZW5jaFBsdWdpbi5qYXZh OjI0MykNCglh
dCBvcmcuZWNsaXBzZS5zd3QuY3VzdG9tLkJ1c3lJbmRpY2F0b3Iuc2hvd1do aWxlKEJ1c3lJ
bmRpY2F0b3IuamF2YTo0OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5h bC5Xb3JrYmVu
Y2hQbHVnaW4uY3JlYXRlRXh0ZW5zaW9uKFdvcmtiZW5jaFBsdWdpbi5qYXZh OjIzOSkNCglh
dCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5FYXJseVN0YXJ0dXBSdW5uYWJs ZS5nZXRFeGVj
dXRhYmxlRXh0ZW5zaW9uKEVhcmx5U3RhcnR1cFJ1bm5hYmxlLmphdmE6MTE3 KQ0KCWF0IG9y
Zy5lY2xpcHNlLnVpLmludGVybmFsLkVhcmx5U3RhcnR1cFJ1bm5hYmxlLnJ1 bihFYXJseVN0
YXJ0dXBSdW5uYWJsZS5qYXZhOjY2KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUu cnVudGltZS5T
YWZlUnVubmVyLnJ1bihTYWZlUnVubmVyLmphdmE6MzcpDQoJYXQgb3JnLmVj bGlwc2UudWku
aW50ZXJuYWwuV29ya2JlbmNoJDU0LnJ1bihXb3JrYmVuY2guamF2YToyMTkw KQ0KCWF0IG9y
Zy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwuam9icy5Xb3JrZXIucnVuKFdvcmtl ci5qYXZhOjU1
KQ0KDQohRU5UUlkgb3JnLmVjbGlwc2UudWkud29ya2JlbmNoIDQgMiAyMDA3 LTA3LTIzIDIx
OjU1OjA4LjQzNw0KIU1FU1NBR0UgUHJvYmxlbXMgb2NjdXJyZWQgd2hlbiBp bnZva2luZyBj
b2RlIGZyb20gcGx1Zy1pbjogIm9yZy5lY2xpcHNlLnVpLndvcmtiZW5jaCIu DQohU1RBQ0sg
MQ0Kb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLkNvcmVFeGNlcHRpb246IFBs dWctaW4gb3Jn
LmVjbGlwc2UucGhwLnhkZWJ1Zy51aSB3YXMgdW5hYmxlIHRvIGxvYWQgY2xh c3Mgb3JnLmVj
bGlwc2UucGhwLnhkZWJ1Zy51aS5FYXJseVN0YXJ0Lg0KCWF0IG9yZy5lY2xp cHNlLmNvcmUu
aW50ZXJuYWwucmVnaXN0cnkub3NnaS5SZWdpc3RyeVN0cmF0ZWd5T1NHSS50 aHJvd0V4Y2Vw
dGlvbihSZWdpc3RyeVN0cmF0ZWd5T1NHSS5qYXZhOjE4MCkNCglhdCBvcmcu ZWNsaXBzZS5j
b3JlLmludGVybmFsLnJlZ2lzdHJ5Lm9zZ2kuUmVnaXN0cnlTdHJhdGVneU9T R0kuY3JlYXRl
RXhlY3V0YWJsZUV4dGVuc2lvbihSZWdpc3RyeVN0cmF0ZWd5T1NHSS5qYXZh OjE2MikNCglh
dCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5LkV4dGVuc2lv blJlZ2lzdHJ5
LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oRXh0ZW5zaW9uUmVnaXN0cnku amF2YTo3ODgp
DQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZWdpc3RyeS5Db25m aWd1cmF0aW9u
RWxlbWVudC5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9uKENvbmZpZ3VyYXRp b25FbGVtZW50
LmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVn aXN0cnkuQ29u
ZmlndXJhdGlvbkVsZW1lbnRIYW5kbGUuY3JlYXRlRXhlY3V0YWJsZUV4dGVu c2lvbihDb25m
aWd1cmF0aW9uRWxlbWVudEhhbmRsZS5qYXZhOjUxKQ0KCWF0IG9yZy5lY2xp cHNlLnVpLmlu
dGVybmFsLldvcmtiZW5jaFBsdWdpbiQxLnJ1bihXb3JrYmVuY2hQbHVnaW4u amF2YToyNDMp
DQoJYXQgb3JnLmVjbGlwc2Uuc3d0LmN1c3RvbS5CdXN5SW5kaWNhdG9yLnNo b3dXaGlsZShC
dXN5SW5kaWNhdG9yLmphdmE6NDkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50 ZXJuYWwuV29y
a2JlbmNoUGx1Z2luLmNyZWF0ZUV4dGVuc2lvbihXb3JrYmVuY2hQbHVnaW4u amF2YToyMzkp
DQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuRWFybHlTdGFydHVwUnVu bmFibGUuZ2V0
RXhlY3V0YWJsZUV4dGVuc2lvbihFYXJseVN0YXJ0dXBSdW5uYWJsZS5qYXZh OjExNykNCglh
dCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5FYXJseVN0YXJ0dXBSdW5uYWJs ZS5ydW4oRWFy
bHlTdGFydHVwUnVubmFibGUuamF2YTo2NikNCglhdCBvcmcuZWNsaXBzZS5j b3JlLnJ1bnRp
bWUuU2FmZVJ1bm5lci5ydW4oU2FmZVJ1bm5lci5qYXZhOjM3KQ0KCWF0IG9y Zy5lY2xpcHNl
LnVpLmludGVybmFsLldvcmtiZW5jaCQ1NC5ydW4oV29ya2JlbmNoLmphdmE6 MjE5MCkNCglh
dCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLmpvYnMuV29ya2VyLnJ1bihX b3JrZXIuamF2
YTo1NSkNCm9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5Db3JlRXhjZXB0aW9u WzFdOiBqYXZh
LmxhbmcuQ2xhc3NOb3RGb3VuZEV4Y2VwdGlvbjogb3JnLmVjbGlwc2UucGhw LnhkZWJ1Zy51
aS5FYXJseVN0YXJ0DQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmZpbmRD bGFzcyhVbmtu
b3duIFNvdXJjZSkNCglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIubG9hZENs YXNzKFVua25v
d24gU291cmNlKQ0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRlci5sb2FkQ2xh c3MoVW5rbm93
biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50 ZXJuYWwuY29y
ZS5CdW5kbGVMb2FkZXIuZmluZENsYXNzSW50ZXJuYWwoQnVuZGxlTG9hZGVy LmphdmE6NDI5
KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNv cmUuQnVuZGxl
TG9hZGVyLmZpbmRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YTozNjkpDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIu ZmluZENsYXNz
KEJ1bmRsZUxvYWRlci5qYXZhOjM1NykNCglhdCBvcmcuZWNsaXBzZS5vc2dp LmludGVybmFs
LmJhc2VhZGFwdG9yLkRlZmF1bHRDbGFzc0xvYWRlci5sb2FkQ2xhc3MoRGVm YXVsdENsYXNz
TG9hZGVyLmphdmE6ODMpDQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmxv YWRDbGFzcyhV
bmtub3duIFNvdXJjZSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29y ay5pbnRlcm5h
bC5jb3JlLkJ1bmRsZUxvYWRlci5sb2FkQ2xhc3MoQnVuZGxlTG9hZGVyLmph dmE6Mjg5KQ0K
CWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUu QnVuZGxlSG9z
dC5sb2FkQ2xhc3MoQnVuZGxlSG9zdC5qYXZhOjIyNykNCglhdCBvcmcuZWNs aXBzZS5vc2dp
LmZyYW1ld29yay5pbnRlcm5hbC5jb3JlLkFic3RyYWN0QnVuZGxlLmxvYWRD bGFzcyhBYnN0
cmFjdEJ1bmRsZS5qYXZhOjEyNjkpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5p bnRlcm5hbC5y
ZWdpc3RyeS5vc2dpLlJlZ2lzdHJ5U3RyYXRlZ3lPU0dJLmNyZWF0ZUV4ZWN1 dGFibGVFeHRl
bnNpb24oUmVnaXN0cnlTdHJhdGVneU9TR0kuamF2YToxNjApDQoJYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5pbnRlcm5hbC5yZWdpc3RyeS5FeHRlbnNpb25SZWdpc3RyeS5jcmVh dGVFeGVjdXRh
YmxlRXh0ZW5zaW9uKEV4dGVuc2lvblJlZ2lzdHJ5LmphdmE6Nzg4KQ0KCWF0 IG9yZy5lY2xp
cHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkuQ29uZmlndXJhdGlvbkVsZW1l bnQuY3JlYXRl
RXhlY3V0YWJsZUV4dGVuc2lvbihDb25maWd1cmF0aW9uRWxlbWVudC5qYXZh OjI0MykNCglh
ZW50SGFuZGxlLmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oQ29uZmlndXJh dGlvbkVsZW1l
bnRIYW5kbGUuamF2YTo1MSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5h bC5Xb3JrYmVu
Y2hQbHVnaW4kMS5ydW4oV29ya2JlbmNoUGx1Z2luLmphdmE6MjQzKQ0KCWF0 IG9yZy5lY2xp
cHNlLnN3dC5jdXN0b20uQnVzeUluZGljYXRvci5zaG93V2hpbGUoQnVzeUlu ZGljYXRvci5q
YXZhOjQ5KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5j aFBsdWdpbi5j
cmVhdGVFeHRlbnNpb24oV29ya2JlbmNoUGx1Z2luLmphdmE6MjM5KQ0KCWF0 IG9yZy5lY2xp
cHNlLnVpLmludGVybmFsLkVhcmx5U3RhcnR1cFJ1bm5hYmxlLmdldEV4ZWN1 dGFibGVFeHRl
bnNpb24oRWFybHlTdGFydHVwUnVubmFibGUuamF2YToxMTcpDQoJYXQgb3Jn LmVjbGlwc2Uu
dWkuaW50ZXJuYWwuRWFybHlTdGFydHVwUnVubmFibGUucnVuKEVhcmx5U3Rh cnR1cFJ1bm5h
YmxlLmphdmE6NjYpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLlNh ZmVSdW5uZXIu
cnVuKFNhZmVSdW5uZXIuamF2YTozNykNCglhdCBvcmcuZWNsaXBzZS51aS5p bnRlcm5hbC5X
b3JrYmVuY2gkNTQucnVuKFdvcmtiZW5jaC5qYXZhOjIxOTApDQoJYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5pbnRlcm5hbC5qb2JzLldvcmtlci5ydW4oV29ya2VyLmphdmE6NTUp DQohU1VCRU5U
UlkgMSBvcmcuZWNsaXBzZS5lcXVpbm94LnJlZ2lzdHJ5IDQgMSAyMDA3LTA3 LTIzIDIxOjU1
OjA4LjQzNw0KIU1FU1NBR0UgUGx1Zy1pbiBvcmcuZWNsaXBzZS5waHAueGRl YnVnLnVpIHdh
cyB1bmFibGUgdG8gbG9hZCBjbGFzcyBvcmcuZWNsaXBzZS5waHAueGRlYnVn LnVpLkVhcmx5
U3RhcnQuDQohU1RBQ0sgMA0KamF2YS5sYW5nLkNsYXNzTm90Rm91bmRFeGNl cHRpb246IG9y
Zy5lY2xpcHNlLnBocC54ZGVidWcudWkuRWFybHlTdGFydA0KCWF0IGphdmEu bGFuZy5DbGFz
c0xvYWRlci5maW5kQ2xhc3MoVW5rbm93biBTb3VyY2UpDQoJYXQgamF2YS5s YW5nLkNsYXNz
TG9hZGVyLmxvYWRDbGFzcyhVbmtub3duIFNvdXJjZSkNCglhdCBqYXZhLmxh bmcuQ2xhc3NM
b2FkZXIubG9hZENsYXNzKFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xp cHNlLm9zZ2ku
ZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlTG9hZGVyLmZpbmRDbGFz c0ludGVybmFs
KEJ1bmRsZUxvYWRlci5qYXZhOjQyOSkNCglhdCBvcmcuZWNsaXBzZS5vc2dp LmZyYW1ld29y
ay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUxvYWRlci5maW5kQ2xhc3MoQnVuZGxl TG9hZGVyLmph
dmE6MzY5KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVy bmFsLmNvcmUu
QnVuZGxlTG9hZGVyLmZpbmRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YTozNTcp DQoJYXQgb3Jn
LmVjbGlwc2Uub3NnaS5pbnRlcm5hbC5iYXNlYWRhcHRvci5EZWZhdWx0Q2xh c3NMb2FkZXIu
bG9hZENsYXNzKERlZmF1bHRDbGFzc0xvYWRlci5qYXZhOjgzKQ0KCWF0IGph dmEubGFuZy5D
bGFzc0xvYWRlci5sb2FkQ2xhc3MoVW5rbm93biBTb3VyY2UpDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIubG9h ZENsYXNzKEJ1
bmRsZUxvYWRlci5qYXZhOjI4OSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZy YW1ld29yay5p
bnRlcm5hbC5jb3JlLkJ1bmRsZUhvc3QubG9hZENsYXNzKEJ1bmRsZUhvc3Qu amF2YToyMjcp
DQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29y ZS5BYnN0cmFj
dEJ1bmRsZS5sb2FkQ2xhc3MoQWJzdHJhY3RCdW5kbGUuamF2YToxMjY5KQ0K CWF0IG9yZy5l
Y2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkub3NnaS5SZWdpc3RyeVN0 cmF0ZWd5T1NH
SS5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9uKFJlZ2lzdHJ5U3RyYXRlZ3lP U0dJLmphdmE6
MTYwKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnku RXh0ZW5zaW9u
UmVnaXN0cnkuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihFeHRlbnNpb25S ZWdpc3RyeS5q
YXZhOjc4OCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lz dHJ5LkNvbmZp
Z3VyYXRpb25FbGVtZW50LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oQ29u ZmlndXJhdGlv
bkVsZW1lbnQuamF2YToyNDMpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRl cm5hbC5yZWdp
c3RyeS5Db25maWd1cmF0aW9uRWxlbWVudEhhbmRsZS5jcmVhdGVFeGVjdXRh YmxlRXh0ZW5z
aW9uKENvbmZpZ3VyYXRpb25FbGVtZW50SGFuZGxlLmphdmE6NTEpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuV29ya2JlbmNoUGx1Z2luJDEucnVuKFdvcmtiZW5j aFBsdWdpbi5q
YXZhOjI0MykNCglhdCBvcmcuZWNsaXBzZS5zd3QuY3VzdG9tLkJ1c3lJbmRp Y2F0b3Iuc2hv
d1doaWxlKEJ1c3lJbmRpY2F0b3IuamF2YTo0OSkNCglhdCBvcmcuZWNsaXBz ZS51aS5pbnRl
cm5hbC5Xb3JrYmVuY2hQbHVnaW4uY3JlYXRlRXh0ZW5zaW9uKFdvcmtiZW5j aFBsdWdpbi5q
YXZhOjIzOSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5FYXJseVN0 YXJ0dXBSdW5u
YWJsZS5nZXRFeGVjdXRhYmxlRXh0ZW5zaW9uKEVhcmx5U3RhcnR1cFJ1bm5h YmxlLmphdmE6
MTE3KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLkVhcmx5U3RhcnR1 cFJ1bm5hYmxl
LnJ1bihFYXJseVN0YXJ0dXBSdW5uYWJsZS5qYXZhOjY2KQ0KCWF0IG9yZy5l Y2xpcHNlLmNv
cmUucnVudGltZS5TYWZlUnVubmVyLnJ1bihTYWZlUnVubmVyLmphdmE6Mzcp DQoJYXQgb3Jn
LmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoJDU0LnJ1bihXb3JrYmVu Y2guamF2YToy
MTkwKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwuam9icy5Xb3Jr ZXIucnVuKFdv
cmtlci5qYXZhOjU1KQ0KIVNVQkVOVFJZIDEgb3JnLmVjbGlwc2UuZXF1aW5v eC5yZWdpc3Ry
eSA0IDEgMjAwNy0wNy0yMyAyMTo1NTowOC40MzcNCiFNRVNTQUdFIFBsdWct aW4gb3JnLmVj
bGlwc2UucGhwLnhkZWJ1Zy51aSB3YXMgdW5hYmxlIHRvIGxvYWQgY2xhc3Mg b3JnLmVjbGlw
c2UucGhwLnhkZWJ1Zy51aS5FYXJseVN0YXJ0Lg0KIVNUQUNLIDANCmphdmEu bGFuZy5DbGFz
c05vdEZvdW5kRXhjZXB0aW9uOiBvcmcuZWNsaXBzZS5waHAueGRlYnVnLnVp LkVhcmx5U3Rh
cnQNCglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIuZmluZENsYXNzKFVua25v d24gU291cmNl
KQ0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRlci5sb2FkQ2xhc3MoVW5rbm93 biBTb3VyY2Up
YWRlci5maW5kQ2xhc3NJbnRlcm5hbChCdW5kbGVMb2FkZXIuamF2YTo0Mjkp DQoJYXQgb3Jn
LmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVM b2FkZXIuZmlu
ZENsYXNzKEJ1bmRsZUxvYWRlci5qYXZhOjM2OSkNCglhdCBvcmcuZWNsaXBz ZS5vc2dpLmZy
YW1ld29yay5pbnRlcm5hbC5jb3JlLkJ1bmRsZUxvYWRlci5maW5kQ2xhc3Mo QnVuZGxlTG9h
ZGVyLmphdmE6MzU3KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuaW50ZXJuYWwu YmFzZWFkYXB0
b3IuRGVmYXVsdENsYXNzTG9hZGVyLmxvYWRDbGFzcyhEZWZhdWx0Q2xhc3NM b2FkZXIuamF2
YTo4MykNCglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIubG9hZENsYXNzKFVu a25vd24gU291
cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFs LmNvcmUuQnVu
ZGxlTG9hZGVyLmxvYWRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YToyODkpDQoJ YXQgb3JnLmVj
bGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0 LmxvYWRDbGFz
cyhCdW5kbGVIb3N0LmphdmE6MjI3KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2ku ZnJhbWV3b3Jr
LmludGVybmFsLmNvcmUuQWJzdHJhY3RCdW5kbGUubG9hZENsYXNzKEFic3Ry YWN0QnVuZGxl
LmphdmE6MTI2OSkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJl Z2lzdHJ5Lm9z
Z2kuUmVnaXN0cnlTdHJhdGVneU9TR0kuY3JlYXRlRXhlY3V0YWJsZUV4dGVu c2lvbihSZWdp
c3RyeVN0cmF0ZWd5T1NHSS5qYXZhOjE2MCkNCglhdCBvcmcuZWNsaXBzZS5j b3JlLmludGVy
bmFsLnJlZ2lzdHJ5LkV4dGVuc2lvblJlZ2lzdHJ5LmNyZWF0ZUV4ZWN1dGFi bGVFeHRlbnNp
b24oRXh0ZW5zaW9uUmVnaXN0cnkuamF2YTo3ODgpDQoJYXQgb3JnLmVjbGlw c2UuY29yZS5p
bnRlcm5hbC5yZWdpc3RyeS5Db25maWd1cmF0aW9uRWxlbWVudC5jcmVhdGVF eGVjdXRhYmxl
RXh0ZW5zaW9uKENvbmZpZ3VyYXRpb25FbGVtZW50LmphdmE6MjQzKQ0KCWF0 IG9yZy5lY2xp
cHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkuQ29uZmlndXJhdGlvbkVsZW1l bnRIYW5kbGUu
Y3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihDb25maWd1cmF0aW9uRWxlbWVu dEhhbmRsZS5q
YXZhOjUxKQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5j aFBsdWdpbiQx
LnJ1bihXb3JrYmVuY2hQbHVnaW4uamF2YToyNDMpDQoJYXQgb3JnLmVjbGlw c2Uuc3d0LmN1
c3RvbS5CdXN5SW5kaWNhdG9yLnNob3dXaGlsZShCdXN5SW5kaWNhdG9yLmph dmE6NDkpDQoJ
YXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNoUGx1Z2luLmNy ZWF0ZUV4dGVu
c2lvbihXb3JrYmVuY2hQbHVnaW4uamF2YToyMzkpDQoJYXQgb3JnLmVjbGlw c2UudWkuaW50
ZXJuYWwuRWFybHlTdGFydHVwUnVubmFibGUuZ2V0RXhlY3V0YWJsZUV4dGVu c2lvbihFYXJs
eVN0YXJ0dXBSdW5uYWJsZS5qYXZhOjExNykNCglhdCBvcmcuZWNsaXBzZS51 aS5pbnRlcm5h
bC5FYXJseVN0YXJ0dXBSdW5uYWJsZS5ydW4oRWFybHlTdGFydHVwUnVubmFi bGUuamF2YTo2
NikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuU2FmZVJ1bm5lci5y dW4oU2FmZVJ1
bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldv cmtiZW5jaCQ1
NC5ydW4oV29ya2JlbmNoLmphdmE6MjE5MCkNCglhdCBvcmcuZWNsaXBzZS5j b3JlLmludGVy
bmFsLmpvYnMuV29ya2VyLnJ1bihXb3JrZXIuamF2YTo1NSkNCg0KIUVOVFJZ IG9yZy5lY2xp
cHNlLnVpIDQgNCAyMDA3LTA3LTIzIDIxOjU1OjA4LjQzNw0KIU1FU1NBR0Ug VW5oYW5kbGVk
IEV4Y2VwdGlvbg0KDQohRU5UUlkgb3JnLmVjbGlwc2UucGhwLnhkZWJ1Zy51 aSA0IDAgMjAw
Ny0wNy0yMyAyMTo1NTowOC40MzcNCiFNRVNTQUdFIFVuYWJsZSB0byBleGVj dXRlIGVhcmx5
IHN0YXJ0dXAgY29kZSBmb3IgYW4gZXh0ZW5zaW9uDQohU1RBQ0sgMQ0Kb3Jn LmVjbGlwc2Uu
Y29yZS5ydW50aW1lLkNvcmVFeGNlcHRpb246IFBsdWctaW4gb3JnLmVjbGlw c2UucGhwLnhk
ZWJ1Zy51aSB3YXMgdW5hYmxlIHRvIGxvYWQgY2xhc3Mgb3JnLmVjbGlwc2Uu cGhwLnhkZWJ1
Zy51aS5FYXJseVN0YXJ0Lg0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJu YWwucmVnaXN0
cnkub3NnaS5SZWdpc3RyeVN0cmF0ZWd5T1NHSS50aHJvd0V4Y2VwdGlvbihS ZWdpc3RyeVN0
cmF0ZWd5T1NHSS5qYXZhOjE4MCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmlu dGVybmFsLnJl
Z2lzdHJ5Lm9zZ2kuUmVnaXN0cnlTdHJhdGVneU9TR0kuY3JlYXRlRXhlY3V0 YWJsZUV4dGVu
c2lvbihSZWdpc3RyeVN0cmF0ZWd5T1NHSS5qYXZhOjE2MikNCglhdCBvcmcu ZWNsaXBzZS5j
b3JlLmludGVybmFsLnJlZ2lzdHJ5LkV4dGVuc2lvblJlZ2lzdHJ5LmNyZWF0 ZUV4ZWN1dGFi
bGVFeHRlbnNpb24oRXh0ZW5zaW9uUmVnaXN0cnkuamF2YTo3ODgpDQoJYXQg b3JnLmVjbGlw
c2UuY29yZS5pbnRlcm5hbC5yZWdpc3RyeS5Db25maWd1cmF0aW9uRWxlbWVu dC5jcmVhdGVF
eGVjdXRhYmxlRXh0ZW5zaW9uKENvbmZpZ3VyYXRpb25FbGVtZW50LmphdmE6 MjQzKQ0KCWF0
IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkuQ29uZmlndXJh dGlvbkVsZW1l
bnRIYW5kbGUuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihDb25maWd1cmF0 aW9uRWxlbWVu
dEhhbmRsZS5qYXZhOjUxKQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFs LldvcmtiZW5j
aFBsdWdpbiQxLnJ1bihXb3JrYmVuY2hQbHVnaW4uamF2YToyNDMpDQoJYXQg b3JnLmVjbGlw
c2Uuc3d0LmN1c3RvbS5CdXN5SW5kaWNhdG9yLnNob3dXaGlsZShCdXN5SW5k aWNhdG9yLmph
dmE6NDkpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNo UGx1Z2luLmNy
ZWF0ZUV4dGVuc2lvbihXb3JrYmVuY2hQbHVnaW4uamF2YToyMzkpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuRWFybHlTdGFydHVwUnVubmFibGUuZ2V0RXhlY3V0 YWJsZUV4dGVu
c2lvbihFYXJseVN0YXJ0dXBSdW5uYWJsZS5qYXZhOjExNykNCglhdCBvcmcu ZWNsaXBzZS51
aS5pbnRlcm5hbC5FYXJseVN0YXJ0dXBSdW5uYWJsZS5ydW4oRWFybHlTdGFy dHVwUnVubmFi
bGUuamF2YTo2NikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuU2Fm ZVJ1bm5lci5y
dW4oU2FmZVJ1bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmlu dGVybmFsLldv
cmtiZW5jaCQ1NC5ydW4oV29ya2JlbmNoLmphdmE6MjE5MCkNCglhdCBvcmcu ZWNsaXBzZS5j
b3JlLmludGVybmFsLmpvYnMuV29ya2VyLnJ1bihXb3JrZXIuamF2YTo1NSkN Cm9yZy5lY2xp
cHNlLmNvcmUucnVudGltZS5Db3JlRXhjZXB0aW9uWzFdOiBqYXZhLmxhbmcu Q2xhc3NOb3RG
b3VuZEV4Y2VwdGlvbjogb3JnLmVjbGlwc2UucGhwLnhkZWJ1Zy51aS5FYXJs eVN0YXJ0DQoJ
cm5hbC5jb3JlLkFic3RyYWN0QnVuZGxlLmxvYWRDbGFzcyhBYnN0cmFjdEJ1 bmRsZS5qYXZh
OjEyNjkpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZWdpc3Ry eS5vc2dpLlJl
Z2lzdHJ5U3RyYXRlZ3lPU0dJLmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24o UmVnaXN0cnlT
dHJhdGVneU9TR0kuamF2YToxNjApDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5p bnRlcm5hbC5y
ZWdpc3RyeS5FeHRlbnNpb25SZWdpc3RyeS5jcmVhdGVFeGVjdXRhYmxlRXh0 ZW5zaW9uKEV4
dGVuc2lvblJlZ2lzdHJ5LmphdmE6Nzg4KQ0KCWF0IG9yZy5lY2xpcHNlLmNv cmUuaW50ZXJu
YWwucmVnaXN0cnkuQ29uZmlndXJhdGlvbkVsZW1lbnQuY3JlYXRlRXhlY3V0 YWJsZUV4dGVu
c2lvbihDb25maWd1cmF0aW9uRWxlbWVudC5qYXZhOjI0MykNCglhdCBvcmcu ZWNsaXBzZS5j
b3JlLmludGVybmFsLnJlZ2lzdHJ5LkNvbmZpZ3VyYXRpb25FbGVtZW50SGFu ZGxlLmNyZWF0
ZUV4ZWN1dGFibGVFeHRlbnNpb24oQ29uZmlndXJhdGlvbkVsZW1lbnRIYW5k bGUuamF2YTo1
MSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2hQbHVn aW4kMS5ydW4o
V29ya2JlbmNoUGx1Z2luLmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xpcHNlLnN3 dC5jdXN0b20u
QnVzeUluZGljYXRvci5zaG93V2hpbGUoQnVzeUluZGljYXRvci5qYXZhOjQ5 KQ0KCWF0IG9y
Zy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaFBsdWdpbi5jcmVhdGVF eHRlbnNpb24o
V29ya2JlbmNoUGx1Z2luLmphdmE6MjM5KQ0KCWF0IG9yZy5lY2xpcHNlLnVp LmludGVybmFs
LkVhcmx5U3RhcnR1cFJ1bm5hYmxlLmdldEV4ZWN1dGFibGVFeHRlbnNpb24o RWFybHlTdGFy
dHVwUnVubmFibGUuamF2YToxMTcpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50 ZXJuYWwuRWFy
bHlTdGFydHVwUnVubmFibGUucnVuKEVhcmx5U3RhcnR1cFJ1bm5hYmxlLmph dmE6NjYpDQoJ
YXQgb3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLlNhZmVSdW5uZXIucnVuKFNh ZmVSdW5uZXIu
amF2YTozNykNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVu Y2gkNTQucnVu
KFdvcmtiZW5jaC5qYXZhOjIxOTApDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5p bnRlcm5hbC5q
b2JzLldvcmtlci5ydW4oV29ya2VyLmphdmE6NTUpDQohU1VCRU5UUlkgMSBv cmcuZWNsaXBz
ZS5lcXVpbm94LnJlZ2lzdHJ5IDQgMSAyMDA3LTA3LTIzIDIxOjU1OjA4LjQz Nw0KIU1FU1NB
R0UgUGx1Zy1pbiBvcmcuZWNsaXBzZS5waHAueGRlYnVnLnVpIHdhcyB1bmFi bGUgdG8gbG9h
ZCBjbGFzcyBvcmcuZWNsaXBzZS5waHAueGRlYnVnLnVpLkVhcmx5U3RhcnQu DQohU1RBQ0sg
MA0KamF2YS5sYW5nLkNsYXNzTm90Rm91bmRFeGNlcHRpb246IG9yZy5lY2xp cHNlLnBocC54
ZGVidWcudWkuRWFybHlTdGFydA0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRl ci5maW5kQ2xh
c3MoVW5rbm93biBTb3VyY2UpDQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVy LmxvYWRDbGFz
cyhVbmtub3duIFNvdXJjZSkNCglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIu bG9hZENsYXNz
KFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3 b3JrLmludGVy
bmFsLmNvcmUuQnVuZGxlTG9hZGVyLmZpbmRDbGFzc0ludGVybmFsKEJ1bmRs ZUxvYWRlci5q
YXZhOjQyOSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRl cm5hbC5jb3Jl
LkJ1bmRsZUxvYWRlci5maW5kQ2xhc3MoQnVuZGxlTG9hZGVyLmphdmE6MzY5 KQ0KCWF0IG9y
Zy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxl TG9hZGVyLmZp
bmRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YTozNTcpDQoJYXQgb3JnLmVjbGlw c2Uub3NnaS5p
bnRlcm5hbC5iYXNlYWRhcHRvci5EZWZhdWx0Q2xhc3NMb2FkZXIubG9hZENs YXNzKERlZmF1
bHRDbGFzc0xvYWRlci5qYXZhOjgzKQ0KCWF0IGphdmEubGFuZy5DbGFzc0xv YWRlci5sb2Fk
Q2xhc3MoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5m cmFtZXdvcmsu
aW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIubG9hZENsYXNzKEJ1bmRsZUxv YWRlci5qYXZh
OjI4OSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5h bC5jb3JlLkJ1
bmRsZUhvc3QubG9hZENsYXNzKEJ1bmRsZUhvc3QuamF2YToyMjcpDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5BYnN0cmFjdEJ1bmRs ZS5sb2FkQ2xh
c3MoQWJzdHJhY3RCdW5kbGUuamF2YToxMjY5KQ0KCWF0IG9yZy5lY2xpcHNl LmNvcmUuaW50
ZXJuYWwucmVnaXN0cnkub3NnaS5SZWdpc3RyeVN0cmF0ZWd5T1NHSS5jcmVh dGVFeGVjdXRh
YmxlRXh0ZW5zaW9uKFJlZ2lzdHJ5U3RyYXRlZ3lPU0dJLmphdmE6MTYwKQ0K CWF0IG9yZy5l
Y2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkuRXh0ZW5zaW9uUmVnaXN0 cnkuY3JlYXRl
RXhlY3V0YWJsZUV4dGVuc2lvbihFeHRlbnNpb25SZWdpc3RyeS5qYXZhOjc4 OCkNCglhdCBv
cmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5LkNvbmZpZ3VyYXRp b25FbGVtZW50
LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oQ29uZmlndXJhdGlvbkVsZW1l bnQuamF2YToy
NDMpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZWdpc3RyeS5D b25maWd1cmF0
aW9uRWxlbWVudEhhbmRsZS5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9uKENv bmZpZ3VyYXRp
b25FbGVtZW50SGFuZGxlLmphdmE6NTEpDQoJYXQgb3JnLmVjbGlwc2UudWku aW50ZXJuYWwu
V29ya2JlbmNoUGx1Z2luJDEucnVuKFdvcmtiZW5jaFBsdWdpbi5qYXZhOjI0 MykNCglhdCBv
cmcuZWNsaXBzZS5zd3QuY3VzdG9tLkJ1c3lJbmRpY2F0b3Iuc2hvd1doaWxl KEJ1c3lJbmRp
Y2F0b3IuamF2YTo0OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5X b3JrYmVuY2hQ
bHVnaW4uY3JlYXRlRXh0ZW5zaW9uKFdvcmtiZW5jaFBsdWdpbi5qYXZhOjIz OSkNCglhdCBv
cmcuZWNsaXBzZS51aS5pbnRlcm5hbC5FYXJseVN0YXJ0dXBSdW5uYWJsZS5n ZXRFeGVjdXRh
YmxlRXh0ZW5zaW9uKEVhcmx5U3RhcnR1cFJ1bm5hYmxlLmphdmE6MTE3KQ0K CWF0IG9yZy5l
Y2xpcHNlLnVpLmludGVybmFsLkVhcmx5U3RhcnR1cFJ1bm5hYmxlLnJ1bihF YXJseVN0YXJ0
dXBSdW5uYWJsZS5qYXZhOjY2KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVu dGltZS5TYWZl
UnVubmVyLnJ1bihTYWZlUnVubmVyLmphdmE6MzcpDQoJYXQgb3JnLmVjbGlw c2UudWkuaW50
ZXJuYWwuV29ya2JlbmNoJDU0LnJ1bihXb3JrYmVuY2guamF2YToyMTkwKQ0K CWF0IG9yZy5l
Y2xpcHNlLmNvcmUuaW50ZXJuYWwuam9icy5Xb3JrZXIucnVuKFdvcmtlci5q YXZhOjU1KQ0K
DQohRU5UUlkgb3JnLmVjbGlwc2Uub3NnaSAyIDAgMjAwNy0wNy0yMyAyMTo1 NToxNS42NzEN
CiFNRVNTQUdFIFRoZSBhY3RpdmF0b3Igb3JnLmVjbGlwc2UucGhwLnhkZWJ1 Zy51aS5BY3Rp
dmF0b3IgZm9yIGJ1bmRsZSBvcmcuZWNsaXBzZS5waHAueGRlYnVnLnVpIGlz IGludmFsaWQN
CiFTVEFDSyAwDQpvcmcub3NnaS5mcmFtZXdvcmsuQnVuZGxlRXhjZXB0aW9u OiBUaGUgYWN0
aXZhdG9yIG9yZy5lY2xpcHNlLnBocC54ZGVidWcudWkuQWN0aXZhdG9yIGZv ciBidW5kbGUg
b3JnLmVjbGlwc2UucGhwLnhkZWJ1Zy51aSBpcyBpbnZhbGlkDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5BYnN0cmFjdEJ1bmRsZS5s b2FkQnVuZGxl
QWN0aXZhdG9yKEFic3RyYWN0QnVuZGxlLmphdmE6MTQxKQ0KCWF0IG9yZy5l Y2xpcHNlLm9z
Z2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlQ29udGV4dEltcGwu c3RhcnQoQnVu
ZGxlQ29udGV4dEltcGwuamF2YTo5NzApDQoJYXQgb3JnLmVjbGlwc2Uub3Nn aS5mcmFtZXdv
cmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0LnN0YXJ0V29ya2VyKEJ1bmRs ZUhvc3QuamF2
YTozNDYpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJu YWwuY29yZS5B
YnN0cmFjdEJ1bmRsZS5zdGFydChBYnN0cmFjdEJ1bmRsZS5qYXZhOjI2MCkN CglhdCBvcmcu
ZWNsaXBzZS5vc2dpLmZyYW1ld29yay51dGlsLlNlY3VyZUFjdGlvbi5zdGFy dChTZWN1cmVB
Y3Rpb24uamF2YTo0MDApDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdv cmsuaW50ZXJu
YWwuY29yZS5CdW5kbGVIb3N0LmxvYWRDbGFzcyhCdW5kbGVIb3N0LmphdmE6 MjM0KQ0KCWF0
IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQWJz dHJhY3RCdW5k
bGUubG9hZENsYXNzKEFic3RyYWN0QnVuZGxlLmphdmE6MTI2OSkNCglhdCBv cmcuZWNsaXBz
ZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5Lm9zZ2kuUmVnaXN0cnlTdHJhdGVn eU9TR0kuY3Jl
YXRlRXhlY3V0YWJsZUV4dGVuc2lvbihSZWdpc3RyeVN0cmF0ZWd5T1NHSS5q YXZhOjE2MCkN
CglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5LkV4dGVu c2lvblJlZ2lz
dHJ5LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oRXh0ZW5zaW9uUmVnaXN0 cnkuamF2YTo3
ODgpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZWdpc3RyeS5D b25maWd1cmF0
aW9uRWxlbWVudC5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9uKENvbmZpZ3Vy YXRpb25FbGVt
ZW50LmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwu cmVnaXN0cnku
Q29uZmlndXJhdGlvbkVsZW1lbnRIYW5kbGUuY3JlYXRlRXhlY3V0YWJsZUV4 dGVuc2lvbihD
b25maWd1cmF0aW9uRWxlbWVudEhhbmRsZS5qYXZhOjUxKQ0KCWF0IG9yZy5l Y2xpcHNlLnBo
cC5pbnRlcm5hbC51aS5wcmVmZXJlbmNlcy5QSFBQcmVmZXJlbmNlUGFnZUJs b2Nrc1JlZ2lz
dHJ5JFBIUFByZWZlcmVuY2VQYWdlQmxvY2tzRmFjdG9yeSQxLnJ1bihVbmtu b3duIFNvdXJj
ZSkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuU2FmZVJ1bm5lci5y dW4oU2FmZVJ1
bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xpcHNlLnBocC5pbnRlcm5hbC51 aS5wcmVmZXJl
bmNlcy5QSFBQcmVmZXJlbmNlUGFnZUJsb2Nrc1JlZ2lzdHJ5JFBIUFByZWZl cmVuY2VQYWdl
QmxvY2tzRmFjdG9yeS5jcmVhdGVQSFBQcmVmZXJlbmNlUGFnZUJsb2NrKFVu a25vd24gU291
cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLnBocC5pbnRlcm5hbC51aS5wcmVmZXJl bmNlcy5QSFBQ
cmVmZXJlbmNlUGFnZUJsb2Nrc1JlZ2lzdHJ5LmdldEJsb2NrcyhVbmtub3du IFNvdXJjZSkN
CglhdCBvcmcuZWNsaXBzZS5waHAuaW50ZXJuYWwudWkucHJlZmVyZW5jZXMu UEhQUHJlZmVy
ZW5jZVBhZ2VCbG9ja3NSZWdpc3RyeS5nZXRQSFBQcmVmZXJlbmNlUGFnZUJs b2NrKFVua25v
d24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLnBocC5pbnRlcm5hbC51aS5w cmVmZXJlbmNl
cy5BYnN0cmFjdFBIUFByb3BlcnR5UHJlZmVyZW5jZVBhZ2UuY3JlYXRlV29y a3NwYWNlQ29u
dGVudHMoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2UucGhwLmlu dGVybmFsLnVp
LnByZWZlcmVuY2VzLkFic3RyYWN0UEhQUHJvcGVydHlQcmVmZXJlbmNlUGFn ZS5jcmVhdGVD
b250ZW50cyhVbmtub3duIFNvdXJjZSkNCglhdCBvcmcuZWNsaXBzZS5qZmFj ZS5wcmVmZXJl
bmNlLlByZWZlcmVuY2VQYWdlLmNyZWF0ZUNvbnRyb2woUHJlZmVyZW5jZVBh Z2UuamF2YToy
MzMpDQoJYXQgb3JnLmVjbGlwc2UucGhwLmludGVybmFsLnVpLnByZWZlcmVu Y2VzLkFic3Ry
YWN0UEhQUHJvcGVydHlQcmVmZXJlbmNlUGFnZS5jcmVhdGVDb250cm9sKFVu a25vd24gU291
cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnByZWZlcmVuY2UuUHJlZmVy ZW5jZURpYWxv
Zy5jcmVhdGVQYWdlQ29udHJvbChQcmVmZXJlbmNlRGlhbG9nLmphdmE6MTQ1 NikNCglhdCBv
cmcuZWNsaXBzZS5qZmFjZS5wcmVmZXJlbmNlLlByZWZlcmVuY2VEaWFsb2ck MTMucnVuKFBy
ZWZlcmVuY2VEaWFsb2cuamF2YToxMjEzKQ0KCWF0IG9yZy5lY2xpcHNlLmNv cmUucnVudGlt
ZS5TYWZlUnVubmVyLnJ1bihTYWZlUnVubmVyLmphdmE6MzcpDQoJYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5ydW50aW1lLlBsYXRmb3JtLnJ1bihQbGF0Zm9ybS5qYXZhOjg1NykN CglhdCBvcmcu
ZWNsaXBzZS51aS5pbnRlcm5hbC5KRmFjZVV0aWwkMS5ydW4oSkZhY2VVdGls LmphdmE6NDYp
DQoJYXQgb3JnLmVjbGlwc2UuamZhY2UudXRpbC5TYWZlUnVubmFibGUucnVu KFNhZmVSdW5u
YWJsZS5qYXZhOjE5MykNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5wcmVmZXJl bmNlLlByZWZl
cmVuY2VEaWFsb2cuc2hvd1BhZ2UoUHJlZmVyZW5jZURpYWxvZy5qYXZhOjEy MDcpDQoJYXQg
b3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuZGlhbG9ncy5GaWx0ZXJlZFByZWZl cmVuY2VEaWFs
b2cuc2hvd1BhZ2UoRmlsdGVyZWRQcmVmZXJlbmNlRGlhbG9nLmphdmE6NDMz KQ0KCWF0IG9y
Zy5lY2xpcHNlLmpmYWNlLnByZWZlcmVuY2UuUHJlZmVyZW5jZURpYWxvZyQ5 LnNlbGVjdGlv
bkNoYW5nZWQoUHJlZmVyZW5jZURpYWxvZy5qYXZhOjY5OCkNCglhdCBvcmcu ZWNsaXBzZS5q
ZmFjZS52aWV3ZXJzLlN0cnVjdHVyZWRWaWV3ZXIkMy5ydW4oU3RydWN0dXJl ZFZpZXdlci5q
YXZhOjg0MikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuU2FmZVJ1 bm5lci5ydW4o
U2FmZVJ1bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVu dGltZS5QbGF0
Zm9ybS5ydW4oUGxhdGZvcm0uamF2YTo4NTcpDQoJYXQgb3JnLmVjbGlwc2Uu dWkuaW50ZXJu
YWwuSkZhY2VVdGlsJDEucnVuKEpGYWNlVXRpbC5qYXZhOjQ2KQ0KCWF0IG9y Zy5lY2xpcHNl
LmpmYWNlLnV0aWwuU2FmZVJ1bm5hYmxlLnJ1bihTYWZlUnVubmFibGUuamF2 YToxOTMpDQoJ
YXQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5TdHJ1Y3R1cmVkVmlld2Vy LmZpcmVQb3N0
U2VsZWN0aW9uQ2hhbmdlZChTdHJ1Y3R1cmVkVmlld2VyLmphdmE6ODQwKQ0K CWF0IG9yZy5l
Y2xpcHNlLmpmYWNlLnZpZXdlcnMuU3RydWN0dXJlZFZpZXdlci5oYW5kbGVQ b3N0U2VsZWN0
KFN0cnVjdHVyZWRWaWV3ZXIuamF2YToxMTUzKQ0KCWF0IG9yZy5lY2xpcHNl LmpmYWNlLnZp
ZXdlcnMuU3RydWN0dXJlZFZpZXdlciQ1LndpZGdldFNlbGVjdGVkKFN0cnVj dHVyZWRWaWV3
ZXIuamF2YToxMTc4KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnV0aWwuT3Bl blN0cmF0ZWd5
LmZpcmVQb3N0U2VsZWN0aW9uRXZlbnQoT3BlblN0cmF0ZWd5LmphdmE6MjUw KQ0KCWF0IG9y
Zy5lY2xpcHNlLmpmYWNlLnV0aWwuT3BlblN0cmF0ZWd5LmFjY2VzcyQ0KE9w ZW5TdHJhdGVn
eS5qYXZhOjI0NCkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS51dGlsLk9wZW5T dHJhdGVneSQz
LnJ1bihPcGVuU3RyYXRlZ3kuamF2YTo0MTgpDQoJYXQgb3JnLmVjbGlwc2Uu c3d0LndpZGdl
dHMuUnVubmFibGVMb2NrLnJ1bihSdW5uYWJsZUxvY2suamF2YTozNSkNCglh dCBvcmcuZWNs
aXBzZS5zd3Qud2lkZ2V0cy5TeW5jaHJvbml6ZXIucnVuQXN5bmNNZXNzYWdl cyhTeW5jaHJv
bml6ZXIuamF2YToxMjMpDQoJYXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMu RGlzcGxheS5y
dW5Bc3luY01lc3NhZ2VzKERpc3BsYXkuamF2YTozNjU5KQ0KCWF0IG9yZy5l Y2xpcHNlLnN3
dC53aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNoKERpc3BsYXkuamF2 YTozMjk2KQ0K
CWF0IG9yZy5lY2xpcHNlLmpmYWNlLndpbmRvdy5XaW5kb3cucnVuRXZlbnRM b29wKFdpbmRv
dy5qYXZhOjgyMCkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS53aW5kb3cuV2lu ZG93Lm9wZW4o
V2luZG93LmphdmE6Nzk2KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFs Lk9wZW5QcmVm
ZXJlbmNlc0FjdGlvbi5ydW4oT3BlblByZWZlcmVuY2VzQWN0aW9uLmphdmE6 NjUpDQoJYXQg
b3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlvbi5ydW5XaXRoRXZlbnQo QWN0aW9uLmph
dmE6NDk4KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmFjdGlvbi5BY3Rpb25D b250cmlidXRp
b25JdGVtLmhhbmRsZVdpZGdldFNlbGVjdGlvbihBY3Rpb25Db250cmlidXRp b25JdGVtLmph
dmE6NTQ1KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmFjdGlvbi5BY3Rpb25D b250cmlidXRp
b25JdGVtLmFjY2VzcyQyKEFjdGlvbkNvbnRyaWJ1dGlvbkl0ZW0uamF2YTo0 OTApDQoJYXQg
b3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlvbkNvbnRyaWJ1dGlvbkl0 ZW0kNS5oYW5k
bGVFdmVudChBY3Rpb25Db250cmlidXRpb25JdGVtLmphdmE6NDAyKQ0KCWF0 IG9yZy5lY2xp
cHNlLnN3dC53aWRnZXRzLkV2ZW50VGFibGUuc2VuZEV2ZW50KEV2ZW50VGFi bGUuamF2YTo2
NikNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5XaWRnZXQuc2VuZEV2 ZW50KFdpZGdl
dC5qYXZhOjkzOCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5EaXNw bGF5LnJ1bkRl
ZmVycmVkRXZlbnRzKERpc3BsYXkuamF2YTozNjgyKQ0KCWF0IG9yZy5lY2xp cHNlLnN3dC53
aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNoKERpc3BsYXkuamF2YToz MjkzKQ0KCWF0
IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaC5ydW5FdmVudExv b3AoV29ya2Jl
bmNoLmphdmE6MjM4OSkNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5X b3JrYmVuY2gu
cnVuVUkoV29ya2JlbmNoLmphdmE6MjM1MykNCglhdCBvcmcuZWNsaXBzZS51 aS5pbnRlcm5h
bC5Xb3JrYmVuY2guYWNjZXNzJDQoV29ya2JlbmNoLmphdmE6MjIxOSkNCglh dCBvcmcuZWNs
aXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2gkNC5ydW4oV29ya2JlbmNoLmph dmE6NDY2KQ0K
CWF0IG9yZy5lY2xpcHNlLmNvcmUuZGF0YWJpbmRpbmcub2JzZXJ2YWJsZS5S ZWFsbS5ydW5X
aXRoRGVmYXVsdChSZWFsbS5qYXZhOjI4OSkNCglhdCBvcmcuZWNsaXBzZS51 aS5pbnRlcm5h
bC5Xb3JrYmVuY2guY3JlYXRlQW5kUnVuV29ya2JlbmNoKFdvcmtiZW5jaC5q YXZhOjQ2MSkN
CglhdCBvcmcuZWNsaXBzZS51aS5QbGF0Zm9ybVVJLmNyZWF0ZUFuZFJ1bldv cmtiZW5jaChQ
bGF0Zm9ybVVJLmphdmE6MTQ5KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVy bmFsLmlkZS5h
cHBsaWNhdGlvbi5JREVBcHBsaWNhdGlvbi5zdGFydChJREVBcHBsaWNhdGlv bi5qYXZhOjEw
NikNCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94LmludGVybmFsLmFwcC5FY2xp cHNlQXBwSGFu
ZGxlLnJ1bihFY2xpcHNlQXBwSGFuZGxlLmphdmE6MTUzKQ0KCWF0IG9yZy5l Y2xpcHNlLmNv
cmUucnVudGltZS5pbnRlcm5hbC5hZGFwdG9yLkVjbGlwc2VBcHBMYXVuY2hl ci5ydW5BcHBs
aWNhdGlvbihFY2xpcHNlQXBwTGF1bmNoZXIuamF2YToxMDYpDQoJYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5ydW50aW1lLmludGVybmFsLmFkYXB0b3IuRWNsaXBzZUFwcExhdW5j aGVyLnN0YXJ0
KEVjbGlwc2VBcHBMYXVuY2hlci5qYXZhOjc2KQ0KCWF0IG9yZy5lY2xpcHNl LmNvcmUucnVu
dGltZS5hZGFwdG9yLkVjbGlwc2VTdGFydGVyLnJ1bihFY2xpcHNlU3RhcnRl ci5qYXZhOjM2
MykNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuYWRhcHRvci5FY2xp cHNlU3RhcnRl
ci5ydW4oRWNsaXBzZVN0YXJ0ZXIuamF2YToxNzYpDQoJYXQgc3VuLnJlZmxl Y3QuTmF0aXZl
TWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZTAoTmF0aXZlIE1ldGhvZCkNCglh dCBzdW4ucmVm
bGVjdC5OYXRpdmVNZXRob2RBY2Nlc3NvckltcGwuaW52b2tlKFVua25vd24g U291cmNlKQ0K
CWF0IHN1bi5yZWZsZWN0LkRlbGVnYXRpbmdNZXRob2RBY2Nlc3NvckltcGwu aW52b2tlKFVu
a25vd24gU291cmNlKQ0KCWF0IGphdmEubGFuZy5yZWZsZWN0Lk1ldGhvZC5p bnZva2UoVW5r
bm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2UuZXF1aW5veC5sYXVuY2hl ci5NYWluLmlu
dm9rZUZyYW1ld29yayhNYWluLmphdmE6NTA0KQ0KCWF0IG9yZy5lY2xpcHNl LmVxdWlub3gu
bGF1bmNoZXIuTWFpbi5iYXNpY1J1bihNYWluLmphdmE6NDQzKQ0KCWF0IG9y Zy5lY2xpcHNl
LmVxdWlub3gubGF1bmNoZXIuTWFpbi5ydW4oTWFpbi5qYXZhOjExNjkpDQpD YXVzZWQgYnk6
IGphdmEubGFuZy5DbGFzc05vdEZvdW5kRXhjZXB0aW9uOiBvcmcuZWNsaXBz ZS5waHAueGRl
YnVnLnVpLkFjdGl2YXRvcg0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRlci5m aW5kQ2xhc3Mo
VW5rbm93biBTb3VyY2UpDQoJYXQgamF2YS5sYW5nLkNsYXNzTG9hZGVyLmxv YWRDbGFzcyhV
bmtub3duIFNvdXJjZSkNCglhdCBqYXZhLmxhbmcuQ2xhc3NMb2FkZXIubG9h ZENsYXNzKFVu
a25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3Jr LmludGVybmFs
LmNvcmUuQnVuZGxlTG9hZGVyLmZpbmRDbGFzc0ludGVybmFsKEJ1bmRsZUxv YWRlci5qYXZh
OjQyOSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5h bC5jb3JlLkJ1
bmRsZUxvYWRlci5maW5kQ2xhc3MoQnVuZGxlTG9hZGVyLmphdmE6MzY5KQ0K CWF0IG9yZy5l
Y2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxlTG9h ZGVyLmZpbmRD
bGFzcyhCdW5kbGVMb2FkZXIuamF2YTozNTcpDQoJYXQgb3JnLmVjbGlwc2Uu b3NnaS5pbnRl
cm5hbC5iYXNlYWRhcHRvci5EZWZhdWx0Q2xhc3NMb2FkZXIubG9hZENsYXNz KERlZmF1bHRD
bGFzc0xvYWRlci5qYXZhOjgzKQ0KCWF0IGphdmEubGFuZy5DbGFzc0xvYWRl ci5sb2FkQ2xh
c3MoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFt ZXdvcmsuaW50
ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIubG9hZENsYXNzKEJ1bmRsZUxvYWRl ci5qYXZhOjI4
OSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay5pbnRlcm5hbC5j b3JlLkJ1bmRs
ZUhvc3QubG9hZENsYXNzKEJ1bmRsZUhvc3QuamF2YToyMjcpDQoJYXQgb3Jn LmVjbGlwc2Uu
QWN0aXZhdG9yKEFic3RyYWN0QnVuZGxlLmphdmE6MTM0KQ0KCS4uLiA3NCBt b3JlDQpSb290
IGV4Y2VwdGlvbjoNCmphdmEubGFuZy5DbGFzc05vdEZvdW5kRXhjZXB0aW9u OiBvcmcuZWNs
aXBzZS5waHAueGRlYnVnLnVpLkFjdGl2YXRvcg0KCWF0IGphdmEubGFuZy5D bGFzc0xvYWRl
ci5maW5kQ2xhc3MoVW5rbm93biBTb3VyY2UpDQoJYXQgamF2YS5sYW5nLkNs YXNzTG9hZGVy
LmxvYWRDbGFzcyhVbmtub3duIFNvdXJjZSkNCglhdCBqYXZhLmxhbmcuQ2xh c3NMb2FkZXIu
bG9hZENsYXNzKFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLm9z Z2kuZnJhbWV3
b3JrLmludGVybmFsLmNvcmUuQnVuZGxlTG9hZGVyLmZpbmRDbGFzc0ludGVy bmFsKEJ1bmRs
ZUxvYWRlci5qYXZhOjQyOSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1l d29yay5pbnRl
cm5hbC5jb3JlLkJ1bmRsZUxvYWRlci5maW5kQ2xhc3MoQnVuZGxlTG9hZGVy LmphdmE6MzY5
TG9hZGVyLmZpbmRDbGFzcyhCdW5kbGVMb2FkZXIuamF2YTozNTcpDQoJYXQg b3JnLmVjbGlw
c2Uub3NnaS5pbnRlcm5hbC5iYXNlYWRhcHRvci5EZWZhdWx0Q2xhc3NMb2Fk ZXIubG9hZENs
YXNzKERlZmF1bHRDbGFzc0xvYWRlci5qYXZhOjgzKQ0KCWF0IGphdmEubGFu Zy5DbGFzc0xv
YWRlci5sb2FkQ2xhc3MoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlw c2Uub3NnaS5m
cmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVMb2FkZXIubG9hZENsYXNz KEJ1bmRsZUxv
YWRlci5qYXZhOjI4OSkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29y ay5pbnRlcm5h
bC5jb3JlLkJ1bmRsZUhvc3QubG9hZENsYXNzKEJ1bmRsZUhvc3QuamF2YToy MjcpDQoJYXQg
b3JnLmVjbGlwc2Uub3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5BYnN0 cmFjdEJ1bmRs
ZS5sb2FkQnVuZGxlQWN0aXZhdG9yKEFic3RyYWN0QnVuZGxlLmphdmE6MTM0 KQ0KCWF0IG9y
Zy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVybmFsLmNvcmUuQnVuZGxl Q29udGV4dElt
cGwuc3RhcnQoQnVuZGxlQ29udGV4dEltcGwuamF2YTo5NzApDQoJYXQgb3Jn LmVjbGlwc2Uu
b3NnaS5mcmFtZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0LnN0YXJ0 V29ya2VyKEJ1
bmRsZUhvc3QuamF2YTozNDYpDQoJYXQgb3JnLmVjbGlwc2Uub3NnaS5mcmFt ZXdvcmsuaW50
ZXJuYWwuY29yZS5BYnN0cmFjdEJ1bmRsZS5zdGFydChBYnN0cmFjdEJ1bmRs ZS5qYXZhOjI2
MCkNCglhdCBvcmcuZWNsaXBzZS5vc2dpLmZyYW1ld29yay51dGlsLlNlY3Vy ZUFjdGlvbi5z
dGFydChTZWN1cmVBY3Rpb24uamF2YTo0MDApDQoJYXQgb3JnLmVjbGlwc2Uu b3NnaS5mcmFt
ZXdvcmsuaW50ZXJuYWwuY29yZS5CdW5kbGVIb3N0LmxvYWRDbGFzcyhCdW5k bGVIb3N0Lmph
dmE6MjM0KQ0KCWF0IG9yZy5lY2xpcHNlLm9zZ2kuZnJhbWV3b3JrLmludGVy bmFsLmNvcmUu
QWJzdHJhY3RCdW5kbGUubG9hZENsYXNzKEFic3RyYWN0QnVuZGxlLmphdmE6 MTI2OSkNCglh
dCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJlZ2lzdHJ5Lm9zZ2kuUmVn aXN0cnlTdHJh
dGVneU9TR0kuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihSZWdpc3RyeVN0 cmF0ZWd5T1NH
SS5qYXZhOjE2MCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFsLnJl Z2lzdHJ5LkV4
dGVuc2lvblJlZ2lzdHJ5LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNpb24oRXh0 ZW5zaW9uUmVn
aXN0cnkuamF2YTo3ODgpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5pbnRlcm5h bC5yZWdpc3Ry
eS5Db25maWd1cmF0aW9uRWxlbWVudC5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5z aW9uKENvbmZp
Z3VyYXRpb25FbGVtZW50LmphdmE6MjQzKQ0KCWF0IG9yZy5lY2xpcHNlLmNv cmUuaW50ZXJu
YWwucmVnaXN0cnkuQ29uZmlndXJhdGlvbkVsZW1lbnRIYW5kbGUuY3JlYXRl RXhlY3V0YWJs
ZUV4dGVuc2lvbihDb25maWd1cmF0aW9uRWxlbWVudEhhbmRsZS5qYXZhOjUx KQ0KCWF0IG9y
Zy5lY2xpcHNlLnBocC5pbnRlcm5hbC51aS5wcmVmZXJlbmNlcy5QSFBQcmVm ZXJlbmNlUGFn
ZUJsb2Nrc1JlZ2lzdHJ5JFBIUFByZWZlcmVuY2VQYWdlQmxvY2tzRmFjdG9y eSQxLnJ1bihV
bmtub3duIFNvdXJjZSkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUu U2FmZVJ1bm5l
ci5ydW4oU2FmZVJ1bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xpcHNlLnBo cC5pbnRlcm5h
bC51aS5wcmVmZXJlbmNlcy5QSFBQcmVmZXJlbmNlUGFnZUJsb2Nrc1JlZ2lz dHJ5JFBIUFBy
ZWZlcmVuY2VQYWdlQmxvY2tzRmFjdG9yeS5jcmVhdGVQSFBQcmVmZXJlbmNl UGFnZUJsb2Nr
KFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLnBocC5pbnRlcm5h bC51aS5wcmVm
ZXJlbmNlcy5QSFBQcmVmZXJlbmNlUGFnZUJsb2Nrc1JlZ2lzdHJ5LmdldEJs b2NrcyhVbmtu
b3duIFNvdXJjZSkNCglhdCBvcmcuZWNsaXBzZS5waHAuaW50ZXJuYWwudWku cHJlZmVyZW5j
ZXMuUEhQUHJlZmVyZW5jZVBhZ2VCbG9ja3NSZWdpc3RyeS5nZXRQSFBQcmVm ZXJlbmNlUGFn
ZUJsb2NrKFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLnBocC5p bnRlcm5hbC51
aS5wcmVmZXJlbmNlcy5BYnN0cmFjdFBIUFByb3BlcnR5UHJlZmVyZW5jZVBh Z2UuY3JlYXRl
V29ya3NwYWNlQ29udGVudHMoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVj bGlwc2UucGhw
LmludGVybmFsLnVpLnByZWZlcmVuY2VzLkFic3RyYWN0UEhQUHJvcGVydHlQ cmVmZXJlbmNl
UGFnZS5jcmVhdGVDb250ZW50cyhVbmtub3duIFNvdXJjZSkNCglhdCBvcmcu ZWNsaXBzZS5q
ZmFjZS5wcmVmZXJlbmNlLlByZWZlcmVuY2VQYWdlLmNyZWF0ZUNvbnRyb2wo UHJlZmVyZW5j
ZVBhZ2UuamF2YToyMzMpDQoJYXQgb3JnLmVjbGlwc2UucGhwLmludGVybmFs LnVpLnByZWZl
cmVuY2VzLkFic3RyYWN0UEhQUHJvcGVydHlQcmVmZXJlbmNlUGFnZS5jcmVh dGVDb250cm9s
KFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnByZWZl cmVuY2UuUHJl
ZmVyZW5jZURpYWxvZy5jcmVhdGVQYWdlQ29udHJvbChQcmVmZXJlbmNlRGlh bG9nLmphdmE6
MTQ1NikNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5wcmVmZXJlbmNlLlByZWZl cmVuY2VEaWFs
b2ckMTMucnVuKFByZWZlcmVuY2VEaWFsb2cuamF2YToxMjEzKQ0KCWF0IG9y Zy5lY2xpcHNl
LmNvcmUucnVudGltZS5TYWZlUnVubmVyLnJ1bihTYWZlUnVubmVyLmphdmE6 MzcpDQoJYXQg
b3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLlBsYXRmb3JtLnJ1bihQbGF0Zm9y bS5qYXZhOjg1
NykNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5KRmFjZVV0aWwkMS5y dW4oSkZhY2VV
dGlsLmphdmE6NDYpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UudXRpbC5TYWZl UnVubmFibGUu
cnVuKFNhZmVSdW5uYWJsZS5qYXZhOjE5MykNCglhdCBvcmcuZWNsaXBzZS5q ZmFjZS5wcmVm
ZXJlbmNlLlByZWZlcmVuY2VEaWFsb2cuc2hvd1BhZ2UoUHJlZmVyZW5jZURp YWxvZy5qYXZh
OjEyMDcpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuZGlhbG9ncy5G aWx0ZXJlZFBy
ZWZlcmVuY2VEaWFsb2cuc2hvd1BhZ2UoRmlsdGVyZWRQcmVmZXJlbmNlRGlh bG9nLmphdmE6
NDMzKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnByZWZlcmVuY2UuUHJlZmVy ZW5jZURpYWxv
ZyQ5LnNlbGVjdGlvbkNoYW5nZWQoUHJlZmVyZW5jZURpYWxvZy5qYXZhOjY5 OCkNCglhdCBv
cmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLlN0cnVjdHVyZWRWaWV3ZXIkMy5y dW4oU3RydWN0
dXJlZFZpZXdlci5qYXZhOjg0MikNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1 bnRpbWUuU2Fm
ZVJ1bm5lci5ydW4oU2FmZVJ1bm5lci5qYXZhOjM3KQ0KCWF0IG9yZy5lY2xp cHNlLmNvcmUu
cnVudGltZS5QbGF0Zm9ybS5ydW4oUGxhdGZvcm0uamF2YTo4NTcpDQoJYXQg b3JnLmVjbGlw
c2UudWkuaW50ZXJuYWwuSkZhY2VVdGlsJDEucnVuKEpGYWNlVXRpbC5qYXZh OjQ2KQ0KCWF0
IG9yZy5lY2xpcHNlLmpmYWNlLnV0aWwuU2FmZVJ1bm5hYmxlLnJ1bihTYWZl UnVubmFibGUu
amF2YToxOTMpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5TdHJ1 Y3R1cmVkVmll
d2VyLmZpcmVQb3N0U2VsZWN0aW9uQ2hhbmdlZChTdHJ1Y3R1cmVkVmlld2Vy LmphdmE6ODQw
KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnZpZXdlcnMuU3RydWN0dXJlZFZp ZXdlci5oYW5k
bGVQb3N0U2VsZWN0KFN0cnVjdHVyZWRWaWV3ZXIuamF2YToxMTUzKQ0KCWF0 IG9yZy5lY2xp
cHNlLmpmYWNlLnZpZXdlcnMuU3RydWN0dXJlZFZpZXdlciQ1LndpZGdldFNl bGVjdGVkKFN0
cnVjdHVyZWRWaWV3ZXIuamF2YToxMTc4KQ0KCWF0IG9yZy5lY2xpcHNlLmpm YWNlLnV0aWwu
T3BlblN0cmF0ZWd5LmZpcmVQb3N0U2VsZWN0aW9uRXZlbnQoT3BlblN0cmF0 ZWd5LmphdmE6
MjUwKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnV0aWwuT3BlblN0cmF0ZWd5 LmFjY2VzcyQ0
KE9wZW5TdHJhdGVneS5qYXZhOjI0NCkNCglhdCBvcmcuZWNsaXBzZS5qZmFj ZS51dGlsLk9w
ZW5TdHJhdGVneSQzLnJ1bihPcGVuU3RyYXRlZ3kuamF2YTo0MTgpDQoJYXQg b3JnLmVjbGlw
c2Uuc3d0LndpZGdldHMuUnVubmFibGVMb2NrLnJ1bihSdW5uYWJsZUxvY2su amF2YTozNSkN
CglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5TeW5jaHJvbml6ZXIucnVu QXN5bmNNZXNz
YWdlcyhTeW5jaHJvbml6ZXIuamF2YToxMjMpDQoJYXQgb3JnLmVjbGlwc2Uu c3d0LndpZGdl
dHMuRGlzcGxheS5ydW5Bc3luY01lc3NhZ2VzKERpc3BsYXkuamF2YTozNjU5 KQ0KCWF0IG9y
Zy5lY2xpcHNlLnN3dC53aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNo KERpc3BsYXku
amF2YTozMjk2KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLndpbmRvdy5XaW5k b3cucnVuRXZl
bnRMb29wKFdpbmRvdy5qYXZhOjgyMCkNCglhdCBvcmcuZWNsaXBzZS5qZmFj ZS53aW5kb3cu
V2luZG93Lm9wZW4oV2luZG93LmphdmE6Nzk2KQ0KCWF0IG9yZy5lY2xpcHNl LnVpLmludGVy
bmFsLk9wZW5QcmVmZXJlbmNlc0FjdGlvbi5ydW4oT3BlblByZWZlcmVuY2Vz QWN0aW9uLmph
dmE6NjUpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlvbi5y dW5XaXRoRXZl
bnQoQWN0aW9uLmphdmE6NDk4KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmFj dGlvbi5BY3Rp
b25Db250cmlidXRpb25JdGVtLmhhbmRsZVdpZGdldFNlbGVjdGlvbihBY3Rp b25Db250cmli
dXRpb25JdGVtLmphdmE6NTQ1KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLmFj dGlvbi5BY3Rp
b25Db250cmlidXRpb25JdGVtLmFjY2VzcyQyKEFjdGlvbkNvbnRyaWJ1dGlv bkl0ZW0uamF2
YTo0OTApDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0aW9uLkFjdGlvbkNv bnRyaWJ1dGlv
bkl0ZW0kNS5oYW5kbGVFdmVudChBY3Rpb25Db250cmlidXRpb25JdGVtLmph dmE6NDAyKQ0K
CWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLkV2ZW50VGFibGUuc2VuZEV2 ZW50KEV2ZW50
VGFibGUuamF2YTo2NikNCglhdCBvcmcuZWNsaXBzZS5zd3Qud2lkZ2V0cy5X aWRnZXQuc2Vu
ZEV2ZW50KFdpZGdldC5qYXZhOjkzOCkNCglhdCBvcmcuZWNsaXBzZS5zd3Qu d2lkZ2V0cy5E
aXNwbGF5LnJ1bkRlZmVycmVkRXZlbnRzKERpc3BsYXkuamF2YTozNjgyKQ0K CWF0IG9yZy5l
Y2xpcHNlLnN3dC53aWRnZXRzLkRpc3BsYXkucmVhZEFuZERpc3BhdGNoKERp c3BsYXkuamF2
YTozMjkzKQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5j aC5ydW5FdmVu
dExvb3AoV29ya2JlbmNoLmphdmE6MjM4OSkNCglhdCBvcmcuZWNsaXBzZS51 aS5pbnRlcm5h
bC5Xb3JrYmVuY2gucnVuVUkoV29ya2JlbmNoLmphdmE6MjM1MykNCglhdCBv cmcuZWNsaXBz
ZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2guYWNjZXNzJDQoV29ya2JlbmNoLmph dmE6MjIxOSkN
CglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2gkNC5ydW4o V29ya2JlbmNo
LmphdmE6NDY2KQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuZGF0YWJpbmRpbmcu b2JzZXJ2YWJs
ZS5SZWFsbS5ydW5XaXRoRGVmYXVsdChSZWFsbS5qYXZhOjI4OSkNCglhdCBv cmcuZWNsaXBz
ZS51aS5pbnRlcm5hbC5Xb3JrYmVuY2guY3JlYXRlQW5kUnVuV29ya2JlbmNo KFdvcmtiZW5j
aC5qYXZhOjQ2MSkNCglhdCBvcmcuZWNsaXBzZS51aS5QbGF0Zm9ybVVJLmNy ZWF0ZUFuZFJ1
bldvcmtiZW5jaChQbGF0Zm9ybVVJLmphdmE6MTQ5KQ0KCWF0IG9yZy5lY2xp cHNlLnVpLmlu
dGVybmFsLmlkZS5hcHBsaWNhdGlvbi5JREVBcHBsaWNhdGlvbi5zdGFydChJ REVBcHBsaWNh
dGlvbi5qYXZhOjEwNikNCglhdCBvcmcuZWNsaXBzZS5lcXVpbm94LmludGVy bmFsLmFwcC5F
Y2xpcHNlQXBwSGFuZGxlLnJ1bihFY2xpcHNlQXBwSGFuZGxlLmphdmE6MTUz KQ0KCWF0IG9y
Zy5lY2xpcHNlLmNvcmUucnVudGltZS5pbnRlcm5hbC5hZGFwdG9yLkVjbGlw c2VBcHBMYXVu
Y2hlci5ydW5BcHBsaWNhdGlvbihFY2xpcHNlQXBwTGF1bmNoZXIuamF2YTox MDYpDQoJYXQg
b3JnLmVjbGlwc2UuY29yZS5ydW50aW1lLmludGVybmFsLmFkYXB0b3IuRWNs aXBzZUFwcExh
dW5jaGVyLnN0YXJ0KEVjbGlwc2VBcHBMYXVuY2hlci5qYXZhOjc2KQ0KCWF0 IG9yZy5lY2xp
cHNlLmNvcmUucnVudGltZS5hZGFwdG9yLkVjbGlwc2VTdGFydGVyLnJ1bihF Y2xpcHNlU3Rh
cnRlci5qYXZhOjM2MykNCglhdCBvcmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUu YWRhcHRvci5F
Y2xpcHNlU3RhcnRlci5ydW4oRWNsaXBzZVN0YXJ0ZXIuamF2YToxNzYpDQoJ YXQgc3VuLnJl
ZmxlY3QuTmF0aXZlTWV0aG9kQWNjZXNzb3JJbXBsLmludm9rZTAoTmF0aXZl IE1ldGhvZCkN
CglhdCBzdW4ucmVmbGVjdC5OYXRpdmVNZXRob2RBY2Nlc3NvckltcGwuaW52 b2tlKFVua25v
d24gU291cmNlKQ0KCWF0IHN1bi5yZWZsZWN0LkRlbGVnYXRpbmdNZXRob2RB Y2Nlc3Nvcklt
cGwuaW52b2tlKFVua25vd24gU291cmNlKQ0KCWF0IGphdmEubGFuZy5yZWZs ZWN0Lk1ldGhv
ZC5pbnZva2UoVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2UuZXF1 aW5veC5sYXVu
Y2hlci5NYWluLmludm9rZUZyYW1ld29yayhNYWluLmphdmE6NTA0KQ0KCWF0 IG9yZy5lY2xp
cHNlLmVxdWlub3gubGF1bmNoZXIuTWFpbi5iYXNpY1J1bihNYWluLmphdmE6 NDQzKQ0KCWF0
IG9yZy5lY2xpcHNlLmVxdWlub3gubGF1bmNoZXIuTWFpbi5ydW4oTWFpbi5q YXZhOjExNjkp
DQoNCiFFTlRSWSBvcmcuZWNsaXBzZS5waHAudWkgNCAyIDIwMDctMDctMjMg MjE6NTU6MTUu
NjcxDQohTUVTU0FHRSBQcm9ibGVtcyBvY2N1cnJlZCB3aGVuIGludm9raW5n IGNvZGUgZnJv
bSBwbHVnLWluOiAib3JnLmVjbGlwc2UucGhwLnVpIi4NCiFTVEFDSyAxDQpv cmcuZWNsaXBz
ZS5jb3JlLnJ1bnRpbWUuQ29yZUV4Y2VwdGlvbjogUGx1Zy1pbiBvcmcuZWNs aXBzZS5waHAu
eGRlYnVnLnVpIHdhcyB1bmFibGUgdG8gbG9hZCBjbGFzcyBvcmcuZWNsaXBz ZS5waHAueGRl
YnVnLnVpLnByZWZlcmVuY2VzLlhEZWJ1Z0FkZE9uUHJlZmVyZW5jZVBhZ2Uu DQoJYXQgb3Jn
LmVjbGlwc2UuY29yZS5pbnRlcm5hbC5yZWdpc3RyeS5vc2dpLlJlZ2lzdHJ5 U3RyYXRlZ3lP
U0dJLnRocm93RXhjZXB0aW9uKFJlZ2lzdHJ5U3RyYXRlZ3lPU0dJLmphdmE6 MTgwKQ0KCWF0
IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVnaXN0cnkub3NnaS5SZWdp c3RyeVN0cmF0
ZWd5T1NHSS5jcmVhdGVFeGVjdXRhYmxlRXh0ZW5zaW9uKFJlZ2lzdHJ5U3Ry YXRlZ3lPU0dJ
LmphdmE6MTYyKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUuaW50ZXJuYWwucmVn aXN0cnkuRXh0
ZW5zaW9uUmVnaXN0cnkuY3JlYXRlRXhlY3V0YWJsZUV4dGVuc2lvbihFeHRl bnNpb25SZWdp
c3RyeS5qYXZhOjc4OCkNCglhdCBvcmcuZWNsaXBzZS5jb3JlLmludGVybmFs LnJlZ2lzdHJ5
LkNvbmZpZ3VyYXRpb25FbGVtZW50LmNyZWF0ZUV4ZWN1dGFibGVFeHRlbnNp b24oQ29uZmln
dXJhdGlvbkVsZW1lbnQuamF2YToyNDMpDQoJYXQgb3JnLmVjbGlwc2UuY29y ZS5pbnRlcm5h
bC5yZWdpc3RyeS5Db25maWd1cmF0aW9uRWxlbWVudEhhbmRsZS5jcmVhdGVF eGVjdXRhYmxl
RXh0ZW5zaW9uKENvbmZpZ3VyYXRpb25FbGVtZW50SGFuZGxlLmphdmE6NTEp DQoJYXQgb3Jn
LmVjbGlwc2UucGhwLmludGVybmFsLnVpLnByZWZlcmVuY2VzLlBIUFByZWZl cmVuY2VQYWdl
QmxvY2tzUmVnaXN0cnkkUEhQUHJlZmVyZW5jZVBhZ2VCbG9ja3NGYWN0b3J5 JDEucnVuKFVu
a25vd24gU291cmNlKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVudGltZS5T YWZlUnVubmVy
LnJ1bihTYWZlUnVubmVyLmphdmE6MzcpDQoJYXQgb3JnLmVjbGlwc2UucGhw LmludGVybmFs
LnVpLnByZWZlcmVuY2VzLlBIUFByZWZlcmVuY2VQYWdlQmxvY2tzUmVnaXN0 cnkkUEhQUHJl
ZmVyZW5jZVBhZ2VCbG9ja3NGYWN0b3J5LmNyZWF0ZVBIUFByZWZlcmVuY2VQ YWdlQmxvY2so
VW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2UucGhwLmludGVybmFs LnVpLnByZWZl
cmVuY2VzLlBIUFByZWZlcmVuY2VQYWdlQmxvY2tzUmVnaXN0cnkuZ2V0Qmxv Y2tzKFVua25v
cy5QSFBQcmVmZXJlbmNlUGFnZUJsb2Nrc1JlZ2lzdHJ5LmdldFBIUFByZWZl cmVuY2VQYWdl
QmxvY2soVW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2UucGhwLmlu dGVybmFsLnVp
LnByZWZlcmVuY2VzLkFic3RyYWN0UEhQUHJvcGVydHlQcmVmZXJlbmNlUGFn ZS5jcmVhdGVX
b3Jrc3BhY2VDb250ZW50cyhVbmtub3duIFNvdXJjZSkNCglhdCBvcmcuZWNs aXBzZS5waHAu
aW50ZXJuYWwudWkucHJlZmVyZW5jZXMuQWJzdHJhY3RQSFBQcm9wZXJ0eVBy ZWZlcmVuY2VQ
YWdlLmNyZWF0ZUNvbnRlbnRzKFVua25vd24gU291cmNlKQ0KCWF0IG9yZy5l Y2xpcHNlLmpm
YWNlLnByZWZlcmVuY2UuUHJlZmVyZW5jZVBhZ2UuY3JlYXRlQ29udHJvbChQ cmVmZXJlbmNl
UGFnZS5qYXZhOjIzMykNCglhdCBvcmcuZWNsaXBzZS5waHAuaW50ZXJuYWwu dWkucHJlZmVy
ZW5jZXMuQWJzdHJhY3RQSFBQcm9wZXJ0eVByZWZlcmVuY2VQYWdlLmNyZWF0 ZUNvbnRyb2wo
VW5rbm93biBTb3VyY2UpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UucHJlZmVy ZW5jZS5QcmVm
ZXJlbmNlRGlhbG9nLmNyZWF0ZVBhZ2VDb250cm9sKFByZWZlcmVuY2VEaWFs b2cuamF2YTox
NDU2KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNlLnByZWZlcmVuY2UuUHJlZmVy ZW5jZURpYWxv
ZyQxMy5ydW4oUHJlZmVyZW5jZURpYWxvZy5qYXZhOjEyMTMpDQoJYXQgb3Jn LmVjbGlwc2Uu
Y29yZS5ydW50aW1lLlNhZmVSdW5uZXIucnVuKFNhZmVSdW5uZXIuamF2YToz NykNCglhdCBv
cmcuZWNsaXBzZS5jb3JlLnJ1bnRpbWUuUGxhdGZvcm0ucnVuKFBsYXRmb3Jt LmphdmE6ODU3
KQ0KCWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLkpGYWNlVXRpbCQxLnJ1 bihKRmFjZVV0
aWwuamF2YTo0NikNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS51dGlsLlNhZmVS dW5uYWJsZS5y
dW4oU2FmZVJ1bm5hYmxlLmphdmE6MTkzKQ0KCWF0IG9yZy5lY2xpcHNlLmpm YWNlLnByZWZl
cmVuY2UuUHJlZmVyZW5jZURpYWxvZy5zaG93UGFnZShQcmVmZXJlbmNlRGlh bG9nLmphdmE6
MTIwNykNCglhdCBvcmcuZWNsaXBzZS51aS5pbnRlcm5hbC5kaWFsb2dzLkZp bHRlcmVkUHJl
ZmVyZW5jZURpYWxvZy5zaG93UGFnZShGaWx0ZXJlZFByZWZlcmVuY2VEaWFs b2cuamF2YTo0
MzMpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UucHJlZmVyZW5jZS5QcmVmZXJl bmNlRGlhbG9n
JDkuc2VsZWN0aW9uQ2hhbmdlZChQcmVmZXJlbmNlRGlhbG9nLmphdmE6Njk4 KQ0KCWF0IG9y
Zy5lY2xpcHNlLmpmYWNlLnZpZXdlcnMuU3RydWN0dXJlZFZpZXdlciQzLnJ1 bihTdHJ1Y3R1
cmVkVmlld2VyLmphdmE6ODQyKQ0KCWF0IG9yZy5lY2xpcHNlLmNvcmUucnVu dGltZS5TYWZl
UnVubmVyLnJ1bihTYWZlUnVubmVyLmphdmE6MzcpDQoJYXQgb3JnLmVjbGlw c2UuY29yZS5y
dW50aW1lLlBsYXRmb3JtLnJ1bihQbGF0Zm9ybS5qYXZhOjg1NykNCglhdCBv cmcuZWNsaXBz
ZS51aS5pbnRlcm5hbC5KRmFjZVV0aWwkMS5ydW4oSkZhY2VVdGlsLmphdmE6 NDYpDQoJYXQg
b3JnLmVjbGlwc2UuamZhY2UudXRpbC5TYWZlUnVubmFibGUucnVuKFNhZmVS dW5uYWJsZS5q
YXZhOjE5MykNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS52aWV3ZXJzLlN0cnVj dHVyZWRWaWV3
ZXIuZmlyZVBvc3RTZWxlY3Rpb25DaGFuZ2VkKFN0cnVjdHVyZWRWaWV3ZXIu amF2YTo4NDAp
DQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uudmlld2Vycy5TdHJ1Y3R1cmVkVmll d2VyLmhhbmRs
ZVBvc3RTZWxlY3QoU3RydWN0dXJlZFZpZXdlci5qYXZhOjExNTMpDQoJYXQg b3JnLmVjbGlw
c2UuamZhY2Uudmlld2Vycy5TdHJ1Y3R1cmVkVmlld2VyJDUud2lkZ2V0U2Vs ZWN0ZWQoU3Ry
dWN0dXJlZFZpZXdlci5qYXZhOjExNzgpDQoJYXQgb3JnLmVjbGlwc2UuamZh Y2UudXRpbC5P
cGVuU3RyYXRlZ3kuZmlyZVBvc3RTZWxlY3Rpb25FdmVudChPcGVuU3RyYXRl Z3kuamF2YToy
NTApDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UudXRpbC5PcGVuU3RyYXRlZ3ku YWNjZXNzJDQo
T3BlblN0cmF0ZWd5LmphdmE6MjQ0KQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNl LnV0aWwuT3Bl
blN0cmF0ZWd5JDMucnVuKE9wZW5TdHJhdGVneS5qYXZhOjQxOCkNCglhdCBv cmcuZWNsaXBz
ZS5zd3Qud2lkZ2V0cy5SdW5uYWJsZUxvY2sucnVuKFJ1bm5hYmxlTG9jay5q YXZhOjM1KQ0K
CWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLlN5bmNocm9uaXplci5ydW5B c3luY01lc3Nh
Z2VzKFN5bmNocm9uaXplci5qYXZhOjEyMykNCglhdCBvcmcuZWNsaXBzZS5z d3Qud2lkZ2V0
cy5EaXNwbGF5LnJ1bkFzeW5jTWVzc2FnZXMoRGlzcGxheS5qYXZhOjM2NTkp DQoJYXQgb3Jn
LmVjbGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5yZWFkQW5kRGlzcGF0Y2go RGlzcGxheS5q
YXZhOjMyOTYpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2Uud2luZG93LldpbmRv dy5ydW5FdmVu
dExvb3AoV2luZG93LmphdmE6ODIwKQ0KCWF0IG9yZy5lY2xpcHNlLmpmYWNl LndpbmRvdy5X
aW5kb3cub3BlbihXaW5kb3cuamF2YTo3OTYpDQoJYXQgb3JnLmVjbGlwc2Uu dWkuaW50ZXJu
YWwuT3BlblByZWZlcmVuY2VzQWN0aW9uLnJ1bihPcGVuUHJlZmVyZW5jZXNB Y3Rpb24uamF2
YTo2NSkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5hY3Rpb24uQWN0aW9uLnJ1 bldpdGhFdmVu
dChBY3Rpb24uamF2YTo0OTgpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0 aW9uLkFjdGlv
bkNvbnRyaWJ1dGlvbkl0ZW0uaGFuZGxlV2lkZ2V0U2VsZWN0aW9uKEFjdGlv bkNvbnRyaWJ1
dGlvbkl0ZW0uamF2YTo1NDUpDQoJYXQgb3JnLmVjbGlwc2UuamZhY2UuYWN0 aW9uLkFjdGlv
bkNvbnRyaWJ1dGlvbkl0ZW0uYWNjZXNzJDIoQWN0aW9uQ29udHJpYnV0aW9u SXRlbS5qYXZh
OjQ5MCkNCglhdCBvcmcuZWNsaXBzZS5qZmFjZS5hY3Rpb24uQWN0aW9uQ29u dHJpYnV0aW9u
SXRlbSQ1LmhhbmRsZUV2ZW50KEFjdGlvbkNvbnRyaWJ1dGlvbkl0ZW0uamF2 YTo0MDIpDQoJ
YXQgb3JnLmVjbGlwc2Uuc3d0LndpZGdldHMuRXZlbnRUYWJsZS5zZW5kRXZl bnQoRXZlbnRU
YWJsZS5qYXZhOjY2KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53aWRnZXRzLldp ZGdldC5zZW5k
RXZlbnQoV2lkZ2V0LmphdmE6OTM4KQ0KCWF0IG9yZy5lY2xpcHNlLnN3dC53 aWRnZXRzLkRp
c3BsYXkucnVuRGVmZXJyZWRFdmVudHMoRGlzcGxheS5qYXZhOjM2ODIpDQoJ YXQgb3JnLmVj
bGlwc2Uuc3d0LndpZGdldHMuRGlzcGxheS5yZWFkQW5kRGlzcGF0Y2goRGlz cGxheS5qYXZh
OjMyOTMpDQoJYXQgb3JnLmVjbGlwc2UudWkuaW50ZXJuYWwuV29ya2JlbmNo LnJ1bkV2ZW50
TG9vcChXb3JrYmVuY2guamF2YToyMzg5KQ0KCWF0IG9yZy5lY2xpcHNlLnVp LmludGVybmFs
LldvcmtiZW5jaC5ydW5VSShXb3JrYmVuY2guamF2YToyMzUzKQ0KCWF0IG9y Zy5lY2xpcHNl
LnVpLmludGVybmFsLldvcmtiZW5jaC5hY2Nlc3MkNChXb3JrYmVuY2guamF2 YToyMjE5KQ0K
CWF0IG9yZy5lY2xpcHNlLnVpLmludGVybmFsLldvcmtiZW5jaCQ0LnJ1bihX b3JrYmVuY2gu
amF2YTo0NjYpDQoJYXQgb3JnLmVjbGlwc2UuY29yZS5kYXRhYmluZGluZy5v YnNlcnZhYmxl
LlJlYWxtLnJ1bldpdGhEZWZhdWx0KFJlYWxtLmphdmE6Mjg5KQ0KCWF0IG9y Zy5lY2xpcHNl
LnVpLmludGVybmFsLldvcmtiZW5jaC5jcmVhdGVBbmRSdW5Xb3JrYmVuY2go V29ya2JlbmNo
LmphdmE6NDYxKQ0KCWF0IG9yZy5lY2xpcHNlLnVpLlBsYXRmb3JtVUkuY3Jl YXRlQW5kUnVu
Re: XDebug Support for PDT 1.0 / Error Message [message #39092 is a reply to message #38929] Wed, 25 July 2007 11:08 Go to previous messageGo to next message
ok, this one has me stumped. I have a fresh install of PDT I20070712 +
xdebug 0.2.3 installed running on the same version of Java as you and it
works fine for me. I did use a clean workspace as well. Can you confirm
the plugin files in your eclipse/plugins directory. They should be of the following
date/time and size
21/07/2007 20:02 90,539 org.eclipse.php.xdebug.core_0.2.3.jar
21/07/2007 20:02 56,421 org.eclipse.php.xdebug.ui_0.2.3.jar
Dave Kelsey
Markus Lauff wrote:
> Dear Dave,
> Markus
>> subdirectory
>> Dave Kelsey
>> Markus Lauff wrote:
>>> Hi,
>>> following error:
>>> Markus
>>>> Dave Kelsey
Re: XDebug Support for PDT 1.0 / Error Message [message #39185 is a reply to message #38839] Wed, 25 July 2007 14:34 Go to previous messageGo to next message
Sorry, my fault.
In copied the src folders to the plugin directory - not the jar files.
Now it works.
Markus
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #39309 is a reply to message #37889] Fri, 27 July 2007 14:00 Go to previous messageGo to next message
Originally posted by: schreck84.gmail.com
Dave,
Will the proxy ability be built in at some point for this plugin?
http://xdebug.org/docs-dbgp.php#just-in-time-debugging-and-d ebugger-proxies
We are using Eclipse/PDT in a corporate environment with multiple people
needing to debug at the same time. I noticed that the ability is in XDebug,
but I could not find a "proxyinit" command in the XDebug/PDT plugin.
Jason Schreckengost
"Dave Kelsey" <dkel50@hotmail.com> wrote in message
news:f7tn8p$qv7$1@build.eclipse.org...
>I have just uploaded to
>https://bugs.eclipse.org/bugs/show_bug.cgi?id=169408
> xdebug support for PDT 1.0 version I20070712 Integration build
> This version also fixes a some bugs
> 1. Web launch didn't remember the server URL
> 2. check box for conditional breakpoints didn't disable the condition
> 3. Watch expression such as $a.$b didn't work
> 4. sample mapper didn't correctly handle remapping of inbound filenames
> I don't know if this version will work with 1.0 M1 though, it may do.
> Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #39403 is a reply to message #39309] Fri, 27 July 2007 19:00 Go to previous messageGo to next message
D Kelsey is currently offline D KelseyFriend
Support for proxies is on my list of things to look at but have never found
the time.
Is there a specific proxy that you use ?
Dave Kelsey
Jason Schreckengost wrote:
> Dave,
> Jason Schreckengost
>> Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #39790 is a reply to message #39403] Mon, 30 July 2007 12:30 Go to previous messageGo to next message
It looked like XDebug had the support built in. I have not read the docs
enough yet to be sure, but if that is in fact built in, we would be using
that by default.
I have a few other projects going on atm, but this proxy may just come in
handy for a few of these. I could look through your current code and try
implementing it if that helps. My Java is a bit rusty, but I am sure it will
come back quickly.
Jason Schreckengost
news:f8dfcd$5qp$1@build.eclipse.org...
> found
> the time.
> Dave Kelsey
>> Dave,
>> XDebug, but I could not find a "proxyinit" command in the XDebug/PDT
>> plugin.
>> Thanks,
>> Jason Schreckengost
>>> Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #39822 is a reply to message #39790] Mon, 30 July 2007 13:06 Go to previous messageGo to next message
The proxy is an intermediate application that sits between the IDE and the
target being debugged. The IDE registers with the proxy. The XDebug engine
connects the the proxy rather than the IDE directly and the proxy then
connects to the IDE and then routes both the inbound and outbound data
accordingly.
The only proxy I know of is the one written by activestate for Komodo.
I haven't thought too much about how the IDE may work with the proxy, but
in order to have a complete solution I would need to code a proxy as well.
This isn't going to be something that would be quick to implement. Sorry.
Dave Kelsey
> that by default.
> come back quickly.
> Jason Schreckengost
>> found
>> the time.
>> Dave Kelsey
>>> Dave,
>>> plugin.
>>> Thanks,
>>> Jason Schreckengost
>>>> Dave Kelsey
Re: XDebug Support for PDT 1.0 I20070712 is available. [message #40883 is a reply to message #37889] Fri, 03 August 2007 20:20 Go to previous message
Igor Kravchyk is currently offline Igor KravchykFriend
Hello Dave,
Thank you for your great work!
I have one notice for now: when I see contents of $this object (like
$this->property) in variables view, stepping through the code by F5/F6
redraws variables view and collapses $this object tree so that I need to
expand it every time I'm stepping. Previous version of plugin (for PDT
0.7) worked fine.
Igor.
Previous Topic:Using exec to run Java apps
Next Topic:Windows-1250 charset for PHP content
Current Time: Wed Feb 05 04:12:27 GMT 2025
Powered by FUDForum. Page generated in 0.05397 seconds
