ClassNotFoundException when configuring caching in OSGi environment [message #385493] |
Mon, 23 February 2009 10:13 |
I'm currently trying to configure eclipselinks' caching for out
application.
I don't want any caching to happen in our JUnit tests, so I specified:
eclipselink.cache.type.default=NONE
in my properties file and got a ClassNotFoundException for the class
org.eclipse.persistence.internal.identitymaps.NoIdentityMap (which is part
of the org.eclipse.persistence.core bundle). - Stacktrace see below
Configuring other values for cache type (e.g. "Full") results in similar
ClassNotFoundExceptions for other classes from the
org.eclipse.persistence.internal.identitymaps package).
The eclipselink bundles are all loaded and they work fine when I remove
the
eclipselink.cache.type.default property from my configuration.
What am I doing wrong?
Joerg
Here's the output I get in stdout and stderr:
[junit] ------------- Standard Output -----------------
[junit] osgi> Persistence bundle starting...
[junit] Persistence bundle started.
[junit] ProviderTracker: New service detected...
[junit] ProviderTracker: Added service
org.eclipse.persistence.jpa.osgi.PersistenceProviderOSGi
[junit] Exception caught: Exception [EclipseLink-28006] (Eclipse
Persistence Services - 1.0.2 (Build 20081024)):
org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on
[junit] Exception Description: ClassNotFound:
[org.eclipse.persistence.internal.identitymaps.NoIdentityMap ] specified in
[eclipselink.cache.type.default] property.
[junit] Internal Exception: java.lang.ClassNotFoundException:
[junit] Initializing database ...
[junit] Setting JPA property: eclipselink.cache.type.default to NONE
[junit] Setting JPA property: log.level to ALL
[junit] ------------- Standard Error -----------------
[junit] Local Exception Stack:
[junit] Exception [EclipseLink-28006] (Eclipse Persistence Services -
[junit] at
org.eclipse.persistence.exceptions.EntityManagerSetupExcepti on.classNotFoundForProperty(EntityManagerSetupException.java :130)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. findClassForProperty(EntityManagerSetupImpl.java:532)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. updateDescriptorCacheSettings(EntityManagerSetupImpl.java:56 4)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. updateServerSession(EntityManagerSetupImpl.java:1194)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. deploy(EntityManagerSetupImpl.java:237)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.getServerSession(EntityManagerFactoryImpl.java:69)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:118)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManagerImpl(EntityManagerFactoryImpl.java:112)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerFactoryImp l.createEntityManager(EntityManagerFactoryImpl.java:100)
[junit] at
de.cenit.eb.sm.finca.functional.dblayer.events.internal.JpaU tils.createEntityManager(Unknown
Source)
[junit] at
de.cenit.eb.sm.finca.functional.dblayer.events.internal.JpaU tils.create(Unknown
Source)
[junit] at
de.cenit.eb.sm.finca.functional.dblayer.events.internal.Defa ultEventFromDatabaseService.activate(Unknown
Source)
[junit] at
de.cenit.eb.sm.finca.functional.dblayer.events.internal.Osgi EventFromDatabaseService.activate(Unknown
Source)
[junit] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[junit] at
[junit] at
[junit] at java.lang.reflect.Method.invoke(Method.java:585)
[junit] at
org.eclipse.equinox.ds.instance.InvokeMethod.invokeMethod(In vokeMethod.java:144)
[junit] at
org.eclipse.equinox.ds.instance.InvokeMethod.activateCompone nt(InvokeMethod.java:60)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.activate(BuildD ispose.java:672)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.buildComponentC onfigInstance(BuildDispose.java:122)
[junit] at
org.eclipse.equinox.ds.instance.InstanceProcess.registerComp onentConfigurations(InstanceProcess.java:145)
[junit] at
org.eclipse.equinox.ds.resolver.Resolver.dispatchWork(Resolv er.java:701)
[junit] at
org.eclipse.equinox.ds.workqueue.WorkQueue$Queued.dispatch(W orkQueue.java:57)
[junit] at
org.eclipse.equinox.ds.workqueue.WorkQueue.run(WorkQueue.jav a:108)
[junit] Caused by: java.lang.ClassNotFoundException:
[junit] at java.lang.ClassLoader.findClass(ClassLoader.java:358)
[junit] at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
[junit] at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
[junit] at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
[junit] at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
[junit] at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
[junit] at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
[junit] at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
[junit] at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
[junit] at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
[junit] at
org.eclipse.persistence.internal.jpa.deployment.osgi.BundleP roxyClassLoader.findClass(BundleProxyClassLoader.java:51)
[junit] at
org.eclipse.persistence.internal.jpa.deployment.osgi.BundleP roxyClassLoader.loadClass(BundleProxyClassLoader.java:59)
[junit] at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
[junit] at java.lang.Class.forName0(Native Method)
[junit] at java.lang.Class.forName(Class.java:242)
[junit] at
org.eclipse.persistence.internal.security.PrivilegedAccessHe lper.getClassForName(PrivilegedAccessHelper.java:86)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. findClass(EntityManagerSetupImpl.java:522)
[junit] at
org.eclipse.persistence.internal.jpa.EntityManagerSetupImpl. findClassForProperty(EntityManagerSetupImpl.java:528)
[junit] ... 23 more
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
Source)
[junit] at
Source)
[junit] at
de.cenit.eb.sm.finca.functional.dblayer.events.internal.Defa ultEvent2DatabaseService.activate(Unknown
Source)
[junit] at
de.cenit.eb.sm.finca.functional.dblayer.events.internal.Osgi Event2DatabaseService.activate(Unknown
Source)
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
org.eclipse.equinox.ds.instance.RegisterComponentService$2.g etService(RegisterComponentService.java:123)
[junit] at
org.eclipse.osgi.framework.internal.core.ServiceUse$1.run(Se rviceUse.java:108)
[junit] at java.security.AccessController.doPrivileged(Native Method)
[junit] at
org.eclipse.osgi.framework.internal.core.ServiceUse.getServi ce(ServiceUse.java:106)
[junit] at
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.getService(ServiceRegistrationImpl.java:345)
[junit] at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.g etService(BundleContextImpl.java:884)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.getService(Buil dDispose.java:450)
[junit] at
org.eclipse.equinox.ds.instance.InvokeMethod.findBindOrUnbin dMethod(InvokeMethod.java:237)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.bindServiceToRe ference(BuildDispose.java:387)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.bindReference(B uildDispose.java:356)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.bind(BuildDispo se.java:306)
[junit] at
org.eclipse.equinox.ds.instance.BuildDispose.buildComponentC onfigInstance(BuildDispose.java:120)
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] at
[junit] ... 35 more
Re: ClassNotFoundException when configuring caching in OSGi environment [message #385742 is a reply to message #385495] |
Wed, 25 February 2009 14:24 |
Hi James,
thanks for your reply - it pointed me into the right direction.
Yes, it seems to be a classloader problem.
Adding an import for
to the MANIFEST.MF solves the problem.
However, this adds a fix dependency to the EclipseLink bundles
which is a little bit ugly, but currently no problem for me.
Thanks for help,
Jörg
FUDForum. Page generated in 0.03244 seconds
